| Sweaty_Doughnut |
 Sweaty_Doughnut Nova Slayer
| MCN |
 MCN Super Spammer
| jaffa90 |
 jaffa90 World Chat Champion
| MCN |
 MCN Super Spammer
| davebike |
 davebike World Chat Champion
 Posted: 11:04 - 30 Apr 2018 Post subject: |
25mm is too tight
Many pro's set chains too tight maybe because it looks better or perhaps as it wears them out quicker
Losses it to at least 35mm after lubing it !
I am a pro but I always advise as lose as possible and as well lubricated as you can manage
Me fazer FZ6 chain at 40/50m turono lubricator using scottoil + sprey lub at least once a week ! Last chain did 38K miles ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| stinkwheel |
 Posted: 12:43 - 30 Apr 2018 Post subject: |
You checking it at the tightest or most loose spot? Sometimes if there is a very big differ3ence between the two, I'll set it a little tighter at the tight spot to compensate for the excessive flapping about at the loose spot. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
| MCN |
 MCN Super Spammer
| yen_powell |
 yen_powell World Chat Champion
| stinkwheel |
 Posted: 20:08 - 30 Apr 2018 Post subject: |
If you think this is bad, try going on a track cycle forum.
People can and do set a slight offset on the chainring bolts to compensate for slight ovality so the chain maintains an even tension all the way round.
In fairness, you could probably do it on a motorbike too. They set the tension at the tightest point then loosen the chainring bolts (closest thing would be the rear sprocket bolts on a motorbike) enough to allow it to move slightly but not enough so it is loose. They then give the top run of chain a sharp tap causing the ring to move on the bolts slightly, re-tighten and find the next tight spot and repeat until the minimum of tightspotness is achieved. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
| Sweaty_Doughnut |
| yen_powell |
| jaffa90 |
| Sweaty_Doughnut |
| MCN |
 MCN Super Spammer
| Sweaty_Doughnut |
| jaffa90 |
| Sweaty_Doughnut |
| stevo123 |
 stevo123 Nitrous Nuisance
| MCN |
 MCN Super Spammer
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
 Posted: 19:18 - 01 May 2018 Post subject: |
The last post was made 8 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
