| M.C |
 M.C Super Spammer
 Posted: 12:27 - 15 Feb 2017 Post subject: Oral health (gum disease/teeth grinding) stress related? |
Thought I'd start a new topic rather than hijacking the grinds my gears thread. So I've had gum disease for a while, the dentist said there was some bone loss but only advised flossing. It's receding upwards from the bottom of my lower gums (pic' attached) but seems to have stabilised.
The dentist mentioned stress as a cause, and as I also grind my teeth I was wondering if anyone had any practical solutions (I thought the dentist would prescribe antibiotics or something), and opinions of stress as a likely cause? I'm not doubting it however stress seems to be the go-to diagnose when medical professionals aren't really sure whats going on.
P.S. dunno if the attachment's working?  |
| stevo as b4 |
| UncleFester |
 UncleFester World Chat Champion
| waffles |
 waffles World Chat Champion
| grr666 |
 grr666 Super Spammer
 Posted: 10:21 - 16 Feb 2017 Post subject: |
Get a good electric toothbrush. Oral B ones are pretty decent. I have been under the dental hospital for the last
18 months and am still on a course of treatment undoing the damage of 25 years without a dentist visit because fear.
The first step for me was binning the manual brush, using a premium specialist toothpaste formulation to help treat
the inevitable gum disease. Electric toothbrushes definitely clean your teeth better and they weaken the calcium build
ups too giving the hygenist an easier job with the sonic mouth lance thingy. I've started using teepee interdental brushes
after each time I eat to poke out all the embedded debris, they are making a big difference.  ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| derillius24 |
 derillius24 Trackday Trickster
 Posted: 11:40 - 16 Feb 2017 Post subject: |
The issues you've mentioned have fairly complex mechanisms associated with them and both are often multi-factorial in their aetiology.
Clenching and grinding (bruxing) - collectively referred to as parafunctional habits - are very strongly associated with stress and anxiety. Often they'll rear their heads as you sleep and targeting the root cause of any psychosocial issues will likely be the only way to eradicate them - clearly easier said than done.
However, there are other measures you can take to prevent adding to the burden felt by your jaw muscles and the soft and hard tissues supporting your teeth: eat a soft diet intermittently (not mush, just an active avoidance of things like crusty bread and apples); avoid maximum mouth opening (catch yawns before you go full crocodile); and avoid chewing gum like the plague. Bite splints can be easily provided by clinicians if indicated by pain, or intra-oral signs your dentists will be able to pick up on.
Periodontal (gum) disease is also a complex condition. Unfortunately any damage done by periodontal disease (i.e. bone loss, soft tissue destruction around the tooth roots) is currently* irreversible but the disease can be stopped from progressing further with effective interventions. As mentioned, a good quality electric toothbrush used properly will be a good thing. Ask your dentist how to brush effectively and how to reach the bits you miss - do ask, virtually zero patients brush their teeth perfectly and if you're suffering from Periodontal disease you need to make sure you're completely eliminating plaque accumulation. Floss and inter-dental brushes? The supporting evidence that exists is of very low quality however anecdotally, regular use of either is a good thing.
Many things affect one's susceptibility to Periodontal disease.
Oral hygiene levels
Immunocompromise or immunosuppression
Poorly controlled Diabetes
Smoking (shoots the vascularity to the soft tissues supporting the teeth)
Stress (exacerbates almost every chronic condition known to man, including Cancer)
Genetics - this is the kicker as if you're genetically predisposed, you've potentially got a battle on your hands regardless of how hard you work at it.
^^ *this list is by no means exhaustive*
Parafunctional habits may also affect the periodontal tissues supporting your teeth by overburdening them so an inter-relationship may exist between the two.
Antibiotics for either of these conditions are generally not indicated
*there is lots of work being done on developing guided tissue regeneration techniques however we're likely a long way from this being common practice ____________________ CG125, CBF250, DRZ400-SM, Z750, Street Triple R, Tuono V4R |
| M.C |
 M.C Super Spammer
 Posted: 16:44 - 16 Feb 2017 Post subject: |
| UncleBFester wrote: | Not diabetic are you? |
I am not. However I have a few weird health things going on/bit of a medical mystery ATM.
| waffles wrote: | Do you grind your teeth at night? If so I think you can get gumshields to wear at night to try to stop that or at least minimise the impact of it. Look at the possible causes of stress in your life and see if there are some resolutions to them or at least establish a positive night routine that lets you sleep better. I subconsciously ground my teeth a few years back and my dentist commented on it, it was at the same time as I was struggling at work so don't rule out stress. I have since changed jobs and havent woken up with a sore jaw in quite some time.
The micro cleaner toothpick things are interdental brushes or tepe brushes. I use them and they are brilliant at getting in between teeth if you arent a fan of floss. You can buy packs of them at Boots for a few quid each and the different colours represent diffferent sizes depending on the gaps between your teeth. Or maybe use Cortisol mouthwash? |
Yeah I grind them at night. I was told about my teeth grinding years ago and that was during a period of unemployment, having recently had to leave my job it might have brought it back on (assuming it stopped ).
I use Corsodyl daily which helps with the bleeding gums. I used to use a Colgate gummy one but they stopped making it, and the main Cordosyl stains your teeth quite badly (well as bad as a diet of tea and coca cola).
| grr666 wrote: | Get a good electric toothbrush. Oral B ones are pretty decent. I have been under the dental hospital for the last
after each time I eat to poke out all the embedded debris, they are making a big difference.  |
I've fairly recently gone back to a manual toothbrush. Electric toothbrushes are good but I found charging them, buying replacement heads a pain. The one I had before last (an Oral B) took 18 hours to charge
| derillius24 wrote: | Smoking (shoots the vascularity to the soft tissues supporting the teeth) |
I don't smoke but I got asked that by the dentist. Is it a standard question or do they only ask people with rubbish yellowy teeth?
Thanks for the responses I will go to the dentist and get a gum shield made-up, I've been putting it off as during my last visit (a little over a year ago) he mentioned I might need a filling, and as it'll be my first I'm a little err... apprehensive.
That was also only my second visit since the age of twelve, but I think it's time to take better care of my teeth, Bodyguards photos have scared me into action. |
| Alpineandy |
 Alpineandy World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 17:21 - 18 Feb 2017 Post subject: |
I used to grind my teeth when I was extremely stressed.
I started biting my tongue to pieces instead. The logic being your tongue is made of meat and it grows back... teeth don't.
I eventually resolved the problem by working in a considerably less stressful job. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| M.C |
 M.C Super Spammer
There is a gap of 355 days between these two posts... |
| stephen_o |
 stephen_o Spanner Monkey
| stephen_o |
| M.C |
 M.C Super Spammer
 Posted: 01:53 - 09 Feb 2018 Post subject: |
| stephen_o wrote: | I grind my teeth due to stress, I have been self employed for the last 14 years, 11 of them in my current occupation with a massive amount of issues which there is no need for me to go into. I grind my teeth nearly constantly but things are not helped because my jaw is not 100% lined up and my two front top teeth buck slightly, my mouth is overcrowded as I haven't lost any teeth since childhood. I tend to grind on my right side and have worn the back teeth well down, also I have some gum receeding due to over exhuberant brushing.
For the grinding I have a prescribed gumshield which I wear at night if things are particularly bad but fortunately things are more settled at the moment than they have been.
The whole situation is further complicated though because I am allergic to fur, fluff, dust, lactose, fructose and a hole lot more and relevant to this post is SLS (Sodium Laurel Sulphate) which is found in all Colgate and many other toothpastes and soaps, shower gels - this shit is in things you wouldn't think of and guess what - I am allergic to that as well and it manifests itself along with any gut problems that flare - currently an almost daily occurance as stomach and intestinal bloating and mouth ulcers. As I write this I have a number of ulcers which have all flared this week some from last night after I ate a Tesco Free From Choco bar which contained Inulin.
The SLS in toothpaste flares me up within 20 minutes of brushing.
The solution for me is to use flouride and sls free toothpaste - a couple of kids ones in the supermarket or from holland and barrett and I cant use mouthwash. |
That's interesting actually, I have been feeling bloated after brushing my teeth and wondering why. The only thing's I used to use Sensodyne (because I liked the packaging (autist alert)), which's meant to be SLS free and I think I still had it then. I've been getting itchy after a bath though, and I used some soup when staying with a relative who has issues finding a suitable shower gel etc., and didn't have any itchiness afterwards. Something to look into
Also still gotta go back to the dentist  |
| stephen_o |
| Jewlio Rides Again LLB |
 Jewlio Rides Again LLB World Chat Champion
 Posted: 12:58 - 10 Feb 2018 Post subject: |
| M.C wrote: | | stephen_o wrote: | I grind my teeth due to stress, I have been self employed for the last 14 years, 11 of them in my current occupation with a massive amount of issues which there is no need for me to go into. I grind my teeth nearly constantly but things are not helped because my jaw is not 100% lined up and my two front top teeth buck slightly, my mouth is overcrowded as I haven't lost any teeth since childhood. I tend to grind on my right side and have worn the back teeth well down, also I have some gum receeding due to over exhuberant brushing.
You washed in soup? ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:59 - 10 Feb 2018 Post subject: |
| stephen_o wrote: | I grind my teeth due to stress, ... |
Although teeth grinding causes mechanical damage/wear, stress is actually influencing your imune system, in a way you are more prone to inflammation and blood composition imbalance (for instance loosing to much of vitamin D, which is responsible for healthy teeth, skin and other bits of your body).
Stress hormones do cause rheumatism, of all sorts, even arthritis. And, as mentioned before, smoking isn't really helping.
The ulcers are of bacteriological origin, not stress related at all and the diabetes type II (= you were not born with this) is not necessarily hereditary. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| kawashima |
 kawashima World Chat Champion
 Posted: 13:48 - 11 Feb 2018 Post subject: |
Not about grinding though..
I sometimes had mouth ulcers maybe due to biting my cheek inside/tongue. I made mouth piece but it wasn't good for me. I started
-taking vitaminB2/B6 tablets before sleeping
-brushing + flossing + water flosser (with hot water+tip with brush)
-training myself slightly opening my mouth with lips closed while asleep.
-taping my upper and lower lips with taping tape to limit max open.
-wear an mask and tape it on my face with taping tape.
Then I can keep my mouth clean and moist. (not to make your mouth dry while asleep is important imo) ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
| stephen_o |
| Ste |
 Ste Not Work Safe
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| J4mes |
 J4mes World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| stephen_o |
 Posted: 20:30 - 11 Feb 2018 Post subject: |
I had not heard of this, I fit the criteria both with my eyes and mouth, I have been complaining to my optician for the last few years and have suffered for many many years with sticky eyes but generally assumed it to be hay fever which affects me in the grass pollen season.
I will look into this more. Thanks ____________________ current scoot 2009 Yamaha YBR250 + Current Pootle 2013 Nissan Leaf |
| hellkat |
 hellkat Super Spammer
| FretGrinder |
 FretGrinder World Chat Champion
The last post was made 8 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
