mash 250cc fuel injection problems
roger77
PostPosted: 18:29 - 06 May 2018    Post subject: mash 250cc fuel injection problems Reply with quote
My bike with 1500kms has a bad case of the "jerky throttle" in 1st and 2nd gear.
I believe this could be down to the FI system acting as a on /off switch at small throttle openings. A common FI problem it seems
Obvious faults like chain tension and throttle cable back lash have been checked
Any one know if a throttle tamer would solve the problem??
pepperami
PostPosted: 19:05 - 06 May 2018    Post subject: Re: mash 250cc fuel injection problems Reply with quote
1500 kms? I’m guessing it’s new and still under warranty ? Surely you should be taking it back to the dealer ?
OR is it your style of riding that is making it feel that way ?
roger77
PostPosted: 16:31 - 07 May 2018    Post subject: Reply with quote
Thanks for the reply, yes the bike is new but I am in France for a couple of months with the bike.
Was looking for a diy solution as I am using the bike every day.
PostPosted: 20:19 - 07 May 2018    Post subject: Reply with quote
Have you considered looking for a Workshop section?
PostPosted: 21:10 - 07 May 2018    Post subject: Reply with quote
A Mash going wrong Shocked
Linuxyeti will be along to tell you they are the bestest bikes in the whole wide world and never go wrong.
So Razz
Triumph Trophy Launch Edition
linuxyeti
PostPosted: 08:10 - 08 May 2018    Post subject: Reply with quote
So Razz
Haha
Never claimed them to be the best bikes in the world, however, my Shineray manufactured Mash 400 is indeed very good, 3 years old, no corrosion to speak of, nothing other than usual comsumables needing to be replaced ..
However, if the OP is in France, there is a healthy network of Mash dealerships over there he could always enquire, perhaps even see if they can substitute the ecu in case there is an issue there, or possibly the throttle position sensor, if it has 1.
However, judging by what the op has said, I suspect, he's not gotten used to riding efi bikes, which may well behave very differently to older non efi bikes he has ridden previously
Beware what photos you upload, or link to on here, especially if you have family members on them
PostPosted: 08:15 - 08 May 2018    Post subject: Reply with quote
#VictimBlaming Tut Tut
linuxyeti
PostPosted: 09:17 - 08 May 2018    Post subject: Reply with quote
Nope, only going on what the OP has posted himself
PostPosted: 09:53 - 08 May 2018    Post subject: Reply with quote
I do hear that some EFI bikes (not mine) have a problem with snatchy throttles.
Those would be bad bikes, that should be sorted out by the manufacturer or dealer.
#Victim
#Blaming
linuxyeti
PostPosted: 10:20 - 08 May 2018    Post subject: Reply with quote
#Victim
#Blaming
Not blaming anyone or anything, as you'll also see I suggested looking at the ecu, and, if it has 1 a throttle position sensor, and as he's in France at the mo, find a Mash dealer to see if they can help or offer suggestions.
I'm a bit curious, anybody ever used a throttle tamer?? Only ask, as i've never heard of 1 before.
PostPosted: 11:31 - 08 May 2018    Post subject: Reply with quote
I can't really see how a device that fiddles with the cable pull will fix a binary fuelling issue.
If it's an overly lean mixture problem, there are other h4x available, like dicking with the air temperature sensor to make the bike think its colder than it really is.
If I had to take a guess at it out in the wild (i.e. France) I might be minded to disconnect the O2 sensor (if it has one) based purely on it apparently working for the Versys.
roger77
PostPosted: 13:23 - 08 May 2018    Post subject: Reply with quote
thanks for the replies. This is my first FI bike and whilst I can reduce the throttle snatch with a small amount of clutch control and a light touch on the throttle its still a pain
I will try a local French dealer and let you know if there is any progress
garth
PostPosted: 21:29 - 08 May 2018    Post subject: Reply with quote
Depends on how sophisticated the system is, but if it's the same as the versys (as mentioned above) of you turn the key whilst holding the starter button down so it doesn't have time to go through its cycle it reverts to a richer safe base map.
PostPosted: 23:15 - 08 May 2018    Post subject: Reply with quote
I suppose anything possible but I really don't think it would be that sophisticated.
You will probably just kill the sprag clutch Razz
roger77
PostPosted: 14:26 - 11 Jul 2018    Post subject: Reply with quote
Just a quick update on this problem.
A new throttle position sensor has been fitted and the bike now rides without any throttle jerks or other problems
Thanks to all the posters for your advise and help
PostPosted: 15:43 - 11 Jul 2018    Post subject: Reply with quote
Thanks for the followup, it's good to get closure.
How easy was it to get the TPS? Was it sorted out under warranty without any quibbles?
linuxyeti
PostPosted: 16:09 - 11 Jul 2018    Post subject: Reply with quote
Cool, good news, how are you finding the bike, I quite like the look of the Black 7 250..
roger77
PostPosted: 08:46 - 12 Jul 2018    Post subject: Reply with quote
TPS was fitted under the 2year warranty by North Cornwall Motorcycles, the Mash dealer.
Bike runs well now its fully run in (occasional 70mph down the A30)
PostPosted: 09:35 - 12 Jul 2018    Post subject: Reply with quote
Dammit Great success!
The last post was made 8 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 102.71 Kb
