New exhaust rings - silicon sealant
colink98
PostPosted: 10:25 - 02 May 2018    Post subject: New exhaust rings - silicon sealant Reply with quote
my exhaust is making some noise again and i have ordered a set of new rings and studs (as the studs where a mess).
i recall giving everything a good clean last time around and was not overly impressed with the exhaust headers (if that's the right name).
is it good, bad or ugly to run a smear of silicon over the new exhaust rings to aid with a decent seal ?
i have read its OK to use silicon to seal other joins of the exhaust
I'm just not sure about so close to the engine.
C.
Ride it like you stole it.
PostPosted: 10:36 - 02 May 2018    Post subject: Reply with quote
I do not know but I wouldn't have thought silicone could handle the 800+ degree temps of an exhaust.
DrDonnyBrago
PostPosted: 10:55 - 02 May 2018    Post subject: Reply with quote
I've used bathroom silicone around end cans and link pipes, might survive around a head-downpipe gasket but it shouldn't be required fi you are using nice new gaskets.
I've had better experiences with the copper ring gaskets over the fibre/aluminium versions.
PostPosted: 11:05 - 02 May 2018    Post subject: Reply with quote
I've not tried using it at the head, but await stinkwheel's pronouncement with interest.
Baffler186
PostPosted: 12:23 - 02 May 2018    Post subject: Reply with quote
Most high temp silicone I have seen is good up to 3 or 400 degrees C. I wouldn't have thought that is enough. Some people have used normal silicone on end cans etc but when I tried it on one of my old bikes it started to burn and turn into crisps within a couple of weeks. I would not do it myself unless you can find silicone that's resistant up to 8 million degrees and specifically deigned for the job.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Hawkeye1250FA
PostPosted: 13:18 - 02 May 2018    Post subject: Reply with quote
Good gasket fitment and properly tightened bolts are sufficient 👍
No reason to mess it up with silicone that will burn and drop off within hours.
If your gaskets are shit - a touch of instant gasket around the OUTER edges before closing and tightening the bolts will help.
Silicon = no Smile
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
PostPosted: 14:59 - 02 May 2018    Post subject: Reply with quote
Silicon = no Smile
https://i.imgur.com/oFk0B3N.png
MCN
PostPosted: 15:29 - 02 May 2018    Post subject: Reply with quote
I remember Aga (Auld fashioned stove makers) use High temp silicone to glue the fire ring rope stuff into the lids of the hotplates. (The stoves rely on detailed energy conservationa and rope prevents heat escaping.) The hottest plate was way over 500°C.
3M make stuff that goes into orbit.
https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-High-Temperature-Sealant-1137/?N=5002385+3291796008&rt=rud
There are 3M products that are sold in smaller quantities too.
Google 3M high temp silicone.
OP The other issue is, why do you need to add a sealant? Unless the surfaces are compromised the own gasket should be all that's required.
Maybe the faces of the zost are mis-aligned warped.
PostPosted: 16:05 - 02 May 2018    Post subject: Reply with quote
I've used plumbers silicone on the header of my air coooled enfield. However hot that gets.
Hawkeye1250FA
PostPosted: 16:26 - 02 May 2018    Post subject: Reply with quote
Silicon = no Smile
“Its special formulation allows Silverhook RTV Instant Gasket to withstand temperatures from -62°c to +260°c & intermittent use to 315°c.”
Still no.
PostPosted: 16:33 - 02 May 2018    Post subject: Reply with quote
It's not going to be 800 degrees anyway. Aluminium melts at 660 and that's what the engine, and the metal foil in composite exhaust washers are made of.
How hot is something in contact with the cylinder head of a liquid cooled bike actually going to get? I'd be very surprised if it's over 200.
Hawkeye1250FA
PostPosted: 16:38 - 02 May 2018    Post subject: Reply with quote
That’s interesting.
PostPosted: 16:39 - 02 May 2018    Post subject: Reply with quote
Watched a thing on youtube a while ago about tuning cars based on EGT, and I seem to remember it was about 800c. I imagine bikes would be similar. I don't know how much transfers to the steel mind.
PostPosted: 16:42 - 02 May 2018    Post subject: Reply with quote
Aye, when the gas hits the first bend, it's epic hot. But the gasket is against the cylinder head. It can't be hitting 800 degrees, it would melt.
stevo as b4
PostPosted: 18:06 - 02 May 2018    Post subject: Reply with quote
I wouldn't tune anything based solely on EGT readings. Its just another indicator tool when you have all singing equipment for monitoring and setting up engines.
They got by years ago without EGT sensors, and from just what I've read on two stroke tuning, EGT's vary with stuff like types of fuel, compression ratios, head design etc. Its easy to get into a minefield and then ignore basic principles IMO.
PostPosted: 09:43 - 03 May 2018    Post subject: Reply with quote
Still no.
Then which "instant gasket" are you recommending?
ThatDippyTwat
PostPosted: 17:36 - 03 May 2018    Post subject: Reply with quote
Another vote for Loctite 5990. My total bodge-job exhaust uses it liberally. Used just after first bend and in a few places down to the endcan. Just Works.
Hong Kong Phooey
PostPosted: 20:50 - 04 May 2018    Post subject: Reply with quote
If the bike is EFI with modern emissions control systems make sure the sealant is o2/lambda safe.
colink98
PostPosted: 09:43 - 05 May 2018    Post subject: Reply with quote
The studs were a mess, 2 of them were M8 to M7.
The other 4 were just M8 Stud.
2 of the copper washers i removed where not even slightly crushed.
i think the flanges were binding on the M8 stud instead of moving freely as they would on M7 thread.
brand new studs installed which are M8 to M7.
the exhaust ports on the engine block are clean and sound.
the down-pipe's looks nasty as fuck.
https://i.imgur.com/fh5XhJU.jpg
if i commit to "Ste for Mod" will it help my exhaust seal better ?
MCN
PostPosted: 10:12 - 05 May 2018    Post subject: Reply with quote
His campaign is based on him turning the forum around to make it a 'Going Concern' again.
Knowing that the forum is back in safe hands will keep your mind off of your clattery pipes at least.
The last post was made 8 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 115.84 Kb
