Two stroke won’t rev out???
Farmingstock This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:29 - 30 Mar 2018    Post subject: Reply with quote
Was it revving out before? What have you altered between it working and it not working?
Triumph Sprint ST 1050
Farmingstock
PostPosted: 15:55 - 30 Mar 2018    Post subject: Reply with quote
I had it rolling roaded and it was fine, but I’ve put carbon reeds in and a different exhaust. It’s been stood all winter, cleaned the carb and changed the jets but no difference at all!!
bacon
PostPosted: 15:59 - 30 Mar 2018    Post subject: Reply with quote
Can you swap out the reeds and exhaust back to what you had before?
Changing something that affects the fueling then wondering why it doesn't run properly is obviously one of your issues.
Get it back on the rolling road to be setup properly if you are dead set on using your new parts
Farmingstock
PostPosted: 16:14 - 30 Mar 2018    Post subject: Reply with quote
This is full throttle but when riding it’s doing this at 8/9000 rpm or anything from 3/4 throttle basically
Nobby the Bastard
Harley Gaydar
PostPosted: 16:23 - 30 Mar 2018    Post subject: Reply with quote
Fin
PostPosted: 16:30 - 30 Mar 2018    Post subject: Reply with quote
This is posted in the wrong section.
But as stated above 36mm is a bit big.
Have you done the basics and cleaned the jets? you sure the power valve is opening fully?
Spark plug being dark would indicate running rich, putting in a larger jet will make it worse. Try moving the choke and seeing how it runs with it on or off.
Engine tuning is not as simple as just fitting bigger parts. If it were that easy we'd all be riding 200mph monsters.
Farmingstock
PostPosted: 16:44 - 30 Mar 2018    Post subject: Reply with quote
Changed the main jet to a 145 instead of the 170 and it’s had an instant improvement, maybe a little too small now but looking like the main jet was far to big for this set up!!
Nobby the Bastard
Harley Gaydar
PostPosted: 16:46 - 30 Mar 2018    Post subject: Reply with quote
PostPosted: 18:36 - 30 Mar 2018    Post subject: Reply with quote
Put it exactly to how it was when it ran fine on a rolling road.
Ditch the carbon reeds.
Farmingstock
PostPosted: 20:10 - 30 Mar 2018    Post subject: Reply with quote
It’s much better now with the smaller main jet, i no longer have the other exhaust or reeds and the carbon ones are duel stage boyson ones.
I may take it back to the dyno when the weather is better as it’s a fair trek!!
PostPosted: 07:02 - 31 Mar 2018    Post subject: Reply with quote
The make of the reeds matters not.
Smashing a smaller jet in there isn't a magic fix, at least I'd expect a plug chop but ideally having it properly set up..
Also, that carb is far too large.
Evil Hans
PostPosted: 07:24 - 31 Mar 2018    Post subject: Reply with quote
We ought to have a Workshop section for questions like this Wink
Farmingstock
PostPosted: 18:09 - 31 Mar 2018    Post subject: Reply with quote
Very Happy please feel free to move to the workshop section, on my phone and I could have sworn it was in the right section when I posted!!
Got a new plug today so will be doing a plug chop although now the radiator has sprung a leak!
The last post was made 8 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 84.57 Kb
