Currently doing A2 > A
Sam Millar
PostPosted: 14:44 - 09 Jun 2018    Post subject: Currently doing A2 > A Reply with quote
Hi All,
Just wanted to ask a few questions. I've been advised that I will need my theory certificate to be in date if I want to progress from my A2 > A. As I technically already have a 'Full UK License' albeit with a power restriction, I was under the impression the theory test I sat in 2014 would do me. Can someone clarify this? I passed my motorcycle theory in Sep 2016 and I then passed my 'A2' in July of 2016. Do I need to sit another theory to be able to go and sit my 'A' now?
I'm 24 and will be 25 in July.
Kentol750
PostPosted: 15:31 - 09 Jun 2018    Post subject: Reply with quote
Yes. You won't once you pass the 2year point in July.
Some bikes.
Pjay This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Kentol750
PostPosted: 16:13 - 09 Jun 2018    Post subject: Reply with quote
It's a new licence attempt. Theory still needed. Answer perfectly clear.
Some bikes.
Pjay
PostPosted: 16:55 - 09 Jun 2018    Post subject: Reply with quote
He has a full motorcycle licence, which means he has passed the relevant theory test. There is no requirement for him to sit another.
And Roger, FYI, he doesn't need to wait 2 years, he is 25, he could have sat the full A licence last year, just producing his A2 licence.
Once you pass your Theory, you have 2 years to then pass your test, he did this.
You are both now confusing the poor chap, when he doesn't need to pass another Theory test at all.
struan80 - I'll go first - satisfied tick 1
PostPosted: 17:01 - 09 Jun 2018    Post subject: Reply with quote
Pjay wrote:
Holding an A2 means you have passed the motorcycle theory, it has nothing to do with 2 years.
Sadly, not the case. Kentol is right.
You always need a theory pass within the last two years, except in the specific case of doing progressive access from A2 to A.
Progressive access means doing A Mod 1 at least 2 years after passing A2 Mod 2. As OP passed in July 2016[*], he would currently be doing direct rather than progressive access, and requires a theory pass.
I know this makes no Goddamn sense, but... Sir Humphrey says.
[*] Something else that makes no sense is:
Garbage in, garbage out.
If you meant motorcycle theory in 2015 then it's expired and you'll either need to do it again, or wait until 2 years after you passed A2.
If you meant something else, let us know and after we're done handbagging each other, we can sort you out.
Kentol750
PostPosted: 17:03 - 09 Jun 2018    Post subject: Reply with quote
If you upgrade before the 2 years are up you need a valid theory test.
As originally stated.
Just got Borged!
Some bikes.
Pjay
PostPosted: 17:06 - 09 Jun 2018    Post subject: Reply with quote
https://www.gov.uk/motorcycle-theory-test/pass-mark-and-result
Your pass certificate number lasts for 2 years. You need to pass both modules of the motorcycle test in that time, otherwise you’ll have to pass the theory test again.
I know someone that passed on a 125 giving them A1, they used that theory pass to take their Full A test.
Sam Millar
PostPosted: 18:05 - 09 Jun 2018    Post subject: Reply with quote
Sorry, I meant I had passed my Theory in 2014, and then past my ‘A2’ a couple of months before the two year expiry.
My question was do I now need to sit another theory test before I can sit my Mod1 or Mod2 tests for my ‘A’?
Kentol750
PostPosted: 18:15 - 09 Jun 2018    Post subject: Yes Reply with quote
Yes. Unless you wait for the 2 year period to finish. So, it depends how desperate to get it done before then.
Some bikes.
Sam Millar
PostPosted: 19:20 - 09 Jun 2018    Post subject: Reply with quote
Does a valid theory have to be current for Mod1 or can I do that and wait until I’ve completed two years as an A2 rider and then do my Mod2 without having to sit another theory?
Kentol750
PostPosted: 19:45 - 09 Jun 2018    Post subject: Theory Reply with quote
You need the theory for mod 1. Have you looked into booking a test, you can't book and put your name to a test without a theory pass against your name on the system.
Some bikes.
Sam Millar
PostPosted: 20:27 - 09 Jun 2018    Post subject: Reply with quote
I had my first assessment today with a local school, he said there was no issues what so ever and when we got back to the school there had been a cancellation and he asked if I wanted it. I said yes as we had previously been talking about tests and he said I'd be waiting into middle of July for a Mod1.
Looks like i'm gonna have to phone and cancel on it! So if I wait until I've been passed my A2 for two years, I no longer have to sit the tests or just have a theory?
Kentol750
PostPosted: 20:39 - 09 Jun 2018    Post subject: Test Reply with quote
Once you pass the 2 year point, you can then do a mod 1 and mod 2 on a full power bike, without needing the theory test. (Didn't the instructor try to put your driver number to the mod 1?)
Some bikes.
Sam Millar
PostPosted: 21:23 - 09 Jun 2018    Post subject: Reply with quote
No I think he just pencilled me into it as I was under the impression my theory was till valid until I got home and checked. I'll be calling him first thing tomorrow to let him know that's not the case.
Will just wait it out as it's only about a month or so until I've passed the two year mark.
I can't believe how silly it is about having to sit these tests again. I passed on a restricted MT07 and will be taking the tests on unrestricted MT07s. The exact same tests on the same bikes, albeit unrestricted - but you hardly use the top end of the power on a test. Rolling Eyes
PostPosted: 06:30 - 10 Jun 2018    Post subject: Reply with quote
Kentol pretty much covered it and ass Rogerborg said. It is something that makes no sense.
If you are upgrading from A2 to full A and have held a full A2 licence for 2 years or longer then you do not need a valid theory test.
If you are upgrading due to age and have not held your A2 licence for 2 years or longer then you must have a valid theory test.
From the looks you either have to wait a little longer or resit a theory.
PostPosted: 07:40 - 10 Jun 2018    Post subject: Reply with quote
pinkyfloyd wrote:
ass Rogerborg
Shocked Crying or Very sad
The thing is, I reckon it's entirely up to DVSA Derek on the day whether he lets the test go ahead.
Derek may not know about the insane situation of there inevitably being a period when your theory has expired but you're not quite eligible for A2 -> A progressive access.
Or Derek may not care, because it is insane. I mean, think about it: waiting another month for you to forget even more about what you learned for the theory test means that... you don't need to re-do the theory test. Brick Wall
If you were DIYing it, I might gamble £15.50 on mod 1 to find out, but if you're paying a training school, I'd want to be sure.
Kentol750
PostPosted: 08:45 - 10 Jun 2018    Post subject: Test Reply with quote
OP, the easiest thing to do is to ask the instructor to try and put your driver number against the test. It should flag up if you have no theory pass. If you get on the system, you go for the test. Chances are the school can cancel if not the case. Doesn't cost to try and book it. After that, it's your money to turn up and see if Rogerborg's theory works.
Some bikes.
PostPosted: 08:54 - 10 Jun 2018    Post subject: Reply with quote
Warranty void where applicable.
The last post was made 7 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 101.02 Kb
