Gear lever moves and clicks but wont shift
bekjoek
PostPosted: 20:35 - 05 Jul 2018    Post subject: Gear lever moves and clicks but wont shift Reply with quote
Hi!
I have a Ktm 125 2015 mod.
When I try shifting it upwards, the shift lever goes up and I feel a small resistance just like it will shift upwards, but then it just looses the resistance and goes up until it stops. It only work to gear upwards sometimes when I am reeeally careful while pressing my foot upwards on the lever.
Dowhshifting is totally fine, but it tends to make a big click when shifting down.
What can the problem be? How can I fix it?
Thanks for answers.
PostPosted: 05:40 - 06 Jul 2018    Post subject: Reply with quote
Sounds like a bent pawl. Heavy-footed gear changing is one possible cause so go easy on your gear pedal once you get it fixed.
On most bikes the pawl mechanism can be found inside the clutch cover to the rear but I have no knowledge of KTM's so you'll have to research that for yourself.
bekjoek
PostPosted: 07:56 - 07 Jul 2018    Post subject: What is a pawl? haha sorry i am not english Reply with quote
    Enduro Numpty
    PostPosted: 08:44 - 07 Jul 2018    Post subject: Reply with quote
    The gear change detent lever is/was a weak point on the KTM 125SX/EXC. It sits behind the clutch. There's a small roller bearing that locates in the shift drum and keeps it in gear and gives you the positive click when shifting. It can disintegrate and do a lot of damage.
    I'd check this as a matter of urgency. A relatively inexpensive, easy repair could turn into a lot of internal damage if bits of bearing are rattling around in the clutch area. I know this from experience!
    Enduro Numpty
    PostPosted: 08:45 - 07 Jul 2018    Post subject: Reply with quote
    arry
    PostPosted: 08:46 - 07 Jul 2018    Post subject: Reply with quote
    Have a watch of this. I know your symptoms aren't quite the same, but I'd suggest it's worth a look.
    https://www.youtube.com/watch?v=4KQRcReVVPQ
    The last post was made 8 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
    Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 46.69 Kb
