Add a 5th gear or gearbox upgrade.
ilonasn
PostPosted: 13:04 - 19 May 2018    Post subject: Add a 5th gear or gearbox upgrade. Reply with quote
I have a Malaguti Motard X3M 125cc from about 2010.
The front sprocket has 13 teeth and the rear sprocket has 51 teeth.
Hills are never a problem now but on straight roads, the bike is maxed out in 4th gear and another gear would be the ultimate driving experience Very Happy , or is there an upgrade available Question , maybe an XT one would fit since it is a Yamaha engine.
Cheers,
ilona
PostPosted: 13:13 - 19 May 2018    Post subject: Reply with quote
You 'should' be able to drop an XT125 engine in there, but depending on whether thats a carb or EFI bike you have there.
If carb, then engine + ancillaries + carb + airbox will get you all gears possible.
PostPosted: 13:16 - 19 May 2018    Post subject: Reply with quote
How heavy are you?
Is your chin touching the tank?
Is the chain oiled?
Is the gearing standard....It'll be the best compromise for most people eg a small light rider may eek a bit more topspeed with taller gearing.
1) Buy a lighter 125cc bike with a fairing.
2) Buy a bike with a bigger engine. Thumbs Up Thumbs Up Thumbs Up
ilonasn
PostPosted: 13:36 - 19 May 2018    Post subject: Reply with quote
I am heavy, maybe 70kg.
It already has an engine with a carb and is air cooled.
I don't want to buy another 125cc and if there is a way to either upgrade the gearbox or add another gear to the gear shaft than that would be more than amazing; but where would I find out about such details since googling it has not been successful at all.
ilona
PostPosted: 14:13 - 19 May 2018    Post subject: Reply with quote
no, thats fucking retarded. Laughing
Replace the engine with the XT one.
PostPosted: 14:58 - 19 May 2018    Post subject: Reply with quote
You just buy the extra gear, then place it on the side of the engine, then hit it with a hammer until it goes into the gearbox.
Sadly I was being facetious, it doesn't work like that.
The cases are designed for a specific set of gears which sit on shafts inside the gearbox. With a four speed gearbox you have two shafts with two gears apiece. In order to add another gear you would need to add another shaft, and there isn't any space inside the box for that.
The only way to do it is to swap the entire lump as others have said, or sell the bike and buy one with a five or six speed gearbox.
PostPosted: 16:33 - 19 May 2018    Post subject: Reply with quote
ilona
There's a good reason for that. Rolling Eyes
If you're maxing it out in top gear, just up the final drive gearing by adding a couple of teeth at the rear or 1 at the front - and by "add" I don't mean stick another couple on with superglue.
You'll lose a bit of acceleration, but gain taller gearing so won't need to be revving the tits off it in top gear.
Adding 2 teeth on the rear sprocket will make things worse. He needs to reduce the size by a couple of teeth.
PostPosted: 20:17 - 19 May 2018    Post subject: Reply with quote
It's a Malaguti, not an Enfield.
As above, if you want to keep the same chain you could try 14 / 51 for about +10% more speed[*] per revs or 15 / 50 for a whopping 20%. If you have enough slack you could go to a 14 or 15 on front without reducing the rear, or drop 4 or more off the rear and lop some chain links out.
Just going +2 on the front might sound extreme but it was a common mod on my HN125-8 and worked well in practice to give a less frenetic ride, although it didn't make them any quicker.
[*] I mean, notionally faster. In practice, you may find the revs drop so much when you change up that you end up worse off. You can't magic any more power out of the engine, or widen its powerband (although you could fit a red one).
ilonasn
PostPosted: 20:57 - 19 May 2018    Post subject: Reply with quote
Thanks a lot for the hammer it into place option, might need to.
I love the front/back gear ratio as it is. Supposedly, some Yamaha engine/gearbox can be upgraded to 150cc. It's also possible to add gears if this was planned by the manufacturer from the beginning as an alternative but I still need to look into it - keep you posted.
ilona
Teflon-Mike
tl;dr
PostPosted: 21:05 - 19 May 2018    Post subject: Reply with quote
Basic primary laws of fizzix.. power=rate of work done, work done is force times distance, so power is force times speed.
Gears. Rotary levers. They can magnify force for a proportional reduction in speed, or increase speed for a proportional reduction in force.
You have a 10bhp, 4-stroke 125, dirt-bike with road-tyres... relatively speaking its tall and wide, and spreads you, the rider out like a human parachute when riding to increase the frontal area drag acts on.
With a finite amount of power, it isn't going to go any quicker, no matter how many gears you got or how you mess with the ratios.... the 'problem' isn't that you dont have enough gears to pick from, its that you dont have any more power.
Raise the gearing; use 14-52 combination or 12-48 combination, it will NOT defy the laws of phisics and suddenly let the bike top out at 120mph... because you still have the same amount of power... it will go just as slowly as before.
All you MIGHT achieve is to shift the top-out point an MPH or so either way; with lower gearing you will reach revs with more power to spare than is needed to reach max speed and so cant go no faster, or you will reach a speed where the resistance force is higher than you have power to over-come, and you'll top-out before you completely run out of power, but be unable to go faster, and maybe get at the engine revs you have a bit more, because the resistance force is always more than the driving force.
With taller gears, you might be able to go a tad quicker... down hill..... where the potential energy of being at the top of a hill, adds to the power the engine may make....
But back to square one..... power is force times speed.... you don't need more gears, you need more POWER!
Again... You have a 10bhp, 4-stroke 125, dirt-bike with road-tyres... relatively speaking its tall and wide, and spreads you, the rider out like a human parachute when riding to increase the frontal area drag acts on.
You want it to go faster on the flat... you need more power or less drag..... that means a bike with a smaller frontal area and pointy fairings... and oooh... with just 10bhp it STILL wont go much if any faster.... look at the specs... so you still need more power....
A 125cc four-stroke single, at BEST, might make oooh, all of 17bhp...... eg YZF-R125.... water-cooled, double-over-head-cams, four valves, fuel injected... and a lot of expensive tuning goodies and work chucked in to get it... briefly....for as long as the cylinder head gasket dont go pop......
Probably the most powerful air-cooled, two-valve 125cc single was the 1973 Honda CB125 motor, that the XL lumps were later based on... managed a heady 13bhp.. and was successively detuned year on year by the factory as it had a habbit of eating its own cam-shafts.
Doubled or quadrupled up, to make a twin or four cylinder engine..... two-valve air cooled engines topped out at around 100bhp per litre.... about 0,1bhp per cc... that's multiplies out to.... oooh.. about 12.5bhp from a 125cc engine.....
Think you can do better than Honda, Suziki, Kawasaki, Yamaha, Ducatti or BMW's enormouse R&D departments? Go for it!!!!
You will NEVER manage to get much more than 13bhp from that engine, no matter how much you do to it... and without that extra power, it will not go any faster on the flat regardless of how you mess with gears.
As has been said... you want more than what you got... buy another bike.... and even then, another 125 will probably still not be much if any different, all of them having the same 'problem' that limited to just 125cc they are also limited to how much power they may make, and you are in a world of slow, where even the fastest of the fast, two-stroke 125's, that might just top a ton, are only barely as 'fast' as thirty year old 250 commuter bikes, let alone anything bigger, newer or more sporty.
What you have is what, eight years old; and no spring chicken... and fact you say its from 'about' 2010.. does make me wonder how legit it is, and whether its even a road legal bike, not a probably stolen or scrapped field-bike... or you should know EXACTLY how old it is and when it was first registered for the road...... but just on age alone, its likely not making all the power or able to go as fast as it should, after almost a decade of learners fiddle fingers trying to 'fix' it....
Old track addage, before looking for more than standard, make sure you have all you have AS standard... and if that aint enough... rather than try re-invent the wheel, look for a different standard that gives you what you want......
PostPosted: 16:41 - 20 May 2018    Post subject: Reply with quote
ilona
Really no, I suspect there might be a couple of Japanese bikes with six speed gearboxes which were retroactively converted to five for another application, but I bet you can count bikes like that on the fingers of one hand when you've failed the Yakuza at least twice.
PostPosted: 17:47 - 20 May 2018    Post subject: Reply with quote
The only way to keep your bike and increase gears is to add the XT engine to your frame.
PostPosted: 18:00 - 20 May 2018    Post subject: Reply with quote
https://jokideo.com/wp-content/uploads/2012/01/403162_10150613644143465_129446698464_11144620_448774237_n.jpg
ilonasn
PostPosted: 22:25 - 20 May 2018    Post subject: Reply with quote
Rolling Eyes
PostPosted: 14:46 - 21 May 2018    Post subject: Reply with quote
According to Bikez.com the Malaguti X3M 125 has a 5 speed gearbox...
supZ
PostPosted: 15:00 - 21 May 2018    Post subject: Reply with quote
indeed.
https://www.bikez.com/motorcycles/malaguti_x3m_motard_125_2010.php
my solution is infact quite simple.
1. when you've got to 4th gear
2. change up again.
happy to help.
CBR954RR - Daily toy
CBR600RR - Trackbike
ilonasn
PostPosted: 17:16 - 21 May 2018    Post subject: Reply with quote
Haha 🤣 Sorry, for the confusion but I did’t consider ‘Neutral’ a gear.[url][/url]
PostPosted: 17:25 - 21 May 2018    Post subject: Reply with quote
Bikez.com is not known to be the most reliable source. Either that or OP's bike is just broken.
PostPosted: 08:05 - 22 May 2018    Post subject: Reply with quote
Other places state 5 also, your bikes fucked.
supZ
PostPosted: 16:18 - 22 May 2018    Post subject: Reply with quote
nor does anyone else Rolling Eyes
WD Forte
PostPosted: 01:07 - 23 May 2018    Post subject: Reply with quote
I know what you're thinking:
"Did I change up four times or only three "
Well, to tell you the truth, in all this excitement, I've kinda lost track myself.
But being this is a Malaguti X3M 125cc the bestest most powerfulest moturd in the world, and would blow your head clean off,
you've got to ask yourself one question:
'Do I feel lucky?' Well, do ya, punk?
bikers smell of wee
The last post was made 8 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.01 - MySQL Queries: 13 - Page Size: 129.15 Kb
