Eletronics/Pi Questions
PostPosted: 13:48 - 11 Apr 2018    Post subject: Eletronics/Pi Questions Reply with quote
I'm making a RPi project, I have a power switch I need to use, I also want a LED to light up when the power is on.
I have little experience so just wanted to check before I start hacking things apart. It's going in a case so I have a Micro USB extender I'm going to fix a slot in the case to run power into the pi.
My plan to use the switch is to intercept the power wire in the cable and run it through the switch. I then plan to tap into the power and ground after the switch to power the LED.
Any reason that won't work?
PostPosted: 13:53 - 11 Apr 2018    Post subject: Reply with quote
I'm probably just a spastic, by any reason you can't use the -ve wire?
I remember my old Clio had a big switch to manually turn on the fan cos sensor was fucked, it burnt through about 4 switches before I put it on the -ve side rather than +ve.
However... you could also use a switch with an LED on it to save the faff?
Following however, as my Pi and Win10 device are in the garage and control CCTV and I still find myself walking out to check they are on...
PostPosted: 14:03 - 11 Apr 2018    Post subject: Reply with quote
The Switch is part of the case, so I can't change it. I am using the neg wire?
Pjay
PostPosted: 14:46 - 11 Apr 2018    Post subject: Reply with quote
Can you do a wiring diagram so I can understand what you are doing?
struan80 - I'll go first - satisfied tick 1
RhynoCZ
PostPosted: 14:54 - 11 Apr 2018    Post subject: Reply with quote
1) LED = use the GPIO: ground + 5V/3.3V (I don't remember the pins, google it) There are at least 2 maybe 3 ''rails'' on the Pi, that stay powered ON when the Pi is booted up. It's mostly used for fans, but you may stick a LED on it too.
2) Switch = turning the Pi ON is alright, turning off requires a script. If you don't use a script to turn the Pi off, you may corrupt the data on the SD card. Oh, and yet again, use the GPIO, don't break the power lead to the USB.
PostPosted: 15:23 - 11 Apr 2018    Post subject: Reply with quote
There is one attached to the first post.
PostPosted: 15:27 - 11 Apr 2018    Post subject: Reply with quote
I've had it running as a KODI box for years, that has only been shut down by yanking the power. I've never had a problem. I've been playing with my build and must have yanked the power 30+ times in the last couple of days, no problem.
I don't want to run the LED from the GPIO logistically it doesn't make sense.
RhynoCZ
PostPosted: 15:30 - 11 Apr 2018    Post subject: Reply with quote
I said it may corrupt the data.
Pjay
PostPosted: 15:31 - 11 Apr 2018    Post subject: Reply with quote
Ah yeah dead simple.
Just follow this guide https://pie.8bitjunkie.net/retropie-shutdown-and-startup-switch-the-easy-way
It's important to have it shutdown correctly as per RhynoCZ's advice.
You can just put 5V + LED to the +V and GND GPIO pins as suggested.
PostPosted: 15:56 - 11 Apr 2018    Post subject: Reply with quote
No good it needs a momentary switch, the case switch isn't.
I'm not bothered about 'maybe' corrupting the data, it hasn't happened in all the years I've been using Kodi, it literally turned on and off every time my TV does. Once I finalize my build I'll make a backup, if it goes tits up I'll be back up and running in ~15 mins.
Pjay
PostPosted: 16:44 - 11 Apr 2018    Post subject: Reply with quote
Then just connect yours to the GPIO, job jobbed.
benvanwell
PostPosted: 22:10 - 11 Apr 2018    Post subject: Reply with quote
The only issue I see is that the LED will need something to limit the current flowing through it. If it's a standard 2-legged 'bare' LED then simply putting a resistor in series should do it.
Just look at the voltage drop (across the resistor) and the current through it to work out what resistance you need.
As an example, if you have a 5V supply, and a 2V LED requiring 25mA then you'd need to drop 3V across the resistor so you'd need a 120Ohm resistor (3V/25mA).
Some packaged LED's have this resistor built in - in which case your proposal will be fine.
Currently Riding: Triumph Sprint ST 1050
Previous: GSF600s, GS500, BMW F45, CG125
PostPosted: 21:41 - 14 Apr 2018    Post subject: Reply with quote
It works Cool
PiStation. Original Controller ports work as does the power switch and the led lights up when it comes on.
It's overclocked and runs well It's not gone higher than 55c that's with the lid shut.
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/29983043_10156195279523476_15200640296681690_o.jpg?_nc_cat=0&oh=f63624beda44090226a32161b0974732&oe=5B5E2AE9
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/29983763_10156195279403476_8773411088492963784_o.jpg?_nc_cat=0&oh=c71cd80270747b145fe45955e2c6c6e1&oe=5B6A7007
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/29873461_10156195279163476_6224936349439404137_o.jpg?_nc_cat=0&oh=eeeca00083f161fcca8e6d6beae09731&oe=5B2A3DF6
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/30072719_10156195278943476_2134421362109926421_o.jpg?_nc_cat=0&oh=d37cac894b98f2ce7cf3fd2e12b55531&oe=5B74A858
https://scontent-lht6-1.xx.fbcdn.net/v/t31.0-8/29983043_10156195279103476_4364128348856023995_o.jpg?_nc_cat=0&oh=a304f50574f2a1da798809e1bd4a2e50&oe=5B6DE6A9
PostPosted: 11:03 - 16 Apr 2018    Post subject: Reply with quote
Now that is cool. Thumbs Up Thumbs Up
DrSnoosnoo
PostPosted: 12:18 - 23 Apr 2018    Post subject: Reply with quote
So? When are you going to post a guide for this?
I want to make one...
Pjay
PostPosted: 12:28 - 23 Apr 2018    Post subject: Reply with quote
That's wonderful and pisses on my retropie consoles :/
https://oi66.tinypic.com/2qch7ix.jpg
https://oi65.tinypic.com/2nszaq0.jpg
The last post was made 8 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 93.7 Kb
