Dealer used wrong oil grade
Sweaty_Doughnut
PostPosted: 17:50 - 10 May 2018    Post subject: Dealer used wrong oil grade Reply with quote
I picked up my bike NC750X DCT (wet clutch) after the second service and have noticed that the engine is a bit jerky. After looking at this online I found that some people resolved it by changing oil. My bike requires 10-30w but the dealer have put 10-40w. Could this have caused any damage to the clutch or engine?
jaffa90
PostPosted: 17:55 - 10 May 2018    Post subject: Reply with quote
""""""" have noticed that the engine is a bit jerky."""""""
More info, when using the clutch or on the run.
Sweaty_Doughnut
PostPosted: 17:56 - 10 May 2018    Post subject: Reply with quote
On the run, mainly in 2nd and 4th gear.
weasley
PostPosted: 18:41 - 10 May 2018    Post subject: Reply with quote
What oil specification does the manual ask for? I’d be surprised if it was only 10W-30.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:44 - 10 May 2018    Post subject: Reply with quote
Tbh, that's the sort of Change you'd use for a higher temp area of the world. I can't see it make it more jerky, just Rob a bit of power.
Triumph Sprint ST 1050
Sweaty_Doughnut
PostPosted: 19:01 - 10 May 2018    Post subject: Reply with quote
Manual recommends 10w-30. However, there is a tiny picture with arrows that shows 10w-30 and 10w-40, not sure if that means you can use 10w-40 oil as well.
On the other hand, he also over tightened the chain, the slack was supposed to be between 30-40mm but it was set between 22-26mm. Could this have caused some damage inside the engine that could cause jerking? I rode with the wrong slack 100 miles (gentle ride).
PostPosted: 19:07 - 10 May 2018    Post subject: Reply with quote
I'd be surprised if it's causing any real problems, and so's my wife.
However, since it's been in to a dealer for that vital peaceomind, I'd fervently, apoplectically, urge that you check that they've actually put some oil in it.
If it's bothering you, go ahead and throw some 10W30 in there, for a fraction of what Honda just mugged you for.
Copycat73
PostPosted: 20:19 - 10 May 2018    Post subject: Reply with quote
Honda states a 10w - 30 oil .. however i have ran a 10w-40 in my cb1000r abs without issue ..
caveat emptor
PostPosted: 20:50 - 10 May 2018    Post subject: Reply with quote
Makes no difference. If you look at an oil viscosity chart they all have similar viscosities once they oil reaches about 60 degrees, which is way below normal running temperature.
Sweaty_Doughnut
PostPosted: 20:54 - 10 May 2018    Post subject: Reply with quote
Could it be then that when the chain was tight something got damaged inside the engine?
PostPosted: 21:00 - 10 May 2018    Post subject: Reply with quote
No I don't think so. Did it make a graunching noise over bumps/dips in the road?
Sweaty_Doughnut
PostPosted: 21:02 - 10 May 2018    Post subject: Reply with quote
Nope, it was totally quiet, unless I didn't hear it because of the helmet.
MCN
PostPosted: 01:15 - 11 May 2018    Post subject: Reply with quote
It shouldn't make any difference.
The viscosity has more to do with protection within a temperature range.
You have oil in there within the range your machine will be operating in.
Try getting lessons from a Bike Training Centre. There is usually one in your nearest city.
Very Happy
Triton Thrasher
PostPosted: 09:03 - 11 May 2018    Post subject: Reply with quote
As long as the chain has some slack at all positions of the rear suspension travel, throughout the 360 degree rotation of the rear wheel, nothing will be damaged.
Rrrrrrrrrrrrrrrrrr
Sweaty_Doughnut
PostPosted: 11:44 - 11 May 2018    Post subject: Reply with quote
Very Happy
Actually, I went for this course but we didn't cover the interchangeability between oil grades Smile
Chris45
PostPosted: 13:36 - 12 May 2018    Post subject: Reply with quote
Don't worry about the grade of oil, it's all designed for cold start/hot engine and most 10/30 W 40 is fine. Older engines benefit more from 20/50 semi synthetic. You sure they put the correct stuff in tho for wet clutches?? Some engine oils will ruin a bike wet clutch ...
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
Sweaty_Doughnut
PostPosted: 13:37 - 12 May 2018    Post subject: Reply with quote
I have a DCT clutch. It uses the engine oil.
weasley
PostPosted: 14:01 - 12 May 2018    Post subject: Reply with quote
From what you’ve said the manual permits a 10W-40 anyway, so true but moot point. Do you know what actual oil was used? I’d assume it’s a genuine motorcycle oil that they use in nothing that comes through the door rather than a car or truck engine oil.
Sweaty_Doughnut
PostPosted: 14:06 - 12 May 2018    Post subject: Reply with quote
They used Castrol Power 1 oil. See the screenshot from the manual. I assume this means that 10w-40 can be used.
https://preview.ibb.co/n37qTy/Screenshot_from_2018_05_12_14_03_19.png
can i delete teamviewer account
Chris45
PostPosted: 17:13 - 12 May 2018    Post subject: Reply with quote
My point exactly thanks. There's very little difference between the lubricants for viscosity purposes. All I'm saying is some oils are specifically not for use with wet clutches, a moot point perhaps? I'd be suprised (shocked) if they had used such a lubricant on your bike, but as the guys say... trust-a-dealer? Not likely. I do everything myself, at least I know it's done properly and if it aint, well I only have myself to blame.
MCN
PostPosted: 17:42 - 12 May 2018    Post subject: Reply with quote
The dealer is most likely the place to find the OEM facts. This is what dealers (and OEMs) sell.
And some 'not the dealers' can know better than some OEM dealers.
Then some DIYers have enough gumption to DITY.
But some folk just want to ride their bike.
I sometimes enjoy a meal cooked by someone else. Very Happy
The last post was made 8 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 113.76 Kb
