Stretchy Chain
insomniac
PostPosted: 12:27 - 07 Jul 2018    Post subject: Stretchy Chain Reply with quote
Hello
I'll admit now that I know nothing about bike maintenance. So the following might seem silly to some.
I have a Suzuki 650DL L4
I have just come back from a 1400 miles trip around a bit of Ireland (the wild Atlantic Coast road, a must Very Happy ). Whilst on my way there I noticed that the bike was making a rattling sound. I guessed that the chain needed adjustment as the garage where I get it serviced does have a habit of leaving a little too much slack.
Anyway it was getting worse by day 3 of my trip so I called into a garage and we adjusted it. The rattling got notably less and the bike behaved better around corners especially.
However by the time I got home last night the chain was rattling like mad.
I went to adjust it again this morning and I found that to get the chain to the 2-3cm movement its supposed to have I have moved the wheel back as far it will go (using the adjusters)
I have had the bike 2 years, the chain was new when I bought it, I have only done about 7000 miles in total.
The people I was riding with, their bikes had done 20,000+ miles on their chains without the need for much adjustment at all.
Would a chain stretch that much? Was the wrong chain put on in the first place?
Most people seem to put in when they've past what so here goes.
CBT: 16/09/12; Theory: 20/02/13 MOD1:20/05/13 MOD2:29/05/13
Suzuki Marauder GZ125; Suzuki Intruder VL800
Nobby the Bastard
Harley Gaydar
PostPosted: 12:29 - 07 Jul 2018    Post subject: Reply with quote
What is your oiling regime?
Triumph Sprint ST 1050
PostPosted: 12:53 - 07 Jul 2018    Post subject: Reply with quote
Was the chain adjuster as far forward as possible when the chain was fitted?
kramdra
PostPosted: 12:56 - 07 Jul 2018    Post subject: Reply with quote
That is no good and a decent chain set should last much longer. Is the front sprocket excessivley worn? I find this is normally what causes chain noise -rather than the slack. I typically set my chain at 45mm and it will never need adjustment. If it is a large ratio chain reduction then the front will wear much quicker
I swap front sprockets about 15k and expect the chain and rear to last 35k. However I oil it daily and most people call the amount I use excessive.
Courier265
PostPosted: 13:15 - 07 Jul 2018    Post subject: Reply with quote
Lubed Daily? I would probably do the same if I was doing 500 miles a day.... Rolling Eyes
insomniac
PostPosted: 13:29 - 07 Jul 2018    Post subject: Reply with quote
I do not lube my chain after every trip out but I do clean it after every two or three trips out, whether it be just a few miles or a bigger trip like the last one.
When I clean it I wipe it down, get a tooth brush and WD40 to get all the bits off and then lube it.
As for the front sprocket, I think it looks ok, but I'm not an expert, they are not sharp or too pointy and there is no play in it on the spindle coming out, the back one looks fine too, with roughly 2mm of head on the top.
If a cheap chain was fitted would that stretch as much as this? or can you buy chains that you adjust the length on? (you can tell I haven't been doing this long)
The bike is fitted with scot oiler, which I do top up and there is oil coming out onto the rear sprocket (where the tube is located, so that is working)
PostPosted: 13:31 - 07 Jul 2018    Post subject: Reply with quote
Probably a Chinesium chain, and you should bin the chain and sprockets and fit something brand-namey or else instadeath follows.
However...
If it lifts clear at the back of the rear sprocket, it's done.
If not, if it's just slack in the middle, and the sprockets are OK, then I would chop a couple of links out and see how much longer you can eke it out. As Ste says, it may have been too long when fitted.
PostPosted: 13:48 - 07 Jul 2018    Post subject: Reply with quote
OP for mod because they said what bike it is at the start of their post.
Courier265
Agreed on this, start again with a decent chain and sprocket kit, cost
wise, about £100 - £135
PostPosted: 13:50 - 07 Jul 2018    Post subject: Reply with quote
https://www.bandcexpress.co.uk/buy/Tsubaki-Chain-Final-Drive-Kit-with-Renthal-sprockets-%28hard-anodised-rear%29-and-Tsubaki-Alpha-X-Ring-Gold-/3188.HA.APX.8B4#eq1
Courier265
PostPosted: 14:11 - 07 Jul 2018    Post subject: Reply with quote
Click Ste's link at your own risk Laughing
jaffa90
PostPosted: 15:33 - 07 Jul 2018    Post subject: Reply with quote
Are you checking the chain tension / slack unladen or laden?
kramdra
PostPosted: 17:59 - 07 Jul 2018    Post subject: Reply with quote
Measure 10 links of the chain and someone less lazy than myself.. can look it up and say if the chain wear is the problem.
Replace with did vm525/530. Replace sprockets
RhynoCZ
PostPosted: 20:52 - 07 Jul 2018    Post subject: Reply with quote
It's every 500 km OR after a ride in rain. Wink
Courier265
PostPosted: 21:47 - 07 Jul 2018    Post subject: Reply with quote
Don't you mean MILES?? Rolling Eyes
tom_e
PostPosted: 11:02 - 08 Jul 2018    Post subject: Reply with quote
As he's in a country that doesn't use Miles as a measurement probably not.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:41 - 08 Jul 2018    Post subject: Reply with quote
As ste insisted on telling me yesterday, it's an old man's piece of kit, but scotoiler, scotoiler, scotoiler.
You'll wonder how you managed before you got one.
RhynoCZ
PostPosted: 11:45 - 08 Jul 2018    Post subject: Reply with quote
Nope, kilometers or 312.5 miles.
Like the vast majority of this planet. Laughing
flearider
PostPosted: 16:47 - 08 Jul 2018    Post subject: Reply with quote
[quote="RhynoCZ"]
but the vast majority are not in the uk so it does not matter
as we are the centre of the civilized world Razz
jaffa90
PostPosted: 00:15 - 09 Jul 2018    Post subject: Reply with quote
Looks like the poster has gone to sleep!
PostPosted: 08:52 - 09 Jul 2018    Post subject: Reply with quote
I always presumed Lincolnshire was part of the UK, obviously I have been ill informed. Thinking
The last post was made 8 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 113.4 Kb
