Rapid flashing indicators - No dash light
Mike916sp
PostPosted: 12:58 - 04 May 2018    Post subject: Rapid flashing indicators - No dash light Reply with quote
hi guys. Can anyone help?
Bike 1976 gt500 suzuki with new battery. All bulbs checked and working.
When indicators switched left or right each side flashes fast but dash light doesn't work. If I disconnect left or right front indicator the dash light and rear indicator on that side stays on. I am confused Question
Any ideas how to fix problem
2007 Ducati 1098s Tricolore, 1994 Ducati 916s1, 1990 Kawasaki 250 Kr1s, 1976 Suzuki GT500 and Honda Lawnmower with hydrostatic drive. Forever an optimist it can be fixed!!!
PostPosted: 14:27 - 04 May 2018    Post subject: Reply with quote
Earthing problem is usually to blame for those kind of flasher issues on a bike of that era, and I'm pretty sure your indicators rely on the frame earth contact where the stalks attach for their earthing. So check the earth connections are good and have clean metal to metal contact. Pay special attention to any frame earths on the back end, often to be found where the rear section of the mudguard attaches. Remember, rust doesn't conduct electricity in any meaningful way.
Also check the wattage of the bulbs is correct (excessively low wattage will cause faster flashing) and make sure the repeater bulb hadn't been replaced with an LED.
pepperami
PostPosted: 14:58 - 04 May 2018    Post subject: Reply with quote
What Mr Stinky said 100% Thumbs Up
Mike916sp
PostPosted: 17:14 - 05 May 2018    Post subject: Reply with quote
Cleaned up all earth's and everything now works as it should. Btw Stinkwheel all bulbs were the correct wattage so total load on circuit was fine.
Still confused though, can't understand why cleaning all four indicator earths would start the repeater light in the dash working - not something I've come across before. Still flash slightly fast but legal.
Old electrics can do weird things!!
PostPosted: 17:45 - 06 May 2018    Post subject: Reply with quote
A single repeater light generally earths through the indicator bulb on the opposite side. If there is a high resistance there, it wont. Causes endless entertainment when people replace stuff with LEDs because it needs to conduct in either direction. The outside of the bulb holder is also live when you indicate in one direction so if it starts blowing fuses when you indicate, look there first.
The last post was made 8 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 44.65 Kb
