Re waterproofing textiles
Davemc37
PostPosted: 14:59 - 28 Mar 2018    Post subject: Re waterproofing textiles Reply with quote
Over the last two days I’ve started to feel a little dampness penetrating my previously watertight alpine stars textile suit. The damn things are also filthy after riding through all but 6 days of the winter.
Question is , is there anywhere in London or Essex where I can get the textile jacket and trousers cleaned and re waterproofed and any idea of the cost.
Many thanks.
born again biker with a mere 23 year gap between bikes.
Powderhead
PostPosted: 15:18 - 28 Mar 2018    Post subject: Re: Re waterproofing textiles Reply with quote
My Alpinestars Andes textiles have never been 100% waterproof Sad
10/10 would not recommend.
The general advice seems to suggest washing textiles with Nikwax Tech Wash, and then re-waterproofing them with Nikwax TX.Direct Wash-In. You can pick up a twin-pack with a litre of both products in it for about £10.
Although, having said that, I've used both of them a few times, followed by a metric fvckton of TX.Direct Spray-On, and I can't honestly say it made a noticeable difference Sad
Interested in hearing what others have to say, but I suspect the best solution is simply "all Gore-Tex everything".
"Now at inspector level!"
colink98
PostPosted: 15:25 - 28 Mar 2018    Post subject: Reply with quote
two days of riding at speed through walls of spray from cars and trucks leads me to accept its a losing battle to try and keep dry.
Ride it like you stole it.
Freddyfruitba...
PostPosted: 15:30 - 28 Mar 2018    Post subject: Re: Re waterproofing textiles Reply with quote
People reckon that the actual presence of dirt and clogging of the fibres causes water leakage (regardless of the waterproofer used)
Landy10
PostPosted: 15:34 - 28 Mar 2018    Post subject: Re: Re waterproofing textiles Reply with quote
Many thanks.
Nikwax tech was and then the wash in stuff in the washing machine. you do have to follow the instructions to the letter and clean the soap drawer etc.
I do my hein gericke jacket every year with it and it stays waterproof having ridden through some torrential downpours here in scotland on a naked bike
Powderhead
PostPosted: 15:36 - 28 Mar 2018    Post subject: Re: Re waterproofing textiles Reply with quote
I wonder how well it would re-waterproof your jacket if/when it eventually starts to leak Thinking
It doesn't work for me. I'm buying Rukka next time Folded arms
ThatDippyTwat
PostPosted: 15:47 - 28 Mar 2018    Post subject: Reply with quote
Also available - Fabsil gold. Had decent results with both, and I also use the Fabsil on tents etc.
kgm
PostPosted: 18:32 - 28 Mar 2018    Post subject: Reply with quote
As above Nikwax tech wash. Definitely clean the soap drawer and was at max 30 degrees. Then do a second wash using the Nikwax water proofing stuff. DO NOT tumble dry.
Any thermal liners can be washed normally
el_oso
PostPosted: 19:55 - 28 Mar 2018    Post subject: Reply with quote
kgm wrote:
DO NOT tumble dry.
Not necessarily correct. Some of the proofers work better with a low tumble dry, just check the label in the jacket/trousers.
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 20:03 - 28 Mar 2018    Post subject: Reply with quote
All that, then when it still leaks, eBay or bin it and buy a new or used Gore Textm lined jacket.
stephen_o
PostPosted: 20:59 - 28 Mar 2018    Post subject: Reply with quote
I reproofed my textiles with this stuff a few years ago, I did keep the water at bay for an hour or so in torrential rain but eventually it does let through. I now wear waterproof overleggings over the trousers so that the crotch says dry.
The textiles need to go this year due to weight loss and age and will be looking for something better.
current scoot 2009 Yamaha YBR250 + Current Pootle 2013 Nissan Leaf
Wonko The Sane
PostPosted: 18:42 - 31 Mar 2018    Post subject: Re: Re waterproofing textiles Reply with quote
I thought it didn't work having swilled in the bath, washing machine worked a treat
Powderhead
PostPosted: 18:45 - 31 Mar 2018    Post subject: Re: Re waterproofing textiles Reply with quote
Washing machine has never worked for me. Maybe I need to try swilling it in the bath Laughing
waffles
PostPosted: 19:57 - 31 Mar 2018    Post subject: Reply with quote
Nikwax is pretty good, I use it on my waterproof walking jacket reasonably regularly and it hasn't let me down yet. Follow the instructions carefully and do both washes; one gets it clean and the other re-waterproofs it.
Bikeless
PostPosted: 21:00 - 31 Mar 2018    Post subject: Reply with quote
Waterproofs are waterproof,if they're not no amount of nikwax or any other product that reinstates the DWR coating will make them,nikwax just makes the surface bead water off so the fabric is still breathable.
Skudd
PostPosted: 20:42 - 02 Apr 2018    Post subject: Reply with quote
I've never found anything waterproof once subjected to winter rain at motorway speeds.
Kawasaki Jimbo
PostPosted: 21:07 - 02 Apr 2018    Post subject: Reply with quote
I use "textiles" but expect them to be shower proof only. A cheap PVC two-piece oversuit for occasions when it pisses down does the job perfectly.
P.S. Goretex and similar "breathable fabrics" are over-rated, it's all marketing. Pass the popcorn
PostPosted: 08:26 - 03 Apr 2018    Post subject: Reply with quote
Which GORE-TEX® gear did you use that leaked, even after following their washing instructions?
natefz6
PostPosted: 12:19 - 05 Apr 2018    Post subject: Reply with quote
I bought some of Scotchguard in September 17.
It has just about stopped working now after 6 months but it did a great job on my 10 year old Goretex. It gave back the repellency which washing with Nikwax never seems too.
I had a problem where after treating with Nickwax I would not get wet as the Goretex was working but my coat would take and age to dry out, longer than the time I was at work. After many a day of smelling like wet dog I was glad to find a solution.
Saying that I did try it on some of the mini me's sprayproof coats and it seem to do diddly squat so ymmv.
"no I didn't steal it that's just the way I ride"
The last post was made 8 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 105.51 Kb
