headlight
andyj50
PostPosted: 21:03 - 09 Jul 2018    Post subject: headlight Reply with quote
wonder if anyone can help I cant get my dipped beam to work on my gsx1400 every thing else works fine wiring is ok bulb is ok just no dipped beam any help would be useful thanks
andy j
jaffa90
PostPosted: 22:50 - 09 Jul 2018    Post subject: Reply with quote
Is the relay switch being activated with the handle bar switch?
andyj50
PostPosted: 23:11 - 09 Jul 2018    Post subject: Reply with quote
would check it if I new where it was located
andy j
Kawasaki Jimbo
PostPosted: 00:14 - 10 Jul 2018    Post subject: Reply with quote
Has the dipped beam filament in the twin-filament bulb blown? New bulb required.
WD Forte
PostPosted: 16:07 - 11 Jul 2018    Post subject: Reply with quote
Of course we can help you.
Firstly:
What were the results of your tests with a meter?
bikers smell of wee
Kentol750
PostPosted: 00:00 - 12 Jul 2018    Post subject: Reply with quote
Change bulb? Looking ok and working are 2 different things.
Some bikes.
Confusion
PostPosted: 16:53 - 12 Jul 2018    Post subject: Re: headlight Reply with quote
The most common cause of headlight faults on Suzuki bikes
of that era is a bad connector. Check the connector blocks
near the front-end of the bike.
Ok, that rules out the battery, main fuse and ignition switch.
How do you know the wiring and bulb are ok?
Assuming the GSX wiring is similar to the GSF (Bandit),
The circuit is:
Ignition switch
Starter button/switch (to kill headlight when starting)
Dimmer (high/low) switch
Fuse for Headlight (Lo)
Bulb connector
A few minutes with a voltmeter will find the fault.
Bandit 650SA, ZZ-R1100
The last post was made 8 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 49.74 Kb
