Poor spray job
Bomberman
PostPosted: 16:05 - 12 Mar 2005    Post subject: Poor spray job Reply with quote
Hiya,
Well, as I posted elsewhere, I slid down the road on my bike last week Thumbs Down Sad Problems,problems most of which appear solved now but...
The previous owner spray painted it matt black, almost certainly to cover previous crash damage. Crashing caused this paint to sort of bubble up and flake off in areas, apparently a crappy job. What I want to know is how do I get the rest off? Its blue underneath and I'd quite like to see it Very Happy but if that isn't possiblw what's my next step? Do I need to respray it? If so can I do that myself?
Cheers Thumbs Up
mchaggis
PostPosted: 20:41 - 12 Mar 2005    Post subject: Reply with quote
Brake fluid takes paint off a treat! I doubt you'll be able to strip it with solvents without taking off all the layers. I'd say you'd want to use solvents or wet and dry (fine sandpaper) to rub it back to the metal and smooth it. Then you'd want at least one primer coat, then several layers of blue, sanding each one after leaving it to dry. Eventually over the lot you'd want a layer or few of lacquer type stuff, I'm not sure what it might call itself.
Please don't just blindly follow my instructions, I've not had to respray anything yet so haven't done it before. You probably should be able to do a decent respray job yourself, getting it professionally done costs the earth from all accounts. Confused
Without knowing what bike it is, if it's been ratted before, then it's tempting just to say rat it again. Matt black all the way. Thumbs Up Smile
Here's a basic Halfords how to. Whether it's really right or not is anyone's guess.
https://www.halfords.com/268.asp
I must not be a troll...
Mmmm, Guinness
ZRX61
Victor Meldrew
PostPosted: 16:34 - 13 Mar 2005    Post subject: Reply with quote
Do NOT!! use fucking brake fluid to remove paint Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
The only sensible thing you actually posted....
mchaggis
PostPosted: 16:43 - 13 Mar 2005    Post subject: Reply with quote
Ever heard of sarcasm?
Feel free to post ideas of your own... Rolling Eyes
Mmmm, Guinness
instigator
PostPosted: 18:32 - 13 Mar 2005    Post subject: Reply with quote
Although I detected your sarcasm haggis, you might want to put in a smilie..... Rolling Eyes Some people do actually take stuff for gospel as soon as they read it, believe it or not Smile
Bomberman
PostPosted: 00:56 - 16 Mar 2005    Post subject: Reply with quote
Hmm, thanks for the replies. Well, the one anyway Wink
I was actually more refering to the fairings to be honest. I'm rather afraid that brake fluid may be just a little too harsh? Wink The worry that I have, is that if I just primer over the current rat black it may eventually just come off when the black starts to fall off again Confused So how to get the bodge job off?
On the rat bike issue, I discovered (a while ago now) that a previous owner had replaced the hinges on the lower fairing with a pair of actual door hinges Very Happy I was impressed at the ingenuity (or laziness) shown by this Very Happy
Oh, finally, what's best to repair a crack in fairing?
Cheers Thumbs Up
Frost
PostPosted: 03:28 - 16 Mar 2005    Post subject: Reply with quote
Best crack filler is fiberglass resin.
If you do spray over the bike then there is no need to sand ALL of the black off. so long as it's all rough enough for the paint to stick, and smooth enough thats theirs no imperfections. Just sand it down with quite rough sand paper (120 grit) and make sure you are rid of all bubbling and imperfections (use a courser grit if neccicary, especially for sanding off excess fireglass) once its all as smooth as you can get it, sand it down with 400 grit.
Spray all the panels with primer sanding it down with 1200+ grit to keep it smooth.
Once thats all done and dry spray it the colour you want (gloss black?) sanding betwean coats.
You can laquer the panels if you like, but unless it's a very nice looking expensive bike i wouldnt bother.
Kaben
PostPosted: 13:57 - 16 Mar 2005    Post subject: Reply with quote
You should sand it back with 600 grit, then move onto 1000 or wet n dry paper. Remove the majority of the black paint (you dont have to worry about little bits here and there that hugging the surface below, just make sure that there are no heavy layers of paint, or loose surfaces). It is important to make the surface as smooth as possible before priming, and you should prime with at least two coats of whatever colour primer you are using. Sand teh primer back with 1200 between the coats lightly to remove any fine bumps. Allow a couple of hours for the primer to cure, then begin to spray your topcoat.
Im guessing you will be using halfords type spray cans, so hold these about 10-12 inches from the surface, and start spraying before you hit the leading edge of the fairing, and stop after you leave the trailing end (this insures edges are covered too) Do this is horizontal lines slightly overlapping eachother. 1st line going from left to right, next right to left etc etc.
After you have finished the first coat, leave for at least 3 hours, and then lightely sand it back with 1200 again. repeat this process 2 or 3 times (more the better, but can get expensive)to get an even coat.
When finished, leave teh fairing overnight to cure, and then next day gently rub back the top coat before spray laquering. Laquer is aplied in the same way as the spray paint, including light rubbing back (except for last coat) 3 layers of laquer should be the minimum you use to stop it looking bobbly. let it dry for about two hourz, then polish with a damp rag HARD. this will bring up a shine and also eliminate teh bobbles which can sometimes give paint jobs a "leathery" look. If u have an electric buffer, this is even better. Leave the whole fairing for another full 24 hours before fitting it to the bike, and you will have a deep, glossy, durable paintjob that will look almost as good as a factory finish Razz ENJOY.
(Oh and do it all inside a well ventilated area. If you do it outside, the wind will blow the paint droplets and you will get uneven coverage. I know it sounds like a long process, but it is well worth it to have a decent paint job( leave as much time as you can spare between coats and it will be even better)........especially if you are thinking of selling it any time soon Mr. Green )
Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/
ZRX61
Victor Meldrew
PostPosted: 14:20 - 16 Mar 2005    Post subject: Reply with quote
What? & spoil all the fucked up advice he's been getting since my first post? Rolling Eyes I've never seen such total bollocks talked about how to paint bike parts...
The best filler for cracked FIBREGLASS fairings is fiberglass resin.... Ya wouldn't want to use it on ABS fairings etc, I won't even get into the rest of the bullshit advice.... but thats the usual standard for this forum when it comes to paint advice...
Kaben
PostPosted: 14:29 - 16 Mar 2005    Post subject: Reply with quote
whats wrong with the paintjob advice??
Bomberman
PostPosted: 15:16 - 16 Mar 2005    Post subject: Reply with quote
So you'll just repeatedly post "you are muppets, you don't know what you're talking about". Well thanks for that, but until you actually start saying where the advice goes wrong, you aren't much use to me or anybody else.
No offence.
And thanks to all the other posters Thumbs Up especially Kaben for taking the time with that one Very Happy
Oooh, I knew I had another Q. It's a small bike, how many cans will I need? Just for the fairings atm. Pic below Smile
Kaben
PostPosted: 15:21 - 16 Mar 2005    Post subject: Reply with quote
the steps i have posted i have used on a number of my friends panels, and also on car panels and door etc (but generally using a charged spray gun rather than halfords spray paints) The method is the same, just make sure you take your time, or you will end up with a shoddy finish.
It is also important to sand lightely between coats, or the following coats will have nothing to "bite" onto........leading to peeling.
hope the respray goes well mate, post some pics on here on you are done Very Happy
ZRX61
Victor Meldrew
PostPosted: 14:14 - 17 Mar 2005    Post subject: Reply with quote
No offence.
Try using the *search*....
Kaben wrote:
It is also important to sand lightely between coats, or the following coats will have nothing to "bite" onto.........
An example of the total bollocks.... Rolling Eyes
Kaben
PostPosted: 14:48 - 17 Mar 2005    Post subject: Reply with quote
have you ever sprayed anything?!! its called Keying! you sand lightely with very fine grit, and it removes imperfections as well as giving something for the next coat to bind to.
It is important, otherwise you get the paint peeling that is the problem in the first place, or little bumps from dust/hair etc particals that stick to the fresh surface.
I think it is you sir who is talking absolute bollocks!
Go get your finger paints out, then use them to lube your fingers and shove them up your arse
ZRX61
Victor Meldrew
PostPosted: 01:24 - 18 Mar 2005    Post subject: Reply with quote
Evidently a LOT more than you have ya pillock, including vintage RR's & several Supermarine Spitfires, P51 Mustangs & more bikes & cars than I can remember. You do NOT need to sand between every fucking coat. If ya get a bit of dust ya just nib it off the surface with a bit of 600grit, NO need to do the entire bloody paint job.
The *next coat* will bind with the paint thats already on there WITHOUT resorting to sanding the fucking part down. Ya normally spray the sealer, the colour & then the clear coats without ONCE sanding between ANY of the coats. Go get a clue sometime.
Kaben
PostPosted: 04:38 - 18 Mar 2005    Post subject: Reply with quote
im am not saying that you take it back to primer each time! just a gentle rub. When using charged spray guns (which i should bloody hope you used for a fecking spitfire or vintage machine!) you will not need to bother with keying, as that is the purpose of the charge, as well as to give an even coverage.
However it would seem to me that halfords type spraypaints are more the order of the day here, and these DO require keying, otherwise the paint will settle into individual layers, making the paint work far less durable, and leaving it open to bubbling at a far earlier stage.
My heart bleeds for all the vintage machines and spitfires you have worked on! You cannot seriously hope for a good finish with out once gently rubbing back between coats? thats just shoddy work, even with a spray gun. You should take pride in working on such historical machines and DO IT PROPERLY
Kaben
PostPosted: 04:54 - 18 Mar 2005    Post subject: Reply with quote
i dont want this to turn into a flame war, we obviously just have completely different approaches to getting a decent finish upon a surface.
I apologise for my previous posts being so ratty, am just in hyper tense mode as my dissitation is due tomorrow at 4 and im nowhere near finished yet Shocked
i can agree with you that you dont HAVE to sand back every coat, but i am a perfectionist and want a perfect glossy finish when i respray things. Gently Sanding back on laquer coats however does give a much deeper shine imo.
Also if you wet the surface of the object and use an electric buffer to buff in some liquid laquer polish (G30 i think the stuff i use is called) you get an Uber deep shine that is far harder than spray laquer alone.
Again sorry for bein rude, and sorry bomberman for hijacking your thread and turning it into a rant about the correct way to respray a fairing lol Laughing hopefully you have more of an idea on how to go about it anyway Wink
Back to the dissitation now.....*sigh*
ZRX61
Victor Meldrew
PostPosted: 05:30 - 18 Mar 2005    Post subject: Reply with quote
They win prizes at Pebble Beach etc & sell for top $$ at Barrett Jackson....Guess I must be doing something right....
Hex
Party Boy
PostPosted: 08:47 - 18 Mar 2005    Post subject: Reply with quote
ZRX61 is right, in a paint shop you will never rub between coats. As he said the primer goes on, colour then clear coats.
If your doing concours some will flatten the paint, but this is actually more to do with reveling MINOR depth differences and ensuring that the paint is totally flat and other bollocks which really dont float my boat and imo is a lot of work for VERY LITTLE extra gain. Though with concours stuff I understand why its done.
The bit about nipping out any dust etc is correct as well, you wouldn't lightly sand to get rid of such things and also the paint doesn't need to be keyed between coats and its nothing to do with using a charged spray gun.
The advice you gave for general home painting is a good start for most, I would probably suggest something very similar for people who never paint anything. Just never confuse home painting with how its really done.
Either way, each to their own people. Laughing
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Bomberman
PostPosted: 09:57 - 18 Mar 2005    Post subject: Reply with quote
Heh, no wories mate Very Happy Using a kind of mixture of the above posts I've got it just about done, and it looks pretty sweet to me so far Thumbs Up Lacquer goes on today and then I shall post some pics when she's all back together.
One last Q. though. I need my bike back, but I want to do some detailing at a later date (next few days). Would it be OK to laquer up and finish and then spray paint on the finished article later?
Again, thanks to all for the advice Thumbs Up
Oh and good luck on your dissertation Kaben Thumbs Up By doing a dual degree, I've managed to avoid that nightmare Wink
Kaben
PostPosted: 12:45 - 18 Mar 2005    Post subject: Reply with quote
Hex i was taught to spray paint by a guy that runs a custom auto respray shop in Exeter. He charges alot for his work, and pretty much always rubs between coats. I guess it has something to do with the quality of the finish you are after. Or perhaps he just has an extremely anal approach and this has rubbed off on me as he taught me.
Hope the finished article come out great bomberman. As for the detailing after laquering, id again say clean it thoroughly before attempting to cover over the laquer. and if its a large area (such as big flames.....god forbid) then you will want to lightely sand the area. Small lines will not need this as you dont need a consistent finish over a wide area. You will need to laquer over the top again though. a number of coats will be needed to remove ridging caused by the new layer of detailing paint.
good luck buddy, post some pics when it is finished. Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 14:21 - 18 Mar 2005    Post subject: Reply with quote
Kaben wrote:
perhaps he just has an extremely anal approach...
Thats putting it mildly.... Laughing How much does he charge for a complete? I start at $10k for a single colour complete (thats for a car, planes are more, MUCH more).
The alternative is to lay out the custom stuff before ya spray the colour & that way it all ends up at the same level before the clear goes on....
Kaben
PostPosted: 17:33 - 18 Mar 2005    Post subject: Reply with quote
Well he charged £8K for an x-reg mini to be resprayed with a single color metallic finish, but with bonnet stripes painted on rather than as a transfer, and mini cooper detailing along the sides.
He also recently did a Ford gran tourino in the Starsky and hutch paintjob and got well over 12k for it. Maybe he's a little over priced, but theres not much competition in the south west.
Yeah but he is talking about detailing after spraying the colour. would be better if you could do teh detailing at the same time bomberman, but seeing as you need your bike back, doing it after is fine Smile
Bomberman
PostPosted: 19:28 - 18 Mar 2005    Post subject: Reply with quote
A lot of money to be sure, but one hell of a fine looking motor Very Happy
As for my experience....
For reference, I give you the original;
https://www.thebdaman.f2s.com/Bike%20Stuff/TZRforweb.gif
So it begins. Sanding down is done, and primer applied...
https://www.thebdaman.f2s.com/Bikeproject/OneCoatPrimerforweb.jpg
Hmm. Note to self. Halfords use lighting that radically alters the colours you see inside their store. This was bright yellow (I'm not kidding) when I bought it. It now appears bright orange. Still, we shall plug on.
https://www.thebdaman.f2s.com/Bikeproject/Fairoutforweb.jpg
Due to my earlier discovery that Halfords lighting is shoddy, I took many cans outside to check to see what colour they actually were this time. The staff were confused by me wanting to leave with their paint without paying but were amiable Thumbs Up I picked quite a virulent shade in the end, its Ford Daytona Yellow in case anyone likes it Wink Such a nice day today too, so I put them outside to help dry faster, allowing me to get more lacquer on. Four layers in fact Very Happy Meh, I have time atm Very Happy
Without further ado though, I give you the completed article. Points of note;
I know I haven't done the tank yet, but I only filled up a couple of days ago and don't want to decant a full tank out Razz
I also haven't done the mudguard. It's drying now and I'll add the pics tomorrow Thumbs Up
The gold exhaust can. It arrived yesterday and the previous owner did it, not me. However, i quite like it now Very Happy
https://www.thebdaman.f2s.com/Bikeproject/fullfairsideforweb.jpg
https://www.thebdaman.f2s.com/Bikeproject/fullfairrightforweb.jpg
I have neglected to include the pictures I took of my face when I discovered how unforgiving Simoniz can be if you put it on areas that aren't ready for it yet Very Happy
Anyhoo, there you go. Until the pics with mudguard. Opinions?
Looking at the pics, they appear horribly aliased and a bit poor. I've had to resize for both size and size Razz and it hurt them a bit. Sorry about that Very Happy
Oh yeah, and the wheels are to be painted soon too Very Happy
Kaben
PostPosted: 13:49 - 19 Mar 2005    Post subject: Reply with quote
definitely looks better than the matt black mate, good job Thumbs Up
The last post was made 21 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 147.41 Kb
