Gsxr srad running problems
Gsxr_rory
PostPosted: 13:58 - 14 May 2018    Post subject: Gsxr srad running problems Reply with quote
Hi,
I have got.a gsxr srad 600 and it's running like a bag of poo
The bike had sat for 2 years without being run and I decided to put it back on the road his year.
The bike just wouldn't idle and died if it was revved.
I took the carbs off, cleaned the jets Etc and re-installed.
The bike runs a bit better but has got flat spots and won't go over 4 k revs
It has got standard air box and filter, and an aftermarket back box
Any help much appreciated
Evil Hans
PostPosted: 15:35 - 14 May 2018    Post subject: Re: Gsxr srad running problems Reply with quote
I'd do that. Again.
Also, check for air leaks, especially the rubber pipes between the airbox and the carb. They fall apart after a few years.
jaffa90
PostPosted: 22:37 - 14 May 2018    Post subject: Reply with quote
What about the vacuum diaphragm rubbers and carb slide movements?
Gsxr_rory
PostPosted: 23:13 - 14 May 2018    Post subject: Reply with quote
The carbs have been fully cleaned again the vacuum pipes etc are all good. Could it need rejetting ?
bacon
PostPosted: 06:58 - 15 May 2018    Post subject: Reply with quote
If it worked prior to standing for 2 years, assuming you've made no changes to the fueling since it was running, but won't run now, then you probably just need to clean everything again like everyone so far has said.
Check fuel filters, check the fuel tap isn't blocked with tank crud (if the tank was near empty when you stood it up, it may have rusted), check the fuel line hasn't been pinched etc, check seals around the airbox and intake etc.
Oh and fresh fuel
Nobby the Bastard
Harley Gaydar
PostPosted: 11:45 - 15 May 2018    Post subject: Reply with quote
Have you checked that you have sparks at all 4 cylinders?
Gsxr_rory
PostPosted: 18:28 - 17 May 2018    Post subject: Reply with quote
I really need advice now please.
Stripped the carbs again and then I randomly noticed that the needles were different lengths.
I bought new needles and installed them. There are currently set to third notch. There is 5 in total.
I put the carbs back on and decided to start the bike.
The bike runs really bad still.
I have got a carb tune pro and decided to try balance the carbs.
The problem is now there seems to be no vacuum at the carb tune pro. There is no movement at all. What could possibly be wrong?? I've got an MOT tomorrow any advice appreciated
Nobby the Bastard
Harley Gaydar
PostPosted: 19:17 - 17 May 2018    Post subject: Reply with quote
You didn't answer my question so I'm out.
Gsxr_rory
PostPosted: 19:19 - 17 May 2018    Post subject: Reply with quote
Yes there is strong sparks on all cylinders they are all firing fine
almostthere
PostPosted: 20:02 - 17 May 2018    Post subject: Reply with quote
had exactly the same thing with my zx9r been stood for years,
I cleaned the carbs a total of four times raised the needles to fourth from top still ran like shit as a last resort I sprayed everthing electrical with a fucking ton of wd40 runs like a dream now Very Happy
Worth a try if it's been left outside.
Beer, It's the reason I get up every afternoon
www.mfairco.uk
jaffa90
PostPosted: 22:21 - 17 May 2018    Post subject: Reply with quote
Same here!
The last post was made 7 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 3.46 - MySQL Queries: 13 - Page Size: 66.04 Kb
