| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| MikeKP61 |
 MikeKP61 Two Stroke Sniffer
 Posted: 03:33 - 31 Jan 2018 Post subject: |
Nothing really wrong with it if it works? If the donor car was running the alternator would be supplying the voltage and current in addition to the battery so you might have a better chance of starting it. Also repeatedly starting the dead car off the donors battery without it running it might eventually drain the donor battery if the fault persists making two dead cars  |
| MCN |
 MCN Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 07:42 - 31 Jan 2018 Post subject: |
With my jump leads: connect the leads and crank it up.
With Halford Jump leads: connect the leads and wait for the battery to charge a bit or watch the leads melt.
If the leads can handle the amps have at it. Helps to put those leads on the engine and starter feed rather than on the battery, if you can. ____________________ a.k.a 'Geri'
| MCN |
 MCN Super Spammer
| stinkwheel |
 Posted: 10:50 - 31 Jan 2018 Post subject: |
You have to be really careful jump starting a car these days.
I would always read the manual. My brother fried the ECU on his wifes pugeot (to his great cost and earache) by doing as described by the OP and MCN. Among other things, it turns out it has a specific jump starting post you're supposed to connect to and absolutely not the battery positive. You can jump it but there are some really specific instructions for doing so.
For reasons I'm not going to get into an argument about again withing a couple of months, if I was starting a bike from a car, I would do it with the car engine off. If a car battery can't crank and start a bike then have charge left to start the car, there was something wrong with it anyway. Others can do whatever the hell they want and shouldn't come crying to me if their reg/rec cooks.
Those little jump starter battery packs are black magic. I thought they were a gimmick until I saw someone fire up a transit van with one three times on one charge at a music festival. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| cb1rocket |
 cb1rocket World Chat Champion
| MCN |
 MCN Super Spammer
| Polarbear |
 Polarbear Super Spammer
 Posted: 14:43 - 31 Jan 2018 Post subject: |
I've just connected leads between batteries and never worried about it. It's worked every time for me and personally I can't see a problem. Paralleling a battery is just providing a bigger electric 'sink'. Same voltage, same resistance just more amps available.
I would't argue with any of Stinkwheels points but then I wouldn't be too bothered about implementing them either as I've never had any problems in 40 years of motoring doing it like that.
You do what you are happy doing.  ____________________ Victory Cross Country American tractor. |
| grr666 |
 grr666 Super Spammer
 Posted: 14:54 - 31 Jan 2018 Post subject: |
I had a van which I sold but not long before selling it had £80 worth of new battery. I still had the old one so
I swapped them over and kept the good un when I sold the van on. So I use that for jumping. 770cca is enough
to start a diesel so it makes light work of starting a bike via some jumper cables. The scoot was as dead as a doornail last
year when I wheeled it out of hibernation, my spare battery started it up no problem and an hours ride was enough to
charge up the one on the scoot. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| MarJay |
 MarJay But it's British!
| MCN |
 MCN Super Spammer
| stinkwheel |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| grr666 |
| G |
 G The Voice of Reason
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
| grr666 |
 Posted: 16:22 - 31 Jan 2018 Post subject: |
I buy all my batteries from Tayna. Just looking to change the one in the van for one with a bit more in the tank ,
so to speak as I want to set up an electric heater in the back to keep the doggo warm after walkies. She's usually
soaking wet and short haired. I can't watch her shiver the poor sod, so I'm looking into making the back warmer
for her, but it needs to be instant heat so electric. Also be handy for defrosting. That said Tayna are much dearer than
you paid at Padgetts.
https://www.tayna.co.uk/motorcycle-batteries/yuasa/ytz10s/ ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| G |
 Posted: 16:30 - 31 Jan 2018 Post subject: |
| grr666 wrote: | I buy all my batteries from Tayna. Just looking to change the one in the van for one with a bit more in the tank ,
Do you want the heater to be running while the car is running?
Electric doesn't mean instant much more than other options.
If it's for heat when you're not driving - a diesel night heater might be a better option.
If you're driving, your alternator is going to have to top up any used power - so an uprated alternator may be a better option if it's going to put a good bit of drain on the battery.
Ideally also have ducting to heat the back from the main heat - then you should only need a fairly short time with electric heat.
I'm not sure what options are available, but for any decent heat from 12v you're going to be talking BIG amps.
How about a 12v heated pet mat? |
| MCN |
 MCN Super Spammer
 Posted: 16:47 - 31 Jan 2018 Post subject: |
https://www.tayna.co.uk/motorcycle-batteries/yuasa/ytz10s/ |
There are specific 'leisure' batteries for running campers, caravans and boats etc. look for one of them.
Different design to a cranking battery, google is your friend. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| grr666 |
 Posted: 16:54 - 31 Jan 2018 Post subject: |
Pet mat may work, I've just spent 60 quid on a large 4 inch thick pvc coated cushion for her to lay on and
to insulate against the floor though. It's just that the van doesn't really warm up at all between here and the forest
we use, being semi rural here I don't have to go far to find lovely countryside, but she definitely has more doggo
fun in the forest which is only 8 minutes away, by the time we return to the van, what little heat had built up on the way
there has gone again. She has got a coat, and a habit of jumping in the river with it on rendering it useless.
I was thinking something like this might be okay? Certainly cheap enough to take a punt.
https://www.ebay.co.uk/itm/DC-12V-300W-Car-Portable-Ceramic-Heater-Cooler-Dryer-Fan-Defroster-Demister-UK/391944035944?hash=item5b41af5e68:g:P0UAAOSwQcJaFO37 ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| MCN |
 MCN Super Spammer
| grr666 |
 Posted: 17:12 - 31 Jan 2018 Post subject: |
There's certainly scope to remove the plylining and dynamat and insulate the sides. . ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| Nobby the Bastard |
The last post was made 8 years, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
