Wobble and crash
kaiten This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
Kawasaki Jimbo
PostPosted: 19:35 - 02 Apr 2018    Post subject: Reply with quote
Momentarily lost the front on a dusty bend, grabbed front brake, went down. It's a classic. Sympathies, but I don't think worn steering head bearings were the cause.
kaiten This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
weasley
PostPosted: 12:36 - 04 Apr 2018    Post subject: Reply with quote
kaiten wrote:
Hey - in the screenshot you shared the brake leaver was not pulled, not even for a bit. Also, when the handlebar started moving the brake lever was not even covered, let alone braking
The brake lever was covered by two fingers for the entire sequence - look again. Otherwise, are you saying that when things started getting out of shape you simply covered the brake, whilst it was head-shaking?
Looking at the footage there appears to be a line along the road (just to the right of the centre line marking) which is difficult to make out in detail, but could be a crack or other surface imperfection that caught the front wheel. If the headset bearings were also loose this may have exacerbated things but I doubt they were the sole cause of the incident (unless very, properly mangled before the drop, which would be obvious in normal manoeuvring).
MCN
PostPosted: 23:22 - 03 May 2018    Post subject: Reply with quote
Two-Up too fast.
Suspension is not able to react to the road conditions.
Shit road surface.
https://youtu.be/fvsDIq3WwVA
Musketeer
PostPosted: 02:47 - 04 May 2018    Post subject: Reply with quote
Honest reply...
You fked up, don't blame the bike.
Bozzy.
PostPosted: 07:28 - 04 May 2018    Post subject: Reply with quote
In before poor road positioning and look where you want to go.
Glad you were both ok though fella. That could have easily ended in tragedy looking at that drop.
SV650S>>>Street Triple R
PostPosted: 08:51 - 04 May 2018    Post subject: Reply with quote
Clear panic when it got sketchy on the front as you are heading for a big drop, your instinct was to brake, we can all see that from here. The braking and target fixation of the big hole is probably your problem.
The last post was made 8 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 56.58 Kb
