Pitted fork repair, degreaser?
Riejufixing
PostPosted: 13:41 - 01 Jul 2018    Post subject: Pitted fork repair, degreaser? Reply with quote
What's a good degreaser to flush out the small pits in the hard chrome coating?
It looks as though I'll have to araldite the poxy things. What causes pitting? Bad manufacture? Stone hits?
OTOH replacement "fork pipes" (Rieju RS3 125) are £37 each.
Teflon-Mike
tl;dr
PostPosted: 15:11 - 01 Jul 2018    Post subject: Re: Pitted fork repair, degreaser? Reply with quote
Poor steel, poor chrome, poor manufacture would be the top choice on a Spanish built bike.... except I own a Spanish built bike that's over 30 years old, with good forks... so be unfair to blame that as sole cause.
Fact is that its a little bike, built down to a cost, with more emphasis on looks and performance than how long it will last, and build quality in general is not what it once was... but wont help none.
Stone hits are interesting idea.. and oft blamed.... but hint is in the name, its 'hard chrome'... take a pair of chrome handlebars to a powder coaters and ask if they will sand-blast and dip them... they will often refuse because even the 'soft' decorative chrome will stand a heck of a lot of blasting... and that stuff is a heck of a lot sharper than a pebble, anmd chucked out the blasting nozzle oft close to or beyond the speed of sound..... I doubt that a 4-stroke 125 will ever get up anything like the sort of speed that the impact of a stone will have the same destructive force Lol! May help chip already flaking chrome off, but you can hit a fork leg with a lump hammer and not damage the chrome coating... might dent the steel beneath... but you wont do much to crack the chrome, so I think you can discount that idea.
MAINTENANCE! Most steel will rust from the inside; cars, bike petrol tanks, that's how they tend to 'go' and forks aren't a lot different; when the chrome starts to go they go from rust under the chrome not above... but, if you dont keep them clean, then any opportunity rust has to get into or under the chrome will be the most significant factor on flaking and pitting.
That seems a pretty reasonable price to me; and a certain 'fix'. And if they are readily available and that's all they cost, I wouldn't be in much of a hurry to try employ a bodge!
Do it once, do it right, do it on the cheap, and forever re-do!
The araldite dodge works, but whatever made the chrome come off will make the araldide come off, sooner or later, and likely the sooner.
Meanwhile, more significant question is what state are teh forks seals if they have been riding over sand-paper rough pitting every time they try work?
In the grand scheme, a new pair of forks seals are usually under a tenner, fork oil not a lot more; and most of the work, especially in a pair of up-side-down forks like the Riajuy has, is in the stripping and rebuilding...
For the money fork legs cost, why bodge why not bite the bullet, do job properly and only have to do it once and likely never have to worry about it again.
Its not like its a rare machine parts are no longer available for or that where they are they are stupid prices, and you have little option but try salvage what you got.
See above... the whole plan is flawed, and you aren't going to effect a very permenant bodge; and even if you get 'best' adherance between the steel beneath and the epoxy, its still not as hard as the chrome it will still get worn away or fall off when chrome around starts to flake.
And there's bigger fish to fry than what degreasant, like what wet and dry to nib back to metal; how hard, how deep is the pit and how much penetration will you get of the araldite...
If I had to employ the bodge 'cos I couldn't get replacement stansions, after nibbing back and degreasing with soap and water.... I'd likely use methalated spirits that will evaporate as last 'wipe'.
B-U-T... if the rust isn't that bad, and fork seals still sealing, I would likely do nothing but clean with soapy water and polish.... and leave the job until it really needed doing, and then do it properly with new legs.
Riejufixing
PostPosted: 16:44 - 01 Jul 2018    Post subject: Re: Pitted fork repair, degreaser? Reply with quote
Lots of things get pitted forks, so perhaps it's not Spanish manufacture (unsure where Rieju's forks are made, engine is Yam with badge-engineered clutch cover, some forks are Showa). I think stones must be favourite - a dent to the steel could crack the chrome microscopically, then water gets in, rust pimples the chrome, seals truncate pimples.... anyway.
This is a "Cat C" rebuild. I might just get a pair of stanchions, as I've saved money by buying "Brake Lever Gear Shift Pedals Adapter" for less than £4 from China, gear+brake rubbers/spindles were snapped off but levers still OK.
The seals are ofc knackered (well, one leg is, other OK but chrome is still pitted, so...). A tenner off eBay for seals & dust covers (twice that from Rieju but they will be NAK seals... not AKA).
The forks are dead easy to dismantle:
1) Remove wheel spindle.
2) Pull down dust seal (blunt kitchen knive edge/lever/use fingers).
3) Prise out circlip.
4) Undo fork top nut (27mm).
5) Push up lower fork leg, loosen lock nut.
6) Remove fork cap nut.
7) pull out bottom of fork leg including stanchion.
I'm not keen on using meths. as a solvent, will try some of the MEK I have ordered to repair the mudguard, it is an aggressive solvent. Thinners is possible too.
Your last suggestion is a possibility; round the edges of the pits, fit new seals, and see how long they last.... Smile
MCN
PostPosted: 17:03 - 01 Jul 2018    Post subject: Reply with quote
Poor Manufacturing.
The process to chrome plate is to grind. chrome and grind again.
The eletro plating does not leave a brite finish so the final part has to be polished.
The process uses a lot of harsh chemicals that are not environmentally friendly or cheap.
Some companies cut corners.
The most common corner is how long the part is is the plating tank.
The longer it is in the thicker the coating.
There are also savings to be made in the under-layers or priming layers.
They acid bath, then nickel plate the help the chrome stick.
Less acid, less nickel, less chrome.
Islander
PostPosted: 17:16 - 01 Jul 2018    Post subject: Reply with quote
I've used the Araldite fix a couple of times and found ordinary brake cleaner applied with a toothbrush effective. Before you clean it, use some fine wet & dry to flatten off any edges on the pits. Gaiters are a good idea to protect the stanchions from further damage. Thumbs Up
WD Forte
PostPosted: 18:20 - 01 Jul 2018    Post subject: Reply with quote
I've used the epoxy method on unobtainium and "how feckin much?"
forks, but for 37 quid each would cough up the dosh.
bikers smell of wee
A100man
PostPosted: 14:20 - 03 Jul 2018    Post subject: Reply with quote
Indeed so. I'm pathologically mean and a dedicated bodge-meister but I would shell out that much in the blink of an eye. For the GT250 I have in my hands right now , new legs are at least £125 each for new or £180 a pair for re-chrome...
J
johnsmith222
PostPosted: 16:03 - 03 Jul 2018    Post subject: Reply with quote
Definitely just replace them. It's always a hassle to have damaged fork seals, so better just get it sorted in 1 go, rather than going down the bodge method.
PostPosted: 00:06 - 04 Jul 2018    Post subject: Reply with quote
In response to the OP,. Brake cleaner, TCE, Isopropyl alcohol.
BusterGonads
PostPosted: 11:57 - 04 Jul 2018    Post subject: Reply with quote
Last year, I got a gallon of that delivered from Amazon for £15. A great degreaser I've found. I also used it as a steriliser for my cut throat razor when I used it to do minor surgery in removing a wart.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
The last post was made 8 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 70.95 Kb
