YBR Cutting out issue
onlyJaz
PostPosted: 13:27 - 02 Jul 2018    Post subject: YBR Cutting out issue Reply with quote
When I start the bike, the revs fluctuate and then sit a bit low hows and many times if I try to open the throttle even a tiny bit then it will cut out the engine. I used to think it was only cold weather but it's happening when hot too. Once the bike has warmed up it's fine.
Also the engine light comes on at random times (not flashing) any thoughts what it could be?
UPDATE: Yesterday's ride, it cut out many times to the point I was worried about stopping - I guess it helped me get home quickly Mr. Green - Engine light more frequent now.
Link here:
https://www.youtube.com/watch?v=7KrgicItbNY
Yamaha YBR 125
onlyJaz
PostPosted: 13:43 - 05 Jul 2018    Post subject: Reply with quote
Any clue?
Yamaha YBR 125
Fizzoid
PostPosted: 13:51 - 05 Jul 2018    Post subject: Reply with quote
Fault codes are stored on the ECU , these will be shown via the engine fault light on the dash board
as a series of flashes of the light .
The engine management light will come on for 3 secs every time you start the bike , if the light does not come on replace the bulb at rear of clocks .
Codes are all 2 digit numbers , the first number will be read by long flashes of the light , the second
number of the code with be in short flashes of the light .
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Ignition coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - ECU malfunction
Fault code 51 - Diagnosis cooling fan motor relay
Fault code 52 - Relay diagnostics lamp head light
Rogerborg wrote: It'd certainly make it easier to ego-find my own posts on pages, given the number of fags (gay like traps) who insist on putting my name in their .sig
zark
PostPosted: 03:32 - 06 Jul 2018    Post subject: Reply with quote
no idea, but 99% of starting/running issues on my YBR were solved by charging or replacing the battery.
got a known good one you can try?
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
ThatDippyTwat
PostPosted: 05:48 - 06 Jul 2018    Post subject: Reply with quote
Hot weather. Fuel pump, They play stupid on 125's and 250's - have a google around if the bike doesn't seem to have codes stored.
Check your oil levels as well. Handbook tells you exactly how to do it.
Fizzoid
PostPosted: 07:57 - 06 Jul 2018    Post subject: Reply with quote
It's certainly an issue on my YBR at the moment. It won't prime when it's hot, I've resorted to having to cover the tank when I park it up in a morning
The last post was made 8 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 48.66 Kb
