Replace Givi top box lock barrel with original Honda one
Jumper
PostPosted: 15:09 - 13 May 2018    Post subject: Replace Givi top box lock barrel with original Honda one Reply with quote
Hi guys, I have a Honda Crosstourer Highlander that came supplied with Honda top box and panniers ( all use the ignition key to lock/unlock) I have replaced the Honda topbox( too small) with a Givi Trecker.
Does anyone know if it’s possible to remove the Honda lock barrel and fit it into the Givi lock in order to keep the ‘one key fits all.
TIA.
ThatDippyTwat
PostPosted: 15:57 - 13 May 2018    Post subject: Reply with quote
Every Givi barrel I've seen is far, far smaller than a standard bike key barrel. The one in front of me (Monokey) is 12.5mm, off the top of my head, a normal ignition key uses a barrel closer to 20mm.
Jumper
PostPosted: 16:25 - 13 May 2018    Post subject: Reply with quote
Thanks for the swift reply Dippy! Does that mean that the Honda topbox barrel is probably also approx 20mm and therefore the Givi ‘hole’ would be too small?
Evil Hans
PostPosted: 16:31 - 13 May 2018    Post subject: Reply with quote
Can you not see them from where you're sitting? Wink
MCN
PostPosted: 16:49 - 13 May 2018    Post subject: Reply with quote
Drill it/File it and fit it?
I think the hole should have a flat on each side too. To stop the barrel twirling.
ThatDippyTwat
PostPosted: 17:12 - 13 May 2018    Post subject: Reply with quote
Even with the surround for the barrel, it's still only 16.5mm across the flats. If you manage to pad it out, you will still need some sort of actuator to turn things. All the Honda barrel will do is touch a few contacts, but you need to physically rotate the latching mechanism in the case.
I have one in front of me to replace one, but I've never needed the box since, so the lock sits on my desk because frankly, I CBA.
Jumper
PostPosted: 17:43 - 13 May 2018    Post subject: Reply with quote
Working away from home atm, hence the time for posting Laughing
Jumper
PostPosted: 17:47 - 13 May 2018    Post subject: Reply with quote
Thanks for the replies guys..... think, as Dippy says, this might have to into my CBA/too difficult box! Rolling Eyes
Jumper
PostPosted: 20:56 - 13 May 2018    Post subject: Reply with quote
The last post was made 8 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 57.45 Kb
