Old Forks and Oil
Suntan Sid
PostPosted: 12:12 - 06 Jul 2018    Post subject: Old Forks and Oil Reply with quote
I have just replaced the fork oil seals on my puny project bike, (show and tell update soon), here is a diagram of the fork internals:-
https://images.cmsnl.com/img/partslists/yamaha-gt80-1975-usa-front-fork-front-fender_bigyau0819c-4_c577.gif
On this particular bike there is only one fork spring, the other fork leg has no spring just a simple damper.
In the service manual it specifies the quantities of oil for each leg, 90cc in the l/h fork and 120cc in the r/h fork.
Logic dictates that I should be putting more oil in the fork leg without a spring and less in the fork leg with a spring.
In the service manual it merely gives l/h and r/h quantities but doesn't specify which fork has the spring in.
To confuse me even further, the previous owner had marked the fork legs "left" and "right" the right leg had the spring in.
So is my logic correct, do I put more oil in the leg with no spring?
fatjames
PostPosted: 13:08 - 06 Jul 2018    Post subject: Reply with quote
What bike is it? Although, I'm not sure I can google any better than you..
Nobby the Bastard
Harley Gaydar
PostPosted: 14:09 - 06 Jul 2018    Post subject: Reply with quote
As the exploded picture has the lhs exploded and displaying a spring, I'd assume the spring is supposed to go in that side.
Edit: If you look at the drain screw, it should be on the front, but it's on the back of the exploded view so RHS.
Edit 2: Do they both have as drain screw at the bottom?
Triumph Sprint ST 1050
temeluchus
PostPosted: 17:16 - 06 Jul 2018    Post subject: Re: Old Forks and Oil Reply with quote
No. The spring takes up some of the free volume in the fork, so I would think the smaller amount would go in that fork.
Ed Case
PostPosted: 17:42 - 06 Jul 2018    Post subject: Reply with quote
Been into bikes for decades but never come across front forks with only a spring in one leg, have you removed the fork cap on the supposedly 'empty' leg to check ?, I certainly would.
Suntan Sid
PostPosted: 19:32 - 06 Jul 2018    Post subject: Reply with quote
The bike is a Yamaha GT50, you can see it in this thread:-
https://www.bikechatforums.com/viewtopic.php?t=323620
No there are no drain screws, the only way to drain the forks is to remove them from the bike and hold them upside down. unfortunately I can't find an online diagram for the specific model but, I know for a fact, (I have a hard copy of the Official Yamaha parts list that covers the 50cc and 80cc versions), that they are the same as the diagram, apart from the drain screws.
Yes, there is only one spring, that's the way it came from the factory!
Err, that's what I was alluding to, less oil in the fork with the spring, for the reason you stated..
temeluchus
PostPosted: 22:00 - 06 Jul 2018    Post subject: Reply with quote
Oops misread that entirely for some reason. Probably the heat.
The last post was made 8 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 55.13 Kb
