What tool should I use to remove a 5mm M6 stud? solved
DanteKrys
PostPosted: 14:37 - 05 Feb 2018    Post subject: What tool should I use to remove a 5mm M6 stud? solved Reply with quote
Hi,
So I broke a 6 mm diameter bolt, and I am left with 5mm stud sticking out from a center stand pivot (see pic). I need to remove it so that I can unscrew the pivot. There are many tools and methods, but not sure if those are appropriate for 5mm long 6mm diameter bolts. Should I buy a bolt extractor dills, Impact Stud Extractor or 1/2drive stud extractor or other extractor. I am on limited budget and 5 mm grip makes it difficult. THx
My bike YBR125
Ybr125
PostPosted: 16:44 - 05 Feb 2018    Post subject: Reply with quote
Lots of plus gas and a set of GOOD (not Chinese) mole grips or a GOOD (not Chinese) Stillsons.
Or you could file flats on it and use a spanner.
If you are going to drill it, I would be drilling and collapsing the thread wall with a cold chisel and then running down with a tap.
I GUARANTEE that if you drill and use a stud extractor it will shear off.
Shall I highlight the caps just to make sure Laughing Thumbs Up
Oh, and Linuxyeti, Chinese tools are worse than Chinese bikes, happy? Cool
Triumph Trophy Launch Edition
PostPosted: 17:37 - 05 Feb 2018    Post subject: Reply with quote
If you try to undo it, LOTS of heat on it after the penetrating spray.
But you'll land up drilling it.
I'm unclear which part of the bike it's on. Is this part of the frame or part of the stand?
PostPosted: 17:43 - 05 Feb 2018    Post subject: Reply with quote
M6 seems a bit thin for a center stand pivot. Even my tiny RXS uses M8.
I'd flaten either side and put a spanner on it if it isn't too small to do so.
DanteKrys
PostPosted: 19:52 - 05 Feb 2018    Post subject: Reply with quote
Solved
So I went to a local workshop. They tried to remove it using the pilers. But since I had a new center stand pivot bolt the guys decidded that the best it would be to remove the old bolt entirely. It was hard to remove (8 years of Scottish weather). They welded a nut to the bold and unscrew the bolt using large ratchet like wrench. TBH I wouldn't be able to do it at home.
Ybr125
dydey90
PostPosted: 20:59 - 05 Feb 2018    Post subject: Reply with quote
It’s worth having a set of unfuckers for stuff like this.
Linky
I bought some for work, never used them, then they dug me out the shit a few weeks ago and saved me a good hour on a breakdown.
PostPosted: 12:32 - 06 Feb 2018    Post subject: Reply with quote
Linky
I have some like those for getting locking wheelnuts off without the key. The are pretty good. Thumbs Up
The last post was made 8 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 53.01 Kb
