R & G heated grip installation
Fdz26
PostPosted: 17:57 - 04 Feb 2018    Post subject: R & G heated grip installation Reply with quote
Hi, has anyone got any tips for installing R & G heated grips. I'm having problems with the grip throttle side as the inside of it is made of plastic similar to a throttle tube with the rubber grip on the outside. It's basically a case trying to stick a plastic tube onto a plastic tube. The rental grip glue supplied with it seems to break down quickly causing the grip to come loose. I don't really want to use super glue as I'm not sure I will get it on and lined up properly before it's set. I also doubt the spray paint or hairspray techniques will work.
Am I being thick or is this a crap design. I've never had problems with grips coming loose before
B0ndy
PostPosted: 18:08 - 04 Feb 2018    Post subject: Reply with quote
Done this a few times:
- Sand off any adhesive left on the throttle tube
- Heat up the grip using a hair dryer
- Put some fairy liquid onto the throttle tube
- Slide it on
- Move the grip back a couple of inches and wipe off the fairy liquid
- Apply some superglue (not the stuff that comes with those grips, it's crap) loctite is good
- Slide it over the glued throttle tube
- Leave it a couple of hours to set
If you still can't get it on after sanding off the adhesive, keep sanding the throttle tube down until it goes on.
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
Courier265
PostPosted: 18:29 - 04 Feb 2018    Post subject: Reply with quote
I've also done this a few times.
I remove the old grip and clean off the old crap with brake cleaner.
Once the pipe is clean, I wrap the pipe with tape, insulating tape or
whatever I have handy. Heat the grip and with a little brake cleaner
the grip will go on but it should be a tight fit so tapping with a rubber
mallet will help...
Job done...
Fdz26
PostPosted: 19:38 - 04 Feb 2018    Post subject: Reply with quote
Thanks for the reply guys. I'm familiar with the techniques you describe. The problem I have is with the throttle side grip of the R & G heated grips. The inside of the grip is a thin plastic tube that has the heating element wrapped around the outside with a rubber grip on top of that. It's not like putting a normal rubber grip onto the throttle tube. The fit is very loose, too loose for my liking.
Confusion
PostPosted: 11:04 - 05 Feb 2018    Post subject: Re: R & G heated grip installation Reply with quote
I fitted a set of R&G grips to my ZZR. The left grip was was so tight
I had to drive it on with a hammer and block of wood.
The RH grip was slightly too big. I used a small amount of
Unibond 100% Power waterproof glue to fix it in place.
The bond failed after two years.
I used more glue for the second attempt, enough to ensure
that the entire surface of the tube was coated. This is still
solid after three years of use.
https://www.unibond.co.uk/en/diy-adhesives/multi-purpose-repair/unibond-100--glue.html
Bandit 650SA, ZZ-R1100
Aceslock
PostPosted: 14:32 - 05 Feb 2018    Post subject: Reply with quote
Ihave just fitted these myself to my ZX6, and had the same issue. a mate gave me some grip glue to secure it as it was very loose as you said. I took it out for a spin the next day but i must have got 200 yards from home and the fker came loose again so i had to abort and get home.
I plastered it with the glue and left it for a week, done about 80 miles yesterday and it has been fine Thumbs Up
Previous Bike: Skyjet SJ27
Sold: Yamaha YZF 600 R Thundercat. Sold: ZX636R
Current bike: R1 14B (Beast)
There is a gap of 2 years, 241 days between these two posts...
RodRides This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 5 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 54.3 Kb
