Engine/exhaust decoke
simon1221
PostPosted: 20:19 - 17 Mar 2005    Post subject: Engine/exhaust decoke Reply with quote
1) Can i do this myself?
2) If not then how much at the garage?
3) What is it?
DNA50 (sorry) ->> TZR125l >> GPZ500S
PostPosted: 20:31 - 17 Mar 2005    Post subject: Reply with quote
It is the act of removing any sooty black carbon deposits from your engine, the crown of the piston and the powervalve (if fitted). These are the result of burning oil in with the fuel in a 2-stroke.
Exhaust: 2 ways, if the baffle in the end of the exhaust system is removeable, take it out, pour petrol over it and set it on fire. Once it has cooled, remove any remaining carbon using a wire brush.
Other way is to remove the whole exhaust ststem, fit a bung in one end and fill it up with caustic soda solution (goggles, gloves!). Leave it to soak for 1/2 an hour then empty it out and rinse through with clean water before refitting.
Piston: Drain the coolant. Take the cylinder head off, set piston to top-dead centre. Scrape the worst of the carbon off with an old screwdriver then clean up with some emery paper. Be carefull not to mark the actual metal. Remove the loose debris with a hoover or some blue-tak. Refit cylinder head using a new gasket. Refill coolant
Powervalve: Never done it myself.
mchaggis
PostPosted: 20:56 - 17 Mar 2005    Post subject: Reply with quote
NaOH(aq) + C(s) -> ?
I must not be a troll...
Mmmm, Guinness
PostPosted: 21:02 - 17 Mar 2005    Post subject: Reply with quote
Don't think it is a reaction as such, there are unburned hydrocarbons there too sticking the carbon together. I thought it was more of a 'soap' type hydrophobic thing allowing the carbon/oil mush to be suspended in the water.
The last post was made 21 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 40.5 Kb
