Suzuki Bandit 600 fork seal replacement
Ziggy81scott
PostPosted: 13:25 - 14 Jul 2018    Post subject: Suzuki Bandit 600 fork seal replacement Reply with quote
I’ve been trying to replace the fork seals on my bike and have come into trouble getting the bolt out of the bottom of the fork slider without the fork cylinder spinning inside.
I believe there is a special tool for this job but as yet i can’t find one.
I tried to use a large nut welded to a socket and this worked on the first fork leg but the second leg seems to have been butchered by someone.
Any ideas what I can try or where to locate a special tool would be great.
Thanks👍
Riejufixing
PostPosted: 14:21 - 14 Jul 2018    Post subject: Reply with quote
Wedge with something (dowel, rawl bolt...) &/or use an air wrench?
kramdra
PostPosted: 15:06 - 14 Jul 2018    Post subject: Reply with quote
If it is butchered what makes you think the special tool is going to work...?
If you have got one apart then you'll be able to see and modify your tool to be a better fit, so that it can work on the other fork. Pics/measurements of the damper rod end may help.
Islander
PostPosted: 15:18 - 14 Jul 2018    Post subject: Reply with quote
I use an impact wrench - it'll remove the bolt with ease Thumbs Up
temeluchus
PostPosted: 20:05 - 14 Jul 2018    Post subject: Reply with quote
You can buy a damper rod holder or manufacture one out of a broom handle, but as Islander says an impact gun is far easier.
The last post was made 8 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 43.11 Kb
