| Lowmk1 |
 Lowmk1 L Plate Warrior
| Tankie |
 Tankie Crazy Courier
| fatjames |
 fatjames World Chat Champion
 Posted: 09:46 - 02 May 2018 Post subject: |
Yes, I had similar problems with my VFR750 of a similar era.
On the VFR, all the wiring for the clocks is on a flexible PCB in the back of the clocks instead of being wired. After a while, corrosion of the tracks on the PCB starts to cause parts to fail one at a time.
I don't know if your bike has the same system but if it does, this is highly likely to be the cause of the problem.
If there are just a few failures (they are easily visible), it's possible to either solder or screw a wire in to bypass the corroded track. After a while, you land up either having to replace it (not sure if available as a seperate part, might be looking at replacing the whole clockset) or get stuck in and rewire the whole lot.
Here's the back of my VFR clocks. You can see the green wire bypassing one of the blown tracks. The track to the right of that wire is also "blown".
After a lot of head scratching and careful looking at the PCB tracks, I got it all rewired, took the time to replace the bulbs with LED ones too. My top tip is to use self-coloured LEDs (so a green one in the indicator slot etc), the blue/white ones are very bright. If I was doing it again, I'd take the bundle of wires along the bottom of the clocks and wrap them as a sub-loom and have them branching vertically to each terminal for neatness.
https://i48.photobucket.com/albums/f216/stinkwheel/clockwire.png ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Lowmk1 |
 Posted: 12:03 - 02 May 2018 Post subject: |
Wow thanks for the fast responses! I’ve just been out and had a quick look before I head off to work, I’ve pulled the n/s fairing off and checked fuses all ok, checked where I spliced into the wiring for the indicator relay all seems good.
Everything on the digital dash works, on start up it does its little check with the Rev counter and digital speedo reading, but stick it in gear and nothing.
I also noticed that the loom coming round the top of the n/s going to the clocks if you wiggle this the Rev counter drops off so possible loose connector there? Still...wiggle this section with it in gear (paddock stand wheel turning) and the speedo won’t flick on. Don’t won’t to strip it all down  |
| Lowmk1 |
| fatjames |
| Lowmk1 |
| Lowmk1 |
 Posted: 12:40 - 03 May 2018 Post subject: |
Fat James - thanks for the help  |
| Tankie |
The last post was made 8 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
