Bending rubber fuel lines
andym
PostPosted: 19:30 - 03 Feb 2018    Post subject: Bending rubber fuel lines Reply with quote
I've started working on my VFR again and noticed that some of the fuel line is a little on the crispy side, I done a repair on part of it over 4 years ago with a length of reinforced fuel line and plastic L joints (whatever the correct name for them is).
Is there a way of permanently bending 1 length of fuel line rather than having several joints in there?
PostPosted: 19:50 - 03 Feb 2018    Post subject: Reply with quote
You can get braided steel fuel hose. Highly unlikely to kink.
You can put a fair bend in the clear, thick walled stuff they use for go-karts too. Freeline I think it's called. I've been using that a lot recently. Is good quality and ethanol proof.
andym
PostPosted: 19:56 - 03 Feb 2018    Post subject: Reply with quote
you of all people should know the kind of bends that I would need to put in the fuel line, would the stuff you've mentioned do 90 degree bends?
Nobby the Bastard
Harley Gaydar
PostPosted: 21:04 - 03 Feb 2018    Post subject: Reply with quote
Just go to your local car tat shop and buy some fuel pipe. Explain that you want the thinnest wall becasue you want it to bend quite a but, else they'll sell you stuff thats an inch in diameter
Triumph Sprint ST 1050
MCN
PostPosted: 23:07 - 03 Feb 2018    Post subject: Reply with quote
It will all bend 90° but the bigger the diameter of the hose the more space it will need to bend.
What do Honda sell?
ZRX61
Victor Meldrew
PostPosted: 03:39 - 04 Feb 2018    Post subject: Reply with quote
Thin wall is much more likely to kink & block/restrict the flow.
They're not one night stands, they're auditions.
bugeye_bob
PostPosted: 10:59 - 04 Feb 2018    Post subject: Reply with quote
Could you not buy the correct genuine part with the bends in ?
They tend to last a good few years before they go crisp again.
PostPosted: 12:38 - 04 Feb 2018    Post subject: Reply with quote
How tight do you want them?
https://www.bikechatforums.com/download.php?id=100787
Nobby the Bastard
Harley Gaydar
PostPosted: 13:24 - 04 Feb 2018    Post subject: Reply with quote
This is what I meant about thin wall. The last stuff I bought was literally an inch in diameter for an internal pipe size the same as that.
ThatDippyTwat
PostPosted: 14:09 - 04 Feb 2018    Post subject: Reply with quote
That's for really high pressure FI systems, usually labelled as J30.
MCN
PostPosted: 14:53 - 04 Feb 2018    Post subject: Reply with quote
https://m.ebay.ie/itm/HONDA-VFR800-FUEL-LINES-1998/263082743312?hash=item3d40f41610:g:iZ0AAOSwIhxZZGMl
Prolly nae good.. but mibby less faphery.
PostPosted: 18:48 - 04 Feb 2018    Post subject: Reply with quote
Those "fuel lines" look awfully like brake lines.
MCN
PostPosted: 19:24 - 04 Feb 2018    Post subject: Reply with quote
I was on mobile and never looked very closely. But the rest has listed brake lines as fuel lines. 🤣
andym
PostPosted: 22:14 - 04 Feb 2018    Post subject: Reply with quote
Look like brake lines, but says they are fuel lines for a VFR800.
Poor picture of the fuel line at the moment:
https://cdn.bcf.44bytes.net/files/vfrside.jpg
Just trying to move it up to the tank the old line feels quite stiff, I did want to replace it for 1 piece of hose, but I suppose I could get away with just replacing from the fuel pump to filter, then from filter to the first joint.
The last post was made 8 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 83.21 Kb
