NBR - Aerial Reception
Gazz
PostPosted: 22:38 - 09 Feb 2018    Post subject: NBR - Aerial Reception Reply with quote
The wind snapped the rusty aerial off my car. Where it had broken, I had to buy a new base for it as well as the long bit.
As a result the radio was poor and would jump from station to station (finding which reception was best).
After fitting the new aerial, the reception is still the same as when the there was no aerial on it.
The new one was a direct replacement using the existing wires that was on the original, but was an aftermarket one.
Any way of improving the signal?
doggone
PostPosted: 23:38 - 09 Feb 2018    Post subject: Reply with quote
Is it possible there was an extra earth cable underneath that fell off?
Most designs must be grounded to the vehicle.
Often a good place to mount it of the way is not well earthed and needs extra cable.
Gazz
PostPosted: 09:42 - 10 Feb 2018    Post subject: Reply with quote
Now that you mention it, there was a tiny bit of wire coming from the original but I don't know how you would be able to attach it to the new base.
doggone
PostPosted: 09:59 - 10 Feb 2018    Post subject: Reply with quote
Usually it's supposed to dig in enough as you tighten it up, you could slacken it off and wrap some copper wire round
bamt
PostPosted: 10:02 - 10 Feb 2018    Post subject: Reply with quote
But check the wire before shorting it to ground; it is possible (if it is coming from the car loom) that it is 12V for a mast base amplifier rather than a ground wire.
The last post was made 8 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 42 Kb
