| kramdra |
 kramdra World Chat Champion
 Posted: 00:11 - 01 Mar 2018 Post subject: Eye irritation from riding? |
Not had an eye test for about 16 years, never had any problems. My eyes have been irritated this week so went got them checked. Looked like I had a bit of dirt but it is a small bit of UV damage on right eye plus dry eyes. Im outside couple hours a day. I dont need and hate glasses.
When riding air leaks around visor and into my eyes. Often feel dirt hit me. I need to stop this, but has happened with every lid. Opening the chin vent can help change the airflow but not much better. Any ideas?
Gave me eye drops and told me to wear uv protection - trying to sell glasses, for outside. Otherwise eyes are perfect  |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| NJD |
 NJD World Chat Champion
 Posted: 01:40 - 01 Mar 2018 Post subject: |
| kramdra wrote: | Any ideas? |
Aye, use eye drops. Tots srs.
Air flow into the eyes is a huge irritant and while not a problem specific to motorbike riders its probably made worse because of taking the brunt of air flow through vents and slightly open visors etc.
Interestingly the guy I spoke to at the opticians (main eye test man) said that in order to get full use of my contacts and prevent blurry vision closing all the vents on my helmet and keeping the visor shut is the best option. This, of course, is a no-brainer problem creator as is wearing glasses when in cold weather because every pin-lock fogs eventually thus, as I've experienced, riding in cold weather varies and some days vision is A O.K and others blury, out of nowhere. You, of course, are convinced that you don't need glasses and don't, I assume, wear contacts so while my experience isn't directly related to yours I write it because blury and reduced vision mid-ride is not a fun thing to experience and so is better to prevent than think its not an issue.
Keep an eye out for:
1) feelings of dryness, grittiness or soreness that get worse throughout the day
2) burning and red eyes
3) eyelids that stick together when you wake up
4) temporarily blurred vision, which usually improves when you blink
As per NHS advice. No. 2 and No. 3 are probably worth noting if occurs because could be blepharitis or, in the summer, conjunctivitis (also for many other reasons). I say keep an eye out for (no pun intended) because if occur is probably the point regular eye care is more needed.
I'd visit someone else, though, just to be sure because even professionals make mistakes: a trained optician putting two contact lenses in my eye because, "I can't see the one you've just put in.. I think it's fallen out," for example. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 07:48 - 01 Mar 2018 Post subject: |
Could be sweat trickling into your eyes. Sometimes get the same problem causing watering. Recently had an eye test and all perfect; that was there suggestion. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| Polarbear |
 Polarbear Super Spammer
| Rogerborg |
 Rogerborg nimbA
| stinkwheel |
 Posted: 10:18 - 01 Mar 2018 Post subject: |
Yes, I get sore eyes on the bike too.
Pretty much any sort of glasses will stop the harmful, short UV wavelengths. I used to work with them in a lab and the difficulty was finding something they WOULD pass through, we had to use special and ludicrously expensive crystal test tubes for UV spectrophotometry. Your visor will block most of them.
UV can cause irritation but if you're like me, part of it is wind blast drying the surface out, part of it is damage to the cornea/tear film by small particles.
I awlays wear some sort of protective glasses under my helmet. Oakley wrap-arounds for preference, the lenses are optically perfect. In fairness though, I'm a cheap arse so I mostly wear JTS stealth protective glasses. which I like because they are a close fit and don't have a seperate "bridge" that goes on your nose, something that annoys the crap out of me. Available in a wide choice of colours.
I also use eye drops on occasion. I look for over the counter ones containing hyaluronic acid, this will help to repair the damaged tear film. The tear film is much more complex than just salty water. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kgm |
 kgm World Chat Champion
| stinkwheel |
| kramdra |
 Posted: 14:38 - 01 Mar 2018 Post subject: |
It was specsavers. I had a proper eye test, including eye pressure, photo of the back, sight test, all perfect, and exam of the eye surface - which was not. I do not need glasses for seeing. I only need something to protect my eyes from UV - glasses, visor, safety squints. Was impressed by the eye test, they check a lot more than when I last went.
In my opinion, prevent this stream of dusty air going around the visor, although he dismissed that / road dust as being a mere annoyance - there are no scratches or signs of foreign bodies on my eye surface.
Cant remember which he said I have.
https://en.wikipedia.org/wiki/Pinguecula
https://en.wikipedia.org/wiki/Pterygium_(conjunctiva)
Suggesting I wear glasses under lid while riding? that does not seem ideal as they will fog up. |
| stephen_o |
 stephen_o Spanner Monkey
| stinkwheel |
| Rogerborg |
 Rogerborg nimbA
| MCN |
 MCN Super Spammer
| AshWebster |
 AshWebster Brolly Dolly
| NJD |
| M.C |
 M.C Super Spammer
| kramdra |
| doggone |
 doggone World Chat Champion
| stephen_o |
| kramdra |
| M.C |
 M.C Super Spammer
| kramdra |
| P.addy |
 P.addy Red Rocket
| Jewlio Rides Again LLB |
 Jewlio Rides Again LLB World Chat Champion
 Posted: 23:18 - 03 Mar 2018 Post subject: |
Riding with your eyes closed will help.  ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
The last post was made 8 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
