Intermittent indicators
XT65
PostPosted: 12:24 - 07 Jul 2018    Post subject: Intermittent indicators Reply with quote
Good afternoon all
I'm having a problem with indicators on a Honda XR 125 L6.
They work sometimes and then don't.
I've cleaned the switch relay is good and so is it shorting out somewhere or wouldn't they work at all if that was the case?
What should I be thinking in this situation.
I'm not sure it's relevant but it seems to happen in this warm weather,but I can't believe it could be temperature related .....Or could it be??
Where to start?
When they work all the dash lights are working as well.
When they dont,neither flashers or dash work btw.
Cheers all!
Courier265
PostPosted: 13:21 - 07 Jul 2018    Post subject: Reply with quote
The relay is dying, I've had the same thing happen on CB250 a few times.
Replace it soon as possible and don't buy a cheapo, buy a genuine Honda
relay, yes I know they are very expensive but those cheapo's don't last long.
XT65
PostPosted: 13:53 - 07 Jul 2018    Post subject: Reply with quote
[quote="Courier265"]The relay is dying, I've had the same thing happen on CB250 a few times.
relay, yes I know they are very expensive but those cheapo's don't last long.[/quote
Thanks mate yes I agree best to get the proper Honda one.
What causes dying as opposed to just stopping working?
Courier265
PostPosted: 14:01 - 07 Jul 2018    Post subject: Reply with quote
The relay simply wears out, so far I've never had one that simply packed
up all of a sudden. (when using a genuine part)
PostPosted: 14:48 - 07 Jul 2018    Post subject: Re: Intermittent indicators Reply with quote
They're supposed to go on and off.
BusterGonads
PostPosted: 23:23 - 08 Jul 2018    Post subject: Reply with quote
When I got my recently acquired year 2000 CG125, I had intermittent indicators. I cleaned up all the contacts and clips and the problem remained, so I took off the cover exposing the circuit board and looked around the circuit with a magnifying glass. That's when I found a cracked solder joint where one of the contacts connecting it to the loom joined onto the circuit board. This cracked joint meant that sometimes there was a connection and sometimes not. Vibration I expect, or maybe rough handling when it was being connected up at some time after it had been removed. Anyway - I re soldered the contact to circuit board connections and it has worked reliably ever since. There is very little inside the circuit more or less just a transistor switch and a relay and a couple of resistors to bias the transistor.
Flasher units aren't expensive items so this wouldn't be worthwhile if you had to go out and buy a soldering iron, but I already have a few of those, so the job only took two minutes and cost nothing.
It is worth taking a look if you have the gear. The case on my Honda one comes off easily by prying the outer casing over a couple of small lugs on the base of the unit.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
XT65
PostPosted: 02:06 - 09 Jul 2018    Post subject: Reply with quote
The circuit board. Inside the relay do you mean?
Teflon-Mike
tl;dr
PostPosted: 03:42 - 09 Jul 2018    Post subject: Re: Intermittent indicators Reply with quote
Reminds me of the QS on a building site I once worked on, asking Liam to check the lamps were working when he hitched up a compressor.... Laughing
BusterGonads
PostPosted: 08:58 - 09 Jul 2018    Post subject: Reply with quote
Inside the little black box with the connectors on it. They look like this only mine is black and has three connector plates on it.
The actual 'relay' is a much smaller component inside the case and mounted on a circuit board with a few other bits to drive the relay. If you have a soldering iron and a bit of new solder, you have nothing to lose by having a look at the inside. It might not fix, but mine was an easy repair where the solder attaching the pins to the board had cracked and was making intermittent contact.
https://www.mandp.co.uk/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_1017_1_5631_1_167_1_14_1_1_1_2_1_6663.jpg
XT65
PostPosted: 14:15 - 09 Jul 2018    Post subject: Reply with quote
Yes that's what I thought you meant....
Good idea sure I'm good with soldering,hadnt thought of that as I thought they were sealed units..
I've ordered a new one but I'm going to have a look in there as you suggest as you're right about a wire bouncing around feeling, and that it could actually be INSIDE the unit...
I'll let you know how I get on.
Cheers mate good shout!
The last post was made 8 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 69.23 Kb
