6v CG125 blowing fuses bulbs
speedingmotor...
PostPosted: 12:55 - 05 May 2018    Post subject: 6v CG125 blowing fuses bulbs Reply with quote
hello everyone,
i have a 1979 CG125
i removed the indicators a while back so it just has the headlights, horn and taillight / running light. a few months ago the low headlight blew, and i had to use the high beam. the horn wasnt working either and i saw the fuse was blown. now, when i change the fuse, the horn will work for a few minutes, then blows.
i have a multimeter.
what can i check? something is earthed that shouldnt be? something that should be earthed is not?
other fault finding tips?
thanks, hope you have a beautiful saturday
https://www.youtube.com/watch?v=zojEIR_SGSk
Triton Thrasher
PostPosted: 13:56 - 05 May 2018    Post subject: Reply with quote
Fit a new headlight bulb of the correct original wattage.
Don't press the horn.
Rrrrrrrrrrrrrrrrrr
speedingmotor...
PostPosted: 16:45 - 05 May 2018    Post subject: Reply with quote
hi
any other advice, maybe using the multimeter? where there should and shouldnt be a complete circuit.
the headlight is the correct headlight bulb, and i like to use my horn.
speedingmotor...
PostPosted: 14:00 - 06 May 2018    Post subject: Reply with quote
disconnected horn
disconnected headlight
still blowing fuses,
gonna check the taillight and i guess the wiring harness to see if its grounded out somewhere?
could my rectifier be blown or something where the generator is producing too much power ?
The last post was made 8 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 39.21 Kb
