Wr 125 not running
HappyDays
PostPosted: 23:27 - 05 May 2018    Post subject: Wr 125 not running Reply with quote
Well, the bike was running fine then will not start.
Battery fine and turns over but nothing, have noticed the pump not priming so fuse, pump, relay or What? anyone had the same and do the fuel pumps fail?
Liquorice Torpedoe
HappyDays
PostPosted: 14:50 - 06 May 2018    Post subject: Reply with quote
Left it for a bit and now it starts!!
Does the pump sometimes stop if it gets to warm?
and can you swap it out with this, anyone?
https://www.ebay.co.uk/itm/YAMAHA-WR125-FUEL-INJECTION-FUEL-PUMP-ALL-MODELS-IN-STOCK-UK-SELLER/112654282849?hash=item1a3ab7f061:g:QoMAAOSwYVlaFvpK
Thanks
Liquorice Torpedoe
ThatDippyTwat
PostPosted: 20:17 - 06 May 2018    Post subject: Reply with quote
Yam's fuel pumps on the YBR's certainly do that. If it's the same pump used, then yeah, it's likely. There was a thread on here about it.
HappyDays
PostPosted: 22:09 - 06 May 2018    Post subject: Reply with quote
Thanks, will need to look into this as I didn't know it could be a common problem with Yamaha pumps when hot/warm.
Liquorice Torpedoe
RS65
PostPosted: 10:24 - 07 May 2018    Post subject: Reply with quote
My WR125 had similar fault and gradually got worse until wouldn't start at all. New fuel pump (expensive) sorted this out and has been ok for last 3 yrs. My 2010 wr had this problem in 2015 at 7500m but has been ok ever since and now on 16000m. Thought problem had returned in 2017 but it was the much cheaper ignition coil that needed replacing. Fuel pump can be removed and tested on a 12v battery supply. This was supposed to be only a common problem on early WR's and YZF's built before 2012. Haynes manual is quite good if you can get a secondhand copy.
HappyDays
PostPosted: 14:07 - 07 May 2018    Post subject: Reply with quote
Hi,
Did you replace the pump in the white plastic bit or the whole assembly.
Thanks
Liquorice Torpedoe
RS65
PostPosted: 15:58 - 07 May 2018    Post subject: Reply with quote
I looked at some kits but could not work out how the moulded plastic housing could be split, to get to the pump, without risk of damaging plastic parts that would need to be re-used. I bought the whole unit instead. Ebay often has secondhand ones. Unfortunately, i do not know if other 125 yamaha's have identical pumps.
HappyDays
PostPosted: 21:18 - 07 May 2018    Post subject: Reply with quote
Cheers RS for the information,
I've seen them on EBay £45 in the plastic so will go with that option and also easy to swap out. Very Happy
Liquorice Torpedoe
The last post was made 7 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 56.23 Kb
