Changing brake pads
mazdt1
PostPosted: 19:36 - 01 May 2018    Post subject: Changing brake pads Reply with quote
So my rear brake starter to do wierd sounds and think i should change the brake pads. I need rear brake pad dementions for my bike. Honda NSR 125 r 01
MCN
PostPosted: 19:40 - 01 May 2018    Post subject: Reply with quote
Never change your break pads.
Change brake pads when worn.
andym
PostPosted: 20:28 - 01 May 2018    Post subject: Reply with quote
Have you tried doing a search somewhere like.... maybe ebay for something along the lines of "NSR 125 rear brake pads"?
NJD
PostPosted: 21:29 - 01 May 2018    Post subject: Reply with quote
Have you actually taken the caliper of the bike and looked -- and perhaps measured with a steel metal ruler -- the depth of the pads or are you guessing entirley because it's making noises and or not working efficiently?
MCN
PostPosted: 22:41 - 01 May 2018    Post subject: Reply with quote
It 'should' be possible to determine the state of the brake pads without removal.
There should be an 'inspection' point on the calliper.
Could be by looking from above, from the rear or from below. Depends on the design.
If there is 3mm material then just wire brush and Detol the pads and calliper.
Don't use any oils or grease or WD40.
Buy some Brake cleaner (halfords or maybe Tesco or Aldi) and some emery cloth or wet and dry paper.
You need some coarse 200 grit and some smooth 600 grit.
Be careful you don't damage the piston or the rubber gator.
Remove all rust and shit (old brake pad and disc material cakes and bakes on the brakes) an old flat screwdriver is a handy scraping tool.
Use the fine 600 emery/wet and dry and polis the disc surface to remove old pad material.
Clean all the loosened detritus out with the brake cleaner and refit the pads or fit new pads.
Pump the brake lever to set the pads on the disc.
Ride it like you stole it.
(Did you steal it?)
PostPosted: 22:43 - 01 May 2018    Post subject: Re: Changing brake pads Reply with quote
Why do you want the dimensions of the rear brake pads?
Powderhead
PostPosted: 13:24 - 02 May 2018    Post subject: Re: Changing brake pads Reply with quote
Are the "wierd sounds" just when braking, or when riding normally without braking as well?
"Now at inspector level!"
MCN
PostPosted: 15:08 - 02 May 2018    Post subject: Reply with quote
I think he's deaded himself. No reply from the OP. Crying or Very sad
May have been a Troal. Very Happy
The last post was made 8 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 8.13 - MySQL Queries: 13 - Page Size: 56 Kb
