OEM ‘Endless’ Chain Removal
Renton
PostPosted: 07:15 - 18 May 2018    Post subject: OEM ‘Endless’ Chain Removal Reply with quote
Need to remove the OEM chain from 00’ Monster 750, and there doesn’t appear to be a master link.
Can i still drill a rivet out?
Essentially, I’m looking for a way to remove the chain without removing any suspension linkage or the swingarm etc.
Caveat; no access to a proper chain removal tool.
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
haroman666
PostPosted: 07:16 - 18 May 2018    Post subject: Reply with quote
Angle grinder!
kgm
PostPosted: 07:33 - 18 May 2018    Post subject: Reply with quote
You can grind the heads off the rivers and replace that link with a new rivet link. If you're replacing the chain just cut right through it. Either way you'll need a chain tool to rivet it back on though unless the bike is lower powered allowing you to use a clip link. The cheap DID stylr tools are fine for riveting but generally don't stand up to removing pins.
PostPosted: 07:36 - 18 May 2018    Post subject: Reply with quote
You should have at least one angle grinder. Thumbs Up
PostPosted: 09:01 - 18 May 2018    Post subject: Re: OEM ‘Endless’ Chain Removal Reply with quote
How are you intending to put it back together again / put a new one on? I wouldn't even consider using a clippy-link on tthat bike.
Hahadumball
PostPosted: 09:55 - 18 May 2018    Post subject: Re: OEM ‘Endless’ Chain Removal Reply with quote
can tell you're from up north your low iq in that post..
superglue it on.. duh!
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Hong Kong Phooey
PostPosted: 10:19 - 18 May 2018    Post subject: Reply with quote
Hacksaw will go through before you've even plugged in the angle grinder.
skatefreak
PostPosted: 10:28 - 18 May 2018    Post subject: Reply with quote
Grind off the end of a rivet and tap through to remove, buy some hollowed tip rivets, have mushroomed these with a brick, ball bearing and hammer before. Not recommended practice though... Laughing
PostPosted: 13:02 - 18 May 2018    Post subject: Reply with quote
Oh, you unplug your angle grinder? I guess you wouldn't want to trip and have your vagina mutilated.
RIP BodyTard.
PostPosted: 13:46 - 18 May 2018    Post subject: Reply with quote
Rogerborg wrote:
RIP BodyTard.
Off topic, where is that sack of joy and political correctness.
RhynoCZ
PostPosted: 13:48 - 18 May 2018    Post subject: Reply with quote
RIP BodyTard.
Yeah, yeah, Roger loves his grindr. Wink
PostPosted: 13:51 - 18 May 2018    Post subject: Reply with quote
With da angles.
Praying
Hahadumball
PostPosted: 17:47 - 18 May 2018    Post subject: Reply with quote
Ste wrote:
With da angles.
Praying
angels Embarassed
or angle grinders being turned into french fried potatas
MCN
PostPosted: 09:30 - 19 May 2018    Post subject: Reply with quote
Paddy. wrote:
Rogerborg wrote:
RIP BodyTard.
Last I heard he's looking to get un-karma-banned from a Honda hornet forum.
Ste is presently brokering a deal for him.
Hong Kong Phooey
PostPosted: 10:00 - 19 May 2018    Post subject: Reply with quote
RIP BodyTard.
When you have a 9 incher it's easy to trip over.
thx1138
PostPosted: 10:26 - 19 May 2018    Post subject: Reply with quote
haroman666 wrote:
Angle grinder!
tried doing it with a Dremmel? Laughing
i did Embarassed broke a few discs
Tamsin
PostPosted: 10:47 - 19 May 2018    Post subject: Reply with quote
What's the point in a grinder you have to plug in? Just slows you down 🤣🤣
PostPosted: 11:20 - 19 May 2018    Post subject: Reply with quote
If it takes less time to cut the chain with a hacksaw than it takes to plug in an angle grinder then you're doing something wrong. Razz
MCN
PostPosted: 11:37 - 19 May 2018    Post subject: Reply with quote
If you ever find yourself doing something wrong then
Ste for MOD.
The last post was made 7 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.48 - MySQL Queries: 13 - Page Size: 104.11 Kb
