CB500 2001 gearbox knocking
salem1987
PostPosted: 13:17 - 21 Apr 2018    Post subject: CB500 2001 gearbox knocking Reply with quote
On the way to MOT the bike developed a strong vibrating noise under acceleration that sounded like the sprocket carrier bearing had failed.
Turns out the bike makes the noise if put in gear with no chain on, a heavy knocking sound at low rpms in any gear.
(If you know what a sprocket carrier/cush drive failure or knackered chain sounds like, its pretty much exactly the same!)
Clutch and basket are all fine and solid. Output shaft bearing has no obvious play either. All shafts i could get my hands on with the clutch casing off seem solid also.
Also no noise in neutral or the clutch pulled in, only when in gear.
Anyone got any ideas before i start splitting the engine?
MCN
PostPosted: 15:43 - 21 Apr 2018    Post subject: Reply with quote
Pull the engine oil filter.
Cut it open.
Look for Jewellery. (Expensive shiny metal)
How is the crank connected to the g/box? Chain or direct drive?
TLDR post. Razz
Is this your Primary Drive? Aye/Naw?
https://www.google.kz/search?client=ms-android-samsung&biw=360&bih=560&tbm=isch&sa=1&ei=zU7bWv28HsjGsAWhlp2IBw&q=cb500+primary+drive+parts+diagram&oq=cb500+primary+drive+parts+diagram&gs_l=mobile-gws-img.12...0.0..12511...0....0.0.............mobile-gws-wiz-img.ylsYCEe16LU%3D#imgrc=eE8FG1CsssaePM:
salem1987
PostPosted: 19:21 - 25 Apr 2018    Post subject: Reply with quote
thanks for the advice.
after much time stripping the clutch etc with no success i checked the front sprocket.
I hadnt replaced it...
Embarassed Rolling Eyes Embarassed
the hooks on the teeth from a knackered sprocket were causing the chain to ride up and make the noise.
Evil Hans
PostPosted: 20:16 - 25 Apr 2018    Post subject: Re: CB500 2001 gearbox knocking Reply with quote
Question
MCN
PostPosted: 03:45 - 26 Apr 2018    Post subject: Re: CB500 2001 gearbox knocking Reply with quote
Evil Hans wrote:
Question
'Primary Drive Chain (Engine-Clutch)'
Not the 'Drive Chain (Transmission/Gearbox-Back Wheel)'
salem1987
PostPosted: 07:09 - 26 Apr 2018    Post subject: Reply with quote
yes the noise was apparent with the chain off at low rpm's, but seems to have disappeared when riding now the front sprocket is fresh.
Odd i know, and probably doesnt make sense. But i can only assume i heard a noise with chain off and it was just the clutch/engine internals being a bit rattly at low rpm's.
PostPosted: 10:55 - 26 Apr 2018    Post subject: Reply with quote
Aye. Front sprocket was my first thought when I ready your post, then I saw the thing about it doing it with the chain off and you saying you'd checked the output shaft for play and thought it couldn't be.
The last post was made 8 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.22 - MySQL Queries: 13 - Page Size: 52.96 Kb
