Part compatibility (how to check)
Visitor Q
$25 whore
PostPosted: 12:24 - 17 Mar 2005    Post subject: Part compatibility (how to check) Reply with quote
It turns out the ecu/pulsar/stator coil (whichever you choose to call it) has gone on my goose. However since the goose is so rare, its a pig finding one. The goose however, uses the same engine as an extremely common DR 350. So since in theory this part is a component of the engine... will they share it?
Robby
Dirty Old Man
PostPosted: 13:22 - 17 Mar 2005    Post subject: Reply with quote
Should be an identical electrical system.
Make sure you know what it is you want thought, you've mentioned 3 things there.
Stator is a big round thing with a few arms with lots of copper wire wrapped around it. These go.
Near that is a pick up coil, this is the bit that is triggered by a magnet or similar on the flywheel, so basically the bit that tells the bike when to spark. These go less, and generally get less effective as they get hot when they do fail.
ECU is the black box of tricks, where pure evil lurks. These can fail, generally killed by getting too much current (dead reg/rec) or shorting out.
Visitor Q
$25 whore
PostPosted: 21:25 - 17 Mar 2005    Post subject: Reply with quote
I thought they were all the same, but everyone has completely different names for them? I was going nuts with it. I'll fone them up and double check before i get the new part (found someone breaking a pretty good condition goose so it should be cushty).
Thanks for the info though, as far as im aware all electrics on the goose are evil.
The last post was made 21 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 37.97 Kb
