Real things you ignored but really was a fault?
Old Git Racing
PostPosted: 22:19 - 17 Jul 2018    Post subject: Real things you ignored but really was a fault? Reply with quote
I got a 350 YPVS from someone. There was always a strange 'clacking' sound when I started it, ignored it and rode it, rode ok. Started to get a misfire, but if you put the fuel tap on prime instead of normal or reserve it got rid of it. Over time it got worse, I knew it had to do with the 'clacking', but didn't want to admit to myself. Got to a point where I rigged up a dummy fuel tank without all the vacuum tap shit and it ran fine. Turned out to be the base gasket on the right cylinder leaking and stopping the vacuum tap working correctly cos it takes it from the right hand carb. Thing is I sort of knew that replacing the tap, having the carbs off loads of times and finding nothing wasn't the problem. Top end off, new gaskets all ok.
OGR
PostPosted: 23:03 - 17 Jul 2018    Post subject: Reply with quote
RE bullet 350 popping and banging on the overrun. Tried sealing the exhaust to no avail so ignored it for a good 6 months until it eventually sounded like a machine gun when you were going downhill and seemed a bit down on power.
Turned out the exhaust valve seat was in finger-tight and was flapping in and out of the head as the valve opened and closed.
Shaft
PostPosted: 23:59 - 17 Jul 2018    Post subject: Reply with quote
Not a bike, but my first 3ltr Capri.
Always had a tick that didn't sound right, had to strobe the timing most weeks (distributor bearing was fooked - well known fault) and became an expert at setting the tappets - still the tick wouldn't go away.
One day, I race a guy in an RS2000 round the South Circ, hand him his arse and cruise off in a different direction - all of a sudden, the tick gets much louder, I glance at the oil pressure gauge, it drops to nothing and the engine seizes.
My engine builder reckoned it was the worst case of oil pump drive failure (another well known Essex V6 fault) he had ever seen, seized on every cylinder Rolling Eyes
chickenstrip
PostPosted: 00:03 - 18 Jul 2018    Post subject: Reply with quote
I found my 400 Superdream to have crap performance and poor handling. I ignored it when I realised the problems were design faults.
PostPosted: 09:54 - 18 Jul 2018    Post subject: Reply with quote
"I must have something caught in/hanging off the fairing."
"One more lap and I'll pull in and check it out."
Nope - that was the sound a 675 engine makes when it hasn't got any oil in it.
And I hadn't clicked that I didn't get that much oil out the previous oil change. (And wasn't aware that you should really use the max line on the dipstick as a minimum.)
Or that I was losing out on the straights on a previous trackday to a friend on an R6 who I was normally evenly matched with.
PostPosted: 09:58 - 18 Jul 2018    Post subject: Reply with quote
I drilled a tiny hole in my dipstick for the new max level on my ST3...
PostPosted: 10:03 - 18 Jul 2018    Post subject: Reply with quote
Years ago I bought a damaged repairable TT600. It was dirt cheap, and I had it delivered to my parents house where I lived at the time. I spent an age fitting new lights, indicators etc. and got it all working. It was only a couple of years old so it didn't need an MOT.
So on the fateful day I started riding it to work, and heard a nasty grinding noise. I thought it was a loose exhaust header nut or something so I kept riding. The noise got worse. The bike started to sound like a Ducati. The noise got yet worse... And then... The engine seized completely.
Turns out, it had dropped a valve, turned the valve head upside down and rammed it back into the head. Dead bike.
WD Forte
PostPosted: 10:21 - 18 Jul 2018    Post subject: Reply with quote
While it were still all fields round here and goal posts were made from jerseys, my first proper, on the road bike was an old Tiger cub.
I rode it happily for a week or two until the petrol tank got all rattly and knocky when it was pointed out to me I had run it dry and the 'noisy tank' was actually the big end knocking.
No more cub.
A good but painful first lesson in maintenance
bikers smell of wee
Loui5D
PostPosted: 10:30 - 18 Jul 2018    Post subject: Reply with quote
thought the knocking i was getting at the front was due to a dodgy fork seal, was actually a collapsed bearing.
STONEY!
PostPosted: 11:02 - 18 Jul 2018    Post subject: Reply with quote
on my first bike at 16 I ignored everything unless it made it faster, ended up running about with nothing but a sidelight, bald tyres, a chain so loose it fell off regularly and only a back brake for about 3 months on the plus side it had a shiny new big bore kit, race pipe, carb and air filter, I fell of it a lot. Laughing
PostPosted: 11:11 - 18 Jul 2018    Post subject: Reply with quote
Thought the road was pretty greasy on the way to an MOT. Tester shouts across "What the f- do you call this?" as he's wobbling the rear wheel side to side a good half inch. Total wheel bearing failure.
PostPosted: 12:30 - 18 Jul 2018    Post subject: Reply with quote
The chain's only a little noisier than it was yesterday.
It's always made that rhythmic clicking, hasn't it?
Clunk-[jerk]-graaaaunch is characteristic, right?
https://i.imgur.com/EaWB09B.jpg
Vracktal
PostPosted: 20:30 - 18 Jul 2018    Post subject: Reply with quote
'kin hell borg, I thought my F800 sprockets were bad!
Anyway on my old KLE I noticed at traffic lights it was sounding a bit louder than usual, idling slightly worse and making a metallic smell. This got worse and worse over the period of three months until the entire left hand exhaust header pipe snapped off. It had been rusting away from behind all that time and I never noticed.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
mentalboy
PostPosted: 02:41 - 19 Jul 2018    Post subject: Reply with quote
Pfft, bit of weld and it'll last for another eleventy thousand miles.
Omitting to regularly check the oil in my old Triumph Herald was a particularly stupid failing on my part. Luckily those were the days when you could visit a breaker and upon parting with 50 quid and a bit of grunting leave with a perfectly serviceable replacement. Some might say that having to replace three engines on the same vehicle was somewhat careless.
It's definitely a fine art though, repeating the trick in a Leyland 7.5ton flatbed on the M5 was a trifle interesting when the coolant tank didn't much fancy acting as an oil cooler and redecorated the whole cab, the flatbed, and presumably, a not unhealthy stretch of the M5 with old engine oil. It was as though someone had turned off the lights!
Make mine a Corona.
PostPosted: 08:53 - 19 Jul 2018    Post subject: Reply with quote
Eh, I lived. When I felt that tooth start to chew away at the chain every time I leaned it over, I accepted it was time to change the C&S.
The last post was made 7 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 92.07 Kb
