Honda h100s 1984
H100igan
PostPosted: 18:07 - 28 May 2018    Post subject: Honda h100s 1984 Reply with quote
So I bought this blue stallion of a honda h100! The seller said the battery needs replacing and this is why the neutral light horn and indicators do not work. Would this be true?
H100😣
dydey90
PostPosted: 19:43 - 28 May 2018    Post subject: Reply with quote
If the battery is entirely flat, then it won’t be able to power any of these. If anything else electrical is currently working on the bike, then obviously the battery isn’t flat.
H100igan This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
dydey90
PostPosted: 20:47 - 28 May 2018    Post subject: Reply with quote
Just looked it up and found out Thumbs Up
Do you still need the answer?
PostPosted: 20:49 - 28 May 2018    Post subject: Reply with quote
"Obviously" he doesn't.
H100igan
PostPosted: 20:53 - 28 May 2018    Post subject: H100 Reply with quote
Have you any advice on them? I have had a few newer bikes from sports to supermoto to enduro and the little h100 I bought isn't that bad of a bike from what I can see but it has had its 17 year old riders playing with it and I just want to check a few things out on it.
H100😣
dydey90
PostPosted: 20:56 - 28 May 2018    Post subject: Reply with quote
Beat me to it.
H100igan This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
PostPosted: 21:37 - 28 May 2018    Post subject: Reply with quote
The first rule of BCF is commonly reported as "You do not talk about BCF". However, this is not the case.
The first rule of BCF is "You do not name yourself after a bike"
The second rule of BCF is "You don't come in, p*ss on someone elses carpet and expect them to be happy about it"
The third rule is "Do not open links posted by Ste at work".
Other than that, welcome to the forum. Obviously.
PostPosted: 22:40 - 28 May 2018    Post subject: Reply with quote
H100igan wrote:
Cheers mate eat a big
Slice of cherry pie and custard? Thanks! My favourite.
grr666
PostPosted: 22:48 - 28 May 2018    Post subject: Reply with quote
Heathen, it really has to be ice cream with cherry pie.
grr666
PostPosted: 07:16 - 29 May 2018    Post subject: Reply with quote
But to be fair, a well made apple pie has no compare. A little cinnamon and a few good quality sultanas is the key.
grr666
PostPosted: 07:19 - 29 May 2018    Post subject: Reply with quote
Also the ice cream has to be of high quality. Madagascan vanilla and clotted cream is an excellent choice to go
with such a pie.
PostPosted: 17:52 - 29 May 2018    Post subject: Reply with quote
Wtf is wrong with this guy?
Is he just wanting some apple pie?
PostPosted: 18:01 - 29 May 2018    Post subject: Reply with quote
Bye Wub
Teflon-Mike
tl;dr
PostPosted: 18:27 - 29 May 2018    Post subject: Reply with quote
And on a different note....
I failed my Part 1 test in 1988 on a Honda H100... women (I think she was a woman... she had tits under her cut... I think... but I never braved up enough to ask!!!) said that it was a fantastic display of trials riding, but the rules said I that unless the front tyre stays on the floor, you aren't in full control!!!! Shocked
6v, Magneto ignition, the biggest wonder is that it actually HAS a neutral warning lamp and a horn to NOT work!! About the only thing with less electrics on it would likely have pedals!
If the chap has to ask on forum about the battery... one does wonder whether he has the know-how to be tackling something so 'complicated'... let alone argue with the answers he gets!?!?!?
H100igan... by any chance does your mum wear a leather sons of apathy cut?
If so I suggest you ask her about H100 'lectrics...
grr666
PostPosted: 18:43 - 29 May 2018    Post subject: Reply with quote
It's worth mentioning that just about any baked dessert is improved with a few toasted pecans. They are quite expensive but
you can make them go further by crushing them up, whole pecans are the preserve of the truly decadent diner.
grr666
PostPosted: 19:14 - 29 May 2018    Post subject: Reply with quote
https://www.bakerssquare.com/i/pies/profile/caramelapplealamode_main1.jpg
This one here looks quite delicious but in this example the pie to ice cream ratio is a little off. By my calculations
it requires 77.2% more ice cream to make sure you can have some of both in each bite. Maximising the enjoyment
of the tartness of the apples and the sweetness of the cream in a delicious symphony of flavour. If you are watching
your weight then perhaps an apple tart would be preferable as it dispenses with about 33% of the pastry by having
no top. This reduces the calories more significantly than the layperson may realise. I like pies very much. Have you read
my book? It's called "I fucking love pies" and is available on Amazon and in all good bookstores.
https://i.imgur.com/5PEljZA.jpg
PostPosted: 19:29 - 29 May 2018    Post subject: Reply with quote
Apple crumble is superior to apple pie.
grr666
PostPosted: 19:31 - 29 May 2018    Post subject: Reply with quote
Fite.
Teflon-Mike
tl;dr
PostPosted: 20:29 - 29 May 2018    Post subject: Reply with quote
Indian Motorcycles..... in particular a 1949 Indian Cheif.. in a baked desert... without pecan nuts, but with apple pies, particularly Rebecca's apple pies.....
The answer, is unfortunately Red... not DuPont Yellow, and started the mess caused by Floyd Clymar's untimely, which requires a very long explanation of how an Indian Enfield isn't necessarily an Indian Enfield, and an Indian Chief isn't a Victory.....
Inferno..... and not the towering kind.... begs watching to answer the argument... and all the way through, when a woman sees the muscles from bruscles without a t-shirt.....
And THEN some-one types "Bakes Deserts need Pecan Nuts" When I am still seeing a long shot of a bottle of José Cuervo back-dropped against Nevada mountains!!!!!
Insanity is merely the measure of madness in which you are in the middle of..... I think I'm cured doctor........
Fisty
PostPosted: 21:58 - 29 May 2018    Post subject: Reply with quote
Ladies and gentlemen.
Here we have the moment Teffers finally lost it. CB125 twist grip wedged sideways up his anus, LSD in his system and half an apple pie smashed over his groin.
Snowie cowering in the corner, leopard print onesie in tatters as Teffers towers abover screeching "BAKED DESERTS NEED PECAN NUTS"
Fatter and faster than Fret
The last post was made 8 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 130.49 Kb
