keeway rkv 125 HELP
pieman88
PostPosted: 20:49 - 26 Mar 2018    Post subject: keeway rkv 125 HELP Reply with quote
iits a 14 plate with 5000 miles on it
its been stood for a few months...
the guy I brought it from says it ran fine but when you dip the clutch the revs drop ( like stopping at lights or junctions) and they drop too far and cut out.... and it would start back up straight away..
he got a new bike so never fixed it
i assumed it was the idle setting or the carb needed adjusting
key in ignition and the displays and clocks n lights all work fine
nut not enough power in battery to turn it over
i drained the tank and carb of the old fuel (smelt really weak) and put fresh fuel in.... oil looks fine
new ngk sparkplug.. seems to be sparking fine (old spark plug was dirty black colour)
flat battery so i used jumper cables from my car battery with the car engine off ( both batterys at 12 v.. utube says this is fine)
turns over and seems to have descent compression but it just doesnt fire up
i need help
any advice would be hugely apreciated
or anyone in nottingham ide be happy to pay u to fix it
pieman88
PostPosted: 17:16 - 29 Mar 2018    Post subject: Reply with quote
Anything??
Kentol750
PostPosted: 17:22 - 29 Mar 2018    Post subject: Hmmm Reply with quote
Killswitch.
Some bikes.
pepperami
PostPosted: 17:34 - 29 Mar 2018    Post subject: Reply with quote
When you say “dip the clutch” you mean pull the clutch lever in?
Are you rolling off the throttle once you have pulled in the clutch, and does the engine cut out when you roll off the throttle.?
Or is the engine cutting out at any time you pull in the clutch lever?
I had an issue with a bike cutting out every time the revs dropped and it turned out to be the valves were a little tight (closed).
Teflon-Mike
tl;dr
PostPosted: 21:08 - 29 Mar 2018    Post subject: Reply with quote
Has it ever had a proper serbice as in had its tappets adjusted, and been given a new spark plug, not just the oil topped up?
Start there.
Jay2903
PostPosted: 03:23 - 31 Mar 2018    Post subject: Reply with quote
If its not firing up maybe check that spark again.
There is a gap of 1 year, 42 days between these two posts...
Jameshowe
PostPosted: 22:07 - 12 May 2019    Post subject: Keeway rkv 125 Reply with quote
Hi I have a keeway rkv 125 2012 it starts brill ticks over fine it’s had an after market back box put on it but when I get just after half revs in every gear it’s kangarooing on me wants to go but like it’s starving it’s self I’ve put a new spark plug in new chain on cleaned my carb and checked air filter Neutral it still doing the same can anyone give me any advice on what it could be thank you[list=][/list]
Jhowe
jaffa90
PostPosted: 22:48 - 12 May 2019    Post subject: Reply with quote
How did you clean the carb?
What condition was the diaphragm rubber and does the carb slide slowly return from the top position?
Evil Hans
PostPosted: 12:42 - 13 May 2019    Post subject: Re: Keeway rkv 125 Reply with quote
Please don't resurrect an old thread to ask a new question ... by the time everyone realises they are reading a year old thread, they'll be too fed up to bother answering your query.
The last post was made 7 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 59.93 Kb
