Weird Rear shock noise
Draco87
PostPosted: 10:21 - 08 May 2018    Post subject: Weird Rear shock noise Reply with quote
Hi guys,
So finally after fixing bike she has now presented another issue 😭. The rear shock on my 04 R6 has some weird bounce! Anyway, I will try Ro explain as best I can. Basically, the shock is functional soaking up bumps but as the shock returns back to normal position it has a knocking sound. Shock compresses fine but upon return it just stops dead like it is hitting on something it is more noticeable when mounting and dismounting the bike. I've looked all around and nothing is in its way chain and wheel are adjusted correctly, I've adjusted pre load in every position but still does it. My only thought is that the shock is failing or completely broken. Can someone suggest something that i maybe missing or o's it a simple case of needing a new one?
1992 Yamaha SR125, 2005 Honda XR125, 1998 Yamaha XJ600S, 2000, 2004 Yamaha R6, 2002 Yamaha Fazer, 2004 Honda CBR
doggone
PostPosted: 12:23 - 08 May 2018    Post subject: Reply with quote
Replacing would be an improvement anyway most likely.
It sounds pooped, and could been hazardous when riding.
Draco87
PostPosted: 12:53 - 08 May 2018    Post subject: Reply with quote
Thanks mate, just as I expected, I will source a new one and fit asap.
Kawasaki Jimbo
PostPosted: 17:26 - 08 May 2018    Post subject: Reply with quote
You're talking about rebound, so I'd see what happened if I adjusted the rebound damping. Also consider the suspension linkages and bearings. Is it the right shock for the bike?
The last post was made 7 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 40.19 Kb
