Bike fails to start (no longer suspect battery)
LustyLew
PostPosted: 08:38 - 17 Jul 2018    Post subject: Bike fails to start (no longer suspect battery) Reply with quote
Morning all!
Tried to start the bike this morning and it wouldn't catch.
Bike would turn over, but that's it. Bike is a Yamaha TDM 900 '08.
I noticed that the LED screen would dim/go blank when hitting the starter and the FI pump didn't whirr into life when turning the ignition on.
This all suggest flat betters so tried to jump it from the car... Still no joy.
With/without jump leads attached the voltage across the battery terminals was 12.3v. Surely enough to get the bike going!
With the jump leads attached and the car running, still only 12.3v.
Is it possible the battery isn't taking a charge?
The last time this happened I managed to bump the bike and when the engine running at 4,000 rpm the reading across the batter was 14.4v so I don't think it's a reg/rec issue (unless it's intermittent).
So, first step, charge the battery & check all fuses.
Second step, replace battery.
What else should I be checking before passing it back to the dealer?
jaffa90
PostPosted: 09:17 - 17 Jul 2018    Post subject: Reply with quote
In warm weather a good modern battery should read 12.8v and 12.6v in cold the morning after, also check the battery connections to the bike.
PostPosted: 09:44 - 17 Jul 2018    Post subject: Reply with quote
I tend to do + to + and - on car to footpeg of bike.
I'd say 12.3 is too low for sure.
I also wouldn't run the car... but thats just me.
The fact it didn't fire up (assuming the car battery is good) means you didn't connect it properly as 12v is 12v and it would deem that as a battery attached to the bike, it doesn't know its 2 metres away and 10x the size.
LustyLew
PostPosted: 10:05 - 17 Jul 2018    Post subject: Reply with quote
I suspect you're right. I did try to re-seat the + terminal on the bike battery, no sparks were spotted which is unusual.
I'll know more tonight.
steve_
PostPosted: 11:38 - 17 Jul 2018    Post subject: Reply with quote
I had an issue with my battery where it would die while I was riding it!
I had to get the coil re-wound which solved the problem.
I ride with a spare battery and homemade jump leads now just incase.
LustyLew
PostPosted: 08:39 - 18 Jul 2018    Post subject: Reply with quote
Well bollocks!
The battery was fully charged last night. Dropped in to the bike this morning hoping all would be well. It was not.
Battery holding about 13v.
From a very brief look and listen.
Turn on ignition
Relay for fuel circuit clicks
Fuel pump doesn't run (high pitch whine for a few seconds normally)
Hit starter button
Starter relay clicks
Bike cranks but doesn't start (obviously)
The fuse for the fulfilling system is OK as again, the relay clicks on/off when insert/remove the fuse.
When I'm home this evening I'll pop the faring off to take a look at the relay and wiring. Make sure there's not damage there. If not, it's back to the dealer. Only PITA is it's 75 miles away via the god awful M25 and M3!
Brick Wall Brick Wall Brick Wall
jaffa90
PostPosted: 08:45 - 18 Jul 2018    Post subject: Reply with quote
What is the battery voltage when pressing the button?
LustyLew
PostPosted: 08:50 - 18 Jul 2018    Post subject: Reply with quote
About 12.3v
Islander
PostPosted: 08:56 - 18 Jul 2018    Post subject: Reply with quote
Not hearing the pump prime is sounding some alarm bells.
PostPosted: 10:17 - 18 Jul 2018    Post subject: Reply with quote
Is sounding like fuel pump is a no no.
Can you provide power to just the fuel pump. I have a plug on mine which goes in to the loom on a connector, you can just feed it power and it'll make noises.
LustyLew
PostPosted: 11:28 - 18 Jul 2018    Post subject: Reply with quote
I'll have a go tonight and see what I can do.
Interestingly, I did read somewhere that too many keys on the bunch can cause issues. I must admint on the Tenere and MT-03 I used to just have the ignition key on its own, so I'll give that a shot too...
Kris
PostPosted: 12:15 - 18 Jul 2018    Post subject: Reply with quote
alarm / immobiliser?
www.prisonplanet.com
LustyLew
PostPosted: 12:22 - 18 Jul 2018    Post subject: Reply with quote
Factory Yamaha Y.I.S.S, though it did have a Datatool S3(?) Green, which was removed by the previous owner and it sat on my desk.
MCN
PostPosted: 12:49 - 18 Jul 2018    Post subject: Reply with quote
TLDRA
Battery Ground/Earth connection to frame is loose/dirty.
Easy to miss.
jaffa90
PostPosted: 16:50 - 18 Jul 2018    Post subject: Reply with quote
MCN wrote:
TLDRA
Easy to miss.
Who said that?
doggone
PostPosted: 22:03 - 18 Jul 2018    Post subject: Reply with quote
MCN wrote:
TLDRA
Easy to miss.
I'd go with this too, to test attach a jump lead to negative terminal and a bright part of frame.If things seem more normal it's a big clue even if it still won't turn over.
MCN
PostPosted: 05:44 - 19 Jul 2018    Post subject: Reply with quote
jaffa90 wrote:
MCN wrote:
TLDRA
Easy to miss.
Who said that?
Who said TLDRA?
LustyLew
PostPosted: 07:46 - 19 Jul 2018    Post subject: Reply with quote
Well it's back up and running.
Took all the panels off and began checking every connector I could see. Had my hand under the tank when I suddenly heard the FI pump whirr into life.
A bit more faffing found what I assume is the FI system relay. Loads of wires going into it (definitely not the ECU). Disconnected, given a bit of a clean and re-seated.
Voila!
Not just to address all the other niggles!!
Thanks all.
PostPosted: 12:21 - 19 Jul 2018    Post subject: Reply with quote
inb4 stranded. Wink
Glad you found it, but I'd be a bit cautious with no long distances in the near future.
LustyLew
PostPosted: 13:08 - 19 Jul 2018    Post subject: Reply with quote
Paddy. wrote:
inb4 stranded. Wink
Ever the optimist! Wink
Yes, I am going to be incredibly paranoid for the next couple of weeks.
I'm planning to give the whole bike a good clean this weekend, try to get everything squeaky clean and properly lubed! Oh, not to mention replacing the 20a fuses with 10a as they should be!
The last post was made 8 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 106.05 Kb
