What was your first bike!!
HappyDays
PostPosted: 14:24 - 25 Feb 2018    Post subject: What was your first bike!! Reply with quote
Well why not, show my age.
Honda MB5, that got me hooked Very Happy
https://www.youtube.com/watch?v=vQO1UEARG2A
Liquorice Torpedoe
trevor saxe-coburg-gotha
PostPosted: 14:32 - 25 Feb 2018    Post subject: Reply with quote
mkII escort
HappyDays
PostPosted: 14:38 - 25 Feb 2018    Post subject: Reply with quote
trevor saxe-coburg-gotha wrote:
mkII escort
Nice
https://www.youtube.com/watch?v=5GK5WqEO5tM
Liquorice Torpedoe
PostPosted: 16:45 - 25 Feb 2018    Post subject: Reply with quote
Honda P50 Embarassed
https://tse3.mm.bing.net/th?id=OIP.1arJNKkrcZqsmWwk_xa_vAHaFj&w=271&h=203&c=7&o=5&pid=1.7
^^^ Generic picture^^^ as I owned it way before digital cameras existed. Laughing
https://tse1.mm.bing.net/th?id=OIP.9nLlU__ftd22R8FDVqLHjQHaD3&w=300&h=156&c=7&o=5&pid=1.7
My first real bike at 17 years old. Yamaha YDS7 Wub
Teflon-Mike
tl;dr
PostPosted: 16:48 - 25 Feb 2018    Post subject: Reply with quote
https://i.pinimg.com/736x/1e/86/4d/1e864d8b7b0ef94680b67e3555f638a1--belt-drive-twists.jpg
Falling out of a shed clearance, when I was 11, I started pedaling it up and down the drive, and was told "If y'cun fix it, y'cun 'av it!" An hour later, having tipped some fresh petrol out of the lawn mower-can into it, and ripped off all the lights, and hence, inadvertantly the shorting 'kill' switch wire, it was a runner..... unfortunatley it wasn't a 'stoppa' causing much consternation when some-one discovered you cant 'stall' a twist and go, and even more when an older but not much wiser fellow, 'tutted' and promptly electroculted themselves trying to pull the spark-plug cap off!! HOURS of entertainment that 'ped provided!!!
https://www.scooterhelp.com/scooters/images/V9A1T.smalldoor.jpg
Same garage clearance unearthed one of these; A Vespa 90, unseremoniosely dumped after some-one had stoved in the 'fork' in a SMIDSY.
Learning thier leson with the Batavas Go-Go, they did NOT suggest if I could fix this one, I could have it.... but I did anyway! Finding a new fork that had at some-point been procured for it, and then used as a pipe-bender!?!?!? I set about trying to make it a go-er.... I got it running, again with a little fresh petrol and a little tinkering with wires... putting the replacement fork on proved a little more vexatiouse... I dont think I had two ball-bearings the same size! But it sort of looked like a skootah.. so I set about finding a front wheel for it.. which I eventually tracked down to my Grandad's wheel-barrow..... and things WERE looking promicing until there was an explosion of expletives from the shed, and a demand I STOP pigging about with stupid-skoota's, and FIX THE FRIGGING WHEEL-BARROW!
https://i.pinimg.com/564x/20/89/72/2089724a1ce0882a06c238e5ce35f808--barracuda--life.jpg
This is a BSA c15 'Baracuda'. I think the one I was given, in an attempt to keep me occupied, was a plain C15 with some Baracuda bits and other go-fast goodies... ~I was faithfuly promiced.... it had a glass-fibre tank, I do recall, and I was told a lumpy cam and 'big-valve' head.... which when lifted proved to be rather mangled by the high-crown High-Compression piston, also fitted, and probably groseely mis-timed, in an attempt to 'Cafe-Racer' it in the 250 L-Plate days..... Also told it was a perfect candidate for a competition 'Trials' chop... I had gone to Casablanca for the waters, rather!!!! It NEVER ran, but it WAS a real motor-bike.... ish! Sort of! If you squinted and used a LOT of imagination!
https://toastywithbeer.96.lt/images/pics/devils_bridge_e.jpg
Feeling guilty... but not very.. I was next bequithed another 'project' in one of these. A 1977 air-cooled, two-stroke twin, Yamaha RD250.... "Well, y'cun fix't'up fur y'16th" I was told.... by some-one who had sort of 'forgotten' that not only had 16 year olds been restricted to mopeds over a decade earlier, 17 year old learner's had been limited to 125's for almost half as long!
BUT!!! It was a proper motor-bike, and eventually IT RAN! Badly! Some-one had had daft ideas about tuning it, so when it did run, it only ran on one of its two cylinders, till it hit 6K rpm, then it went wherever it wanted, rather quickly!
SO! Concluding that 'Groan-upz-LIE' I decided to ignore them all! And I bought one of these:-
https://www.southwestmontesa.com/images/gal_248.jpg
A 1981 Montesa 248 competition trials bike. It had one 'day-light' MOT that had just expired when I got it, so dating the bike, and purchase to February 1985. It was a full 250, 'clubman' trials bike, and a little regulation digging had revealed I could ride it in competition the year I would turn 16.. and since I turned 16 much later that year... I DID!
Handing over a life-times savings from mowing lawns and stuff, I got it home and stunned the family expecting another 'project' cos it RAN! And was actually newer than my Grandad's car!
It was the my first 'Proppa' bike, as in it WAS a bike, AND it actually ran, AND I could actually ride the chuffing thing 'some-where'!
And THIRTY-ODD YEARS ON... I STILL have it!
And it's a 'project'!!!!!!! It has actually been hard used in clubman and later 'classic' competition, but right now, time has caught up with it, and it's been so hacked and bashed from original, it's a bit of a dilemah whether to 'restore', which to factory standard would probably be financially impractical if not physically impossible, or just 'renovate' to ONE of the guises it actually ran in over its competition career... and along the way? How many of the 'mods' I never got round to trying out might I work into the 'Project'... so its a hanging one..... Especially, as IF I ever go back to the sport, I am no old enough to run a modern 'banana-bike' in the old fogey class, and those fly-weight things are Soooooooo easy to ride in comparison! So why make life harder than I need?
https://www.sportbikerider.us/Pics41/1990-Kawasaki-AR125-192383.jpg
First 'Road-Bike', was one of them. A 1990 Kawasaki AR125, bought brand new, with my grant-cheque, cos with the launch of the Yamaha TZR125, they were offering a healthy discount on them, and I needed cheap and reliable wheels for a summer job.... so I ran it through uni for almost 3-years, while they sorted out the 'new' persuit-test.. or more precisely got some examiners who could do it! In between it being nicked, and the HP agreement running out, and getting my full-licence on it... JUST in time for Norwich Union to refuse insurance policies to any-one under 25! (Let alone some-one under 25 with three total loss theft claims on a brand new bike!!!).... But I still Had the Montesa...... oh, and another 'project-bike', a 1983 Honda CBX550 with snapped cam-chain, sat in the garage....... oh the errors of 'yoof'!
Irn-Bru
PostPosted: 17:02 - 25 Feb 2018    Post subject: Reply with quote
https://i.imgur.com/kcduX.jpg
Yamaha DT125RE Thumbs Up Did 85mph thanks to 2 stroke powah, and a few derestriction mods.
waffles
PostPosted: 18:13 - 25 Feb 2018    Post subject: Reply with quote
I had a crappy Chinese knockoff version of a dirtbike (a Shineray something 125) before coming to my senses and buying a Yamaha xt125x.
I don't have pictures of either of them unfortunately.
PostPosted: 18:21 - 25 Feb 2018    Post subject: Reply with quote
I had a H reg Honda NS125R in red. Not unlike this, but it had a black seat as the original red seat cover was torn, so I replaced it. A previous owner had resprayed the wheels black, as with this one.
https://i.ebayimg.com/00/s/NzUwWDEwMDA=/z/zVkAAOSwbYZXYVUJ/$_86.JPG
PostPosted: 18:26 - 25 Feb 2018    Post subject: Reply with quote
Picture off my Haynes manual.
https://www.bikepics.com/pics/2004/08/28/bikepics-202571-full.jpg
ThatDippyTwat
PostPosted: 18:45 - 25 Feb 2018    Post subject: Reply with quote
KX80 Big Wheel. Swapped not long afterwards for a KX500, muchos fun once you got used to it.
Road bike was a CB250N, raked out with 6" overs and a bit later, a 400 lump in it. Because I could, but certainly shouldn't have. No pictures because I'm an old bastid and CBA googling them.
PostPosted: 18:56 - 25 Feb 2018    Post subject: Reply with quote
2002 NSR125
https://mcn-images.bauersecure.com/upload/839/images/1752x1168/MNSR120033BA-01.jpg
It was restricted and 100% legit until I met some dodgy people from the internet. Shocked
thx1138
PostPosted: 19:19 - 25 Feb 2018    Post subject: Reply with quote
Suzuki DR 100
Kawasaki KMX 125
Suzuki TS 125
They were the first three that I had before, during and after getting bike license as a 19year old.
temeluchus
PostPosted: 19:37 - 25 Feb 2018    Post subject: Reply with quote
Kawasaki KH100
PostPosted: 20:39 - 25 Feb 2018    Post subject: Reply with quote
I'm here by mistake i.e I couldn't afford a car so my uncle said 'Why not have the old XL to get about on'.
Here it is moments after my first ride.
https://i.imgur.com/HfFyom5.jpg
Minging November evening..I'd not ridden a bike since trying a PW80 sometime in the 80s and sitting on a 1300 Zed.
I asked how to start it and about the gears...a while later I got back grinning like..well like we all did after out first ride on our first bike.
Took that photo and been smitten since.
I still don't own a car. Smile
TbirdX
PostPosted: 22:31 - 25 Feb 2018    Post subject: Reply with quote
TS100 Field bike
VFR800X - CFMoto 450MT - TTR250
Blah blah
PostPosted: 22:37 - 25 Feb 2018    Post subject: Reply with quote
KH100ex... loved it, did 75 while lying on the tank, white with red and blue stripes, and I could get into third doing burnouts !
Brilliant fun at 17 but it didn't stop me wanting an RG125 though...
stevo as b4
PostPosted: 00:21 - 26 Feb 2018    Post subject: Reply with quote
You've fucked this thread OP before it even started. You should have said 'what was your first road bike'
These lot won't differentiate between first legal road bike, and the moped they found down the park, the PW80 they went round the garden on, or the RM80 they beat all comet's on every Sunday at the MX track.
There's a hell of a difference between first two wheel experience or vehicle, and first bike on the road. And we've had plenty of what was your first bike threads before here.
Billy Balthorpe
PostPosted: 00:35 - 26 Feb 2018    Post subject: Reply with quote
12 years old and got myself a Honda C50 for £3 and a fishing reel. It didn't run which was the only reason me and my Dad managed to get my Mum to agree to me having it "Look love, it doesn't run, you know the lad likes engines and engineering and stuff, why not let him have it and take it apart, learn how it works". Cheers Dad!
A week later after stripping and re building the top end with no manual it was locked solid, "Go and buy a manual so you can set the valve timing up properly you idiot" was my Dads wise advice. Another week and it was rebuilt again and my old man was sat on it at the top of the drive and I pushed him down the incline. He banged it into gear and it fired and shot off down the drive, throttle stuck wide open and no brakes, he managed to fling it onto the front lawn rather than shoot out onto the road, gouging out a big strip of pristine grass, knocking down two rose bushes and putting a crack it the wall. It was the first time I heard him swear "F**k it off across the fields" he said to my beaming face when I ran down the drive. The only way I could slow it down was to put my hand over the carb inlet and the only way to stop the engine was to pull off a bare copper plug cap, petrol, sparks, God knows how I didn't set myself on fire or electrocute myself.
First road bike was a DT50M in 1980.
First "proper" bike was a Yamaha 350N YPVS.
M.O.B. Successfully taking the piss since 2014.
Billy Balthorpe
PostPosted: 00:36 - 26 Feb 2018    Post subject: Reply with quote
Sorry Stevo!
M.C
PostPosted: 01:01 - 26 Feb 2018    Post subject: Reply with quote
I still regret getting an XR instead of a DT Crying or Very sad
PostPosted: 11:11 - 26 Feb 2018    Post subject: Reply with quote
Tef, tef, tef.
You can only have ONE first bike...
Jeez. Brick Wall
AshWebster
PostPosted: 11:41 - 26 Feb 2018    Post subject: Reply with quote
CG125.
Failing that.. your Mum
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
RhynoCZ
PostPosted: 12:08 - 26 Feb 2018    Post subject: Reply with quote
What was the very first thread about this and where is it now?
Jewlio Rides Again LLB
PostPosted: 12:18 - 26 Feb 2018    Post subject: Reply with quote
Fucking Tef. Tit.
Mk2 RD125LC.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
The last post was made 8 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 135.71 Kb
