| jordanrbaker |
 jordanrbaker L Plate Warrior
| P.addy |
 P.addy Red Rocket
| rhys99 |
 rhys99 Scooby Slapper
| stirlinggaz |
| ThatDippyTwat |
 Posted: 18:45 - 13 Jul 2018 Post subject: |
| stirlinggaz wrote: | just my opinion, ignore it you want |
You should ignore it - He doesn't know how expansion chambers work.
It won't free up power. Expansion chamber are both sized and shaped for sepcific applications. If a chamber is too big or small, bad things happen, but you will, at the very least, lose power, not gain any. If it's shaped incorrectly, it will effectively "move the powerband" to different areas in the rev range.
If you want to know how they work, there are plenty of papers/videos that give an overview of it. I hope you like maths if you want details.
Now, if it's the endcan, then you may get away with it. Just be aware that a can made for a crosser is going to be loud as fuck, and will probably get you pulled by the police. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| stevo as b4 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:37 - 13 Jul 2018 Post subject: |
I fully advocate buying the most expensive exhaust that you can find.
Then when it doesn't fit, or fvcks the fuelling, ask again in the Workshop section. ____________________ Biking is 1/20th as dangerous as horse riding.
| jordanrbaker |
 Posted: 21:36 - 13 Jul 2018 Post subject: |
| rhys99 |
| stirlinggaz |
 Posted: 18:40 - 15 Jul 2018 Post subject: |
| ThatDippyTwat wrote: |
Now, if it's the endcan, then you may get away with it. Just be aware that a can made for a crosser is going to be loud as fuck, and will probably get you pulled by the police. |
Hi,
how the hell do you presume I don't know how expansion chambers work?
i have access to same calculations & formalae as you &
I probably own more 2t bikes than most ppl.
& my point was, a pipe meant for a standard 50cc will be a restriction on a bike with 80cc & a bigger carb.
you can't disagree with that?
since the op stated 80/80cc exhausts were cheap? why not try 1?
have you ever tried it. I have. with dyno prints to prove.
I agree it might move the powerband, although in my experience stinger length has more of an effect here.
I did say a pipe for a cr80 would probably be unsuitable.
what would be ideal is a custom made expansion chamber but price might be prohibitI've.
if ppl don't try new things, they don't learn anything.
cheers,
GAZ |
| stevo as b4 |
 Posted: 20:34 - 15 Jul 2018 Post subject: |
I wouldn't sweat it, that's the problem with 2strokes, every fucker out there thinks they know what they are doing and how to tune them.
We can all read a few books, surf the forums and speak to tuners, and then we all think we know it all and can build the perfect motor that's got explosive performance in our sheds.
I sometimes think I've got something sussed out and know how it works and what to do with it. Reality is I know fuck all about them and what makes a great motor. The more you read and learn about them the more complicated and involved you realise they are and the less you understand about what's going on.
Unless someone has their own dyno, and machine shop and a decent supply of engines to play with, the chances are we'll always know fuck all about what's going on inside and what effect changes to things will make.
For the keen diy tuner with access to such services, it could take 5years of playing and experimenting to take say a 55bhp 250cc to 65bhp.
Sorry to OP for off topic, but you can get good aftermarket big bore suited pipes for the Derbi engine, I'd buy one and set up the carb and ignition to suit, instead of messing about with old cut and shut MX pipes, unless you've got access to the above services? |
The last post was made 8 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
