Hive heating thing....
mudcow007
PostPosted: 16:02 - 04 Mar 2018    Post subject: Hive heating thing.... Reply with quote
My boiler is old school, as in you need to go to it to turn it on, an has a mechanical timer on the front.
The mrs wants the heating to come on automatically when its cold etc....
So, after I bought the Hive light bulbs with the little hub etc, I quite fancy connecting the boiler up too, so bought a Hive Active Heating Multizone....
I don't own any other heating kit from Hive. Will the thing I bought work without buying any other Hive heating "kit".
The reason I'm worried is that on the side of the box (that i seen after opening everything) it states
In order to have Hive Multizone you will have need to purchase Hive Active Heating™ which contains a thermostat, receiver and Hub. For each additional Hive Multizone kit you will receive an additional thermostat and receiver.
All i want is a wifi thermostat that's controllable from a web app, my house is tiny so not bothered about "mulitple zones etc"....did I buy the wrong thing, or can i just wire this up an it should just work
Ebbs73
PostPosted: 17:39 - 04 Mar 2018    Post subject: Reply with quote
It looks like you've bought the wrong thing .
Send it back and buy one designed for your system , is it a combi , heat only ?
Lots of other options but you've got the over hives so I guess you'd follow suit .
Chris
dodsi
Dirty Carny
PostPosted: 12:52 - 05 Mar 2018    Post subject: Reply with quote
Disclaimer: I have a nest (same idea - just made by google) so the following is true of that.
The 'Hub' is the thing that will plug into your boiler and work as an access point for all the other kit. With this I got a wireless thermostat and separately I bought the 'Protect' which is a connected smoke/CO detector, this just links to the 'Hub' Any additional 'Works with...' kit will also just connect to the same Hub.
2Hondas
PostPosted: 18:26 - 05 Mar 2018    Post subject: Reply with quote
Nest Protect doesn't connect to the thermostat in any way other than via the cloud. In your house there is no connection between the heat link and your Nest Protect.
The Boiler is wired to the Nest Heat Link which then connects to the Nest Thermostat wirelessly.
The Nest Thermostat connects to your Wifi which allows it to sync to the Nest cloud service, which you can monitor remotely via the Nest app.
The Nest Protect Smoke/CO detector connects to your Wifi which allows it to sync to the Nest cloud service, allowing you to monitor it remotely via the Nest app.
Current - 2010 Kawasaki ER-6n - Green
Previous - 2000 Honda CB600F Hornet - Yellow
Previous - 2007 Yamaha YBR125 -Blue
panrider_uk
PostPosted: 21:30 - 05 Mar 2018    Post subject: Reply with quote
If your boiler can take a normal two wire thermostat then you can use something like the Salus IT-500. Fairy low cost and lets you control the heat from the portable thermostat, app via wireless or app via internet.
There are no subscription costs for this.
almostthere
PostPosted: 22:49 - 05 Mar 2018    Post subject: Reply with quote
If your boilers old skool you wont have any zones,
send the multizone back and get a nest, honeywell or heatmiser neostat and hub,
why pay a subscription to BG when you dont need to?
Beer, It's the reason I get up every afternoon
www.mfairco.uk
iooi
PostPosted: 16:17 - 06 Mar 2018    Post subject: Reply with quote
You do not have to have a subscription. You can buy outright. Time it right and you can end up paying 50% less than retail price on Amazon.
OP might just be better getting a new boiler. Instead of fancy kit to turn it on & off.
almostthere
PostPosted: 19:49 - 06 Mar 2018    Post subject: Reply with quote
you buy it outright then pay £9.00 a month to use it
www.mfairco.uk
iooi
PostPosted: 21:29 - 06 Mar 2018    Post subject: Reply with quote
No you don't......
https://www.hivehome.com
https://www.britishgas.co.uk/smart-home/hive.html
I Paid £99.00 thanks to black Friday offer, which included BG fitting it Smile
No ongoing plan, works Ok. Lets face it. It's only a thermostat that you can control via a app...
As to saving £££. Mmm. Not happening here. Same cost as the old stat. Despite the ability to tweak temps as required.
mudcow007
PostPosted: 23:22 - 06 Mar 2018    Post subject: Reply with quote
Sorry no updates yet, I have spoken to a few people who have said what I have bought should just work.
I have opened all the packaging etc now so doubt Amazon would accept a return anyways Sad
If it doesnt work I will sling it onto eBay.
Now i need to figure out how to remove the mechanical clock an replace it with the Hive "magic box"
no subscriptions when you buy the kit, its only on subscription if you sign up for one - i think
t121anf
PostPosted: 09:56 - 07 Mar 2018    Post subject: Reply with quote
Do you not leave it in place and set it to always on? That's my plan for my Nest on a Baxi boiler.
LustyLew
PostPosted: 11:05 - 07 Mar 2018    Post subject: Reply with quote
That's exactly what I did with mine. I've got an Ideal Independent C24 combi. Set the 24h segment timer to always on.
Removed the existing wireless thermostat receiver and replaced with the hive receiver. Two wires, that was it.
I very much doubt it'll save me huge amounts of cash. But it does mean I can customise my weekly timings without having to faff with the segment timer on a Friday night.
Freddyfruitba...
PostPosted: 11:47 - 07 Mar 2018    Post subject: Reply with quote
They probably will actually; though you might well not get back the full purchase price if the product is obviously opened. (Amazon do have 'seconds' sales where they flog off returns like this).
Definitely worth a look anyway - just complete their online returns process, explain your situation honestly, and see what they come up with.
bladerunner
PostPosted: 00:14 - 08 Mar 2018    Post subject: Reply with quote
you should be ok with multi zone...you'll just be using 1 zone. You can use multi zone if you later wish to fit servo radiator valves with separate room temps such as a spare room. I've got the Salus as well rather than nest but you basic setup is leave your boiler on 24Hrs and the nest thermostat decides when to turn it on/off depending on room temps and times you select. The hub connection means you can still work it via remote or your phone if the internet is down ( local network) and cloud based connection so you can change/read home temps when away. Id expect the extra parts it says needed are for setting up zone 2 etc so you should be good to go. on my boiler connections I needed 3 wires and a jumper to power the boiler remote AND the thermostat connections. Worth checking if its mains output or DC output if your fitting it yourself!
t121anf
PostPosted: 00:15 - 08 Mar 2018    Post subject: Reply with quote
Installed the nest tonight, as said mechanical timer in always on. Scheduling set via nest.
mudcow007
PostPosted: 00:51 - 08 Mar 2018    Post subject: Reply with quote
Hive replied tonight to my email - by phone?! an said the kit I have bought will work because I already have a hub Thumbs Up
natefz6
PostPosted: 15:41 - 09 Mar 2018    Post subject: Reply with quote
Interesting... I have Hive v1 and wanted to upgrade to hive V2 which I think is just a thermostat change from what I can see. When looking though I couldn't find the upgrade pack anymore just multizone thermostat. I wonder if I could just buy one and attach to my existing hub.
"no I didn't steal it that's just the way I ride"
mudcow007
PostPosted: 23:08 - 11 Mar 2018    Post subject: Reply with quote
Mine says it doesn't support V1 hubs?
natefz6
PostPosted: 13:35 - 12 Mar 2018    Post subject: Reply with quote
bah! ok back to the drawing board.
The last post was made 8 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 103.81 Kb
