Securing bike without ground anchor
adengtg
PostPosted: 21:38 - 25 Feb 2018    Post subject: Securing bike without ground anchor Reply with quote
So, i need to secure my bike but as im in a rented property, i cant be concreting or drilling a proper ground anchor into the floor. it will be kept on a driveway at the front of the property as theres no access to the garden. the driveway has gravel and pavings tones and grass to one side.
I have a Pragmasis Protector 16mm and oxford monster disc lock to stop it being moved but at the moment it could still be picked up and put in a van or whatever. I thought of using a ground anchor that just screws into grass/dirt but that doesnt seem that secure.
Anybody have any suggestions of how to keep it safe?
rpsmith79
PostPosted: 21:46 - 25 Feb 2018    Post subject: Reply with quote
Large plant pot/planter + bag of cement/concrete + ground anchor = job done
PostPosted: 21:56 - 25 Feb 2018    Post subject: Reply with quote
If I were the property owner, I'd be less bothered by an unobtrusive ground anchor than a great big pot full of concrete that I could never get rid of.
If you fit a recessed flippy-up ground anchor you can just kick some gravel over it when you leave, get your deposit back, then get on with your life. What are they going to do if/when they find it? Sue you for adding facilities to their property?
adengtg
PostPosted: 22:03 - 25 Feb 2018    Post subject: Reply with quote
Fair enough, might try that. Will have a look for "stealthy" ground anchors and see what there is.
winz
PostPosted: 13:52 - 26 Feb 2018    Post subject: Reply with quote
I bought a Y shaped anchor for my driveway, landlord was ok with it because it can be filled in and you wouldn't know it was in there.
Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F
Freddyfruitba...
PostPosted: 14:16 - 26 Feb 2018    Post subject: Reply with quote
I wouldn't, because it would be the tenant's responsibility to shift it at the end of the tenancy, and if he didn't I'd be within my rights to deduct the cost of doing so from the tenant's deposit (probably hiring a handyman with a kango?)
They would't need to sue; they are entitled to have the property reinstated as it was at the outset, less fair wear and tear. Plenty of tenants will leave stuff behind which they consider 'adds value', but that doesn't cut it. Landlord would therefore be entitled simply to deduct the cost of anchor removal and making good; the kicker is that he would have no obligation to actually spend that money on doing the work, so he'd have every incentive to make a deposit deduction.
So by far the best solution would be to negotiate with the landlord and get him to agree (in writing); ie convince him that the anchor will be neat and unobtrusive, won't be in the way of any future non-biker tenants, and that you are indeed 'adding value' to his property.
owl
PostPosted: 14:27 - 26 Feb 2018    Post subject: Reply with quote
just ask, make it clear that it will be unobtrusive and like ffb says, get it in writing
https://i.imgur.com/SmbMrFa.jpg
Observation is the greatest source of wisdom.
MahatmaAndhi
PostPosted: 19:28 - 26 Feb 2018    Post subject: Reply with quote
I bought a Y-Anchor and dug a hole in the mud right next to the paving slabs. Put in post postcrete and put the Y-Anchor in. Within minutes, it was set and the postcrete grafted itself to the existing concrete from the paving slabs.
I own my property, so I'm not bothered in the long run, but you could just fill in the holes with mud and nobody would be any the wiser.
2008 Aprilia Sportcity 250
owl
PostPosted: 02:12 - 27 Feb 2018    Post subject: Reply with quote
Do those y anchors fill up with water?
PostPosted: 10:05 - 27 Feb 2018    Post subject: Reply with quote
I believe the idea is that you concrete around it, but leave the bottom of the Y clear to drain into a soil/gravel sump.
DrSnoosnoo
PostPosted: 10:55 - 27 Feb 2018    Post subject: Reply with quote
I may or may not have a Y anchor concreted in my shed/garage thing. I may or may not have never used it because nobody wants to nick my stuff anyway.
The last post was made 8 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 69.88 Kb
