Where can i buy this item?
RickTaff
PostPosted: 22:12 - 15 May 2018    Post subject: Where can i buy this item? Reply with quote
In the attached photograph, it shows a headlight removed from the fairing and in the centre cirlce bit... there is 3 prongs. Headlight, sidelight and high beam i believe.
The issue i have is the previous owner has cut the connection blocks off my wiring loom so i have to crimp my wires (indicators, neutral, etc etc) together to make connections. So far so good.
My question is - rather than feed the copper wire through the little holes on those prongs and try and loop them or something, and hope they stay in there (thus meaning my headlight continues to work) can i buy a connector so i can fasten the wires to that, then just plug into the connection on back of headlight case
Itchy
PostPosted: 22:18 - 15 May 2018    Post subject: Reply with quote
You mean this:
https://www.ebay.co.uk/itm/H4-Headlight-Headlamp-3-Pin-Bulb-Repair-Plug-Connector/141177298307?hash=item20ded29d83:m:mCAJ2jV3ImbqVvCh5NgbE4w
In fact I probably have one somewhere.
RickTaff
PostPosted: 22:22 - 15 May 2018    Post subject: Reply with quote
Itchy wrote:
Yes! I'd just have to crimp the existing 3 wires onto the wires connected to that, and plug it in.
Thanks!
Itchy
PostPosted: 22:23 - 15 May 2018    Post subject: Reply with quote
Thanks!
Last time I did this I didn't have a crimper so I simply soldered them on and covered them in shrinktube and electrical tape.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:29 - 15 May 2018    Post subject: Reply with quote
You can buy them in halfords, ffs....
Triumph Sprint ST 1050
The last post was made 8 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 46.06 Kb
