Potholes shaking parts loose?
andym
PostPosted: 13:30 - 11 Jul 2018    Post subject: Potholes shaking parts loose? Reply with quote
Today is the third day in a row trying to get the ninja running properly.
So far the fuel pump has been replaced, secured HT leads, stripped and cleaned the starter motor, secured HT leads (again)... after a few minutes riding again it would idle at the lights for a few seconds then fade out.
Today I decided to try securing the HT leads and check none of the spark plugs were loose... problem leads were 2 & 3, but I found plugs 1 & 4 weren't even hand tight Evil or Very Mad
Tightened everything up, took it for a test ride and it ran great, got back home and as I was opening my lockup.... the engine faded out again.
This is the end of my road:
https://goo.gl/wDBrVG
Quite a lot of the roads are like that around here, so could this be shaking parts loose?
PostPosted: 13:51 - 11 Jul 2018    Post subject: Reply with quote
So the plugs are coming loose? I seriously doubt it's vibration, the plugs stay in my enfield and i've seen me ride my VFR 10 miles along forestry tracks to go camping.
I wonder if the crush washers are beyond re-use. I'd try new plugs/caps if they are coming loose.
u33db
PostPosted: 13:57 - 11 Jul 2018    Post subject: Reply with quote
Maybe you're not tightening the plugs enough?
If you're doing them by "feel", maybe try using a torque wrench instead to be more accurate?
PostPosted: 14:46 - 11 Jul 2018    Post subject: Reply with quote
I personally wouldn't recommend that. I seriously doubt most people have a torque wrench that would go low enough anyway.
Sparkplugs with a crush washer go in finger tight + 1/4 turn the first time you fit them, finger-tight then 1/12 of a turn the next time you fit them. There will be variations on this according to size but it's usually printed on the box.
No tighter that that. I've been doing that for over 20 years and have never had one come loose or (*touches wood*) stripped a thread out.
andym
PostPosted: 14:51 - 11 Jul 2018    Post subject: Reply with quote
That's usually what I do and I've never had a problem with them coming loose before... until now that is.
I don't think I've even done 1,500 miles since they were replaced... mind you they haven't been checked since then either
PostPosted: 16:24 - 11 Jul 2018    Post subject: Reply with quote
How are the threads? A lot of kawasakis have deeply recessed plugs that can become a real water trap. Have the alloy worms been at it?
u33db
PostPosted: 18:49 - 11 Jul 2018    Post subject: Reply with quote
Err...if you check NGK's website they give recommended torques;
https://www.ngkntk.co.uk/index.php/technical-centre/spark-plugs/tightening-torque/
Its usually in the region of 20 Nm depending on plug size which is within range for most smaller torque wrenchs...e.g. halfords smallest goes 12-60NM IIRC, yet their largest goes 60-300NM.
PostPosted: 19:56 - 11 Jul 2018    Post subject: Reply with quote
Fair do's. Hadn't ever seen that. Equally, there is no way in holy hell I'd wind a sparkplug up to that kind of torque in the alloy head of any of my bikes. I'd fully expect it to keep turning and never hear a click.
The last post was made 7 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.12 - MySQL Queries: 13 - Page Size: 60.53 Kb
