Yamaha YBR125 Polarity
Cavallo
PostPosted: 14:38 - 01 Feb 2018    Post subject: Yamaha YBR125 Polarity Reply with quote
Hello,
I intend to install a Motorcycle alarm with remote start and the user manual specify to check the bike polarity. I dont know if its a Positive polarity or Negative Polarity. any suggestions how i can check ?
Thanks
zark
PostPosted: 14:54 - 01 Feb 2018    Post subject: Reply with quote
It's negative earth...
Home fit alarms are a pain in the arse though, I give it a month till the 'my bike won't start' thread... Then the 'alarm for sale thread'
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
Cavallo
PostPosted: 15:10 - 01 Feb 2018    Post subject: Reply with quote
Hi,
this is the note shown in the manual
Note: Bike with Positive Starter connect RED wire to RED/WHITE wire (factory default)
Bike with Negative Starter connect GREEN wire to RED/WHITE wire
Most Yamaha Bikes are negative, all other bikes positive (check polarity)
the thing is that i cant figure it out how to check it.
PostPosted: 17:02 - 01 Feb 2018    Post subject: Reply with quote
Don't use the remote start option.
Cavallo
PostPosted: 18:47 - 01 Feb 2018    Post subject: Reply with quote
why not?
MCN
PostPosted: 19:37 - 01 Feb 2018    Post subject: Reply with quote
Cavallo wrote:
why not?
Because.
Stalk
PostPosted: 19:57 - 01 Feb 2018    Post subject: Reply with quote
Presumably you are insured third party, electrical fire and theft? If you need to ask such a basic question, should you be messing with it? Also, I think its an offence to leave an unnatended vehicle running, if not, it certainly is stupid. Even if it is chained up, some twat will try to ride it away. Not going to be that far away when you use the remote start? What's the point then?
PostPosted: 23:59 - 01 Feb 2018    Post subject: Reply with quote
Cavallo wrote:
why not?
At what point will you use it. It's of zero use and will break.
Snap your steering lock and remote start, bike gone. Start up and it's in gear, bike on floor.
There isn't a law about leaving an engine running...
Nobby the Bastard
Harley Gaydar
PostPosted: 00:02 - 02 Feb 2018    Post subject: Reply with quote
Anyway, I've never come across a vehicle that was positive polarity.
Just assume negative unless the manual says positive. The worst that could happen is that you fry the alarm and end up with a flat battery.
Wait....
Triumph Sprint ST 1050
MCN
PostPosted: 08:03 - 02 Feb 2018    Post subject: Reply with quote
Auld shite was Positive to Earth. Newer shite is Mostly if not exclusively Negative to Earth.
But you knew that. 😊
I hooked up the 6v battery to one of my Auld BSAs and sizzles the coil cause I connected Negative to Earth. The cable colours are not Red and Black like more modern stuff. So it was not my fault. Embarassed
PostPosted: 09:57 - 02 Feb 2018    Post subject: Reply with quote
https://www.legislation.gov.uk/uksi/1986/1078/regulation/107/made "Leaving motor vehicles unattended: no person shall leave, or cause or permit to be left, on a road a motor vehicle which is not attended by a person licensed to drive it unless the engine is stopped"
https://www.legislation.gov.uk/uksi/1986/1078/regulation/98/made "Stopping of engine when stationary: the driver of a vehicle shall, when the vehicle is stationary, stop the action of any machinery attached to or forming part of the vehicle so far as may be necessary for the prevention of noise"
Are offences thanks to https://www.legislation.gov.uk/ukpga/1988/52/section/42
Cavallo
PostPosted: 10:14 - 02 Feb 2018    Post subject: Reply with quote
There isn't a law about leaving an engine running...[/quote]
bike won't start is its not in neutral.
RhynoCZ
PostPosted: 10:52 - 02 Feb 2018    Post subject: Reply with quote
This, Thumbs Up
RhynoCZ
PostPosted: 10:55 - 02 Feb 2018    Post subject: Reply with quote
Cavallo wrote:
Bike won't start is its not in neutral.
Ideally it won't. But still, do you have manual choke? If so, then don't bother with the remote start. Wink
Cavallo
PostPosted: 11:41 - 02 Feb 2018    Post subject: Reply with quote
nope. Fuel Injection
PostPosted: 15:59 - 02 Feb 2018    Post subject: Reply with quote
Well they look to be a bit pony. Laughing
The last post was made 8 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 92.8 Kb
