| dsaunders |
 dsaunders L Plate Warrior
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:27 - 04 May 2018 Post subject: |
Sound unseen, your chain is too tight. Spanner monkeys luuuuurve them some over-tight chain.
Stop putting your safety in the paws of someone who could not possibly care less, and check the slack in your chain, on your bike, yourself. ____________________ Biking is 1/20th as dangerous as horse riding.
| NJD |
 NJD World Chat Champion
 Posted: 21:48 - 04 May 2018 Post subject: |
Unless there was some prior agreement, in writing, regarding warrenty prior to paying for the chain cost and labour charges then that re-visit will cost you.
If it is an over-tightened chain -- and as borg says the sound has not been seen by BCF -- then you'll want to play attention to it sooner rather than later before you damage the internals of the bike.
Chain adjustment is fairly easy and for a first timer, as I found out no so long ago, the most time consuming part is making sure everything is in line post doing the job.
Check the slack as per the manual and adjust if needed.
Use a big combination spanner (ring at one end and open at the other) to tighten the axle (do look at torque setting on manual to get an idea); I use a Halfords Pro one that cost, IIRC, a tenner and after a couple of turns it's as tight as it needs to be (varies depending on how much was loosened).
Measure from the back of the axle plate to the end of the swingarm on either side to ensure wheel is aligned.
Adjust chain side first and then repeat on non-chain side afterwards. Do small adjustments on chain side and other side and loosen or tighten as needed.
You'll be amazed how easy a small movement of the adjuster nut makes. If you look at the chain as you turn the adjuster nut with a spanner on the chain side you'll see it go up (to tighten) or down (to loosen). I adjusted mine and it took like the smallest adjustment in the world and made all the difference.
Or you can take it back, since it was shop fitted, and come to a deal about the noise. I doubt they'd accept responsibility for any serious damage without being proded by someone who knows a bit more than yourself at the moment.
As Borg says start doing your own work. Get to learn the bike better and save monies in the process. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| tom_e |
 tom_e Brolly Dolly
| MCN |
 MCN Super Spammer
 Posted: 18:46 - 06 May 2018 Post subject: |
Chains don't 'bed in' much. And not so much that you need to re-touch the adjustment.
They only need a check to make sure all the shit is still there and secure.
And possibly a slather of chain oil. (Or Acidic/polluted/exhausted used engine oil some swear by. )
As said, learn the ropes/chains and do it your self.
It is one of the rules of harmony after all. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| dsaunders |
| kgm |
 kgm World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 01:11 - 07 May 2018 Post subject: |
https://www.cmsnl.com/honda-cb500-1996-t-germany_model1568/partslist/F__1200.html#results
Maybe not your bike but at 29k a new chain and sprockets would get new 'fish drive' rubbers. Item 3 in the diagram.
These reduce the vibration in the transmission.
Cheap to purchase and relatively simple to change.
There are not many parts to go wrong in the chain drive system.
Just an idea. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| dsaunders |
The last post was made 7 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
